Joeledmund
puppy doesn't work on new board?!?
Wed Oct 24, 2012 7:38 am
i dont know if it is me or the 512Mb Rpi but i cant get puppy to work at all the little green light doen't even turn on but i got wheezy to work 8gb sd , tiny core linux to work 256Mb sd, and fendora to work 4gb sd
i even tried the new alpha 3 and 4 so i dont know what to do
cport80
Re: puppy doesn't work on new board?!?
Thu Dec 20, 2012 12:06 pm
Puppy does work on the 512mb pi but I think there was an issue with the loader of the Alpha4 release. If I remember rightly I had to mount the sd card on a PC and replace the bootcode.bin file with the one from a Raspbian install.
I have it running here and like all the other puppy variants it seems very slick with a good selection of applications :).
drgeoff
Sat Dec 29, 2012 5:20 pm
See http://www.raspberrypi.org/phpBB3/viewt ... 54#p242754 for the explanation that new firmware is required for the 512M RPi. The Puppy distributions have an older firmware.
don570
Mon Oct 26, 2015 10:39 pm
A puppy user has reported success in installing FatdogArm
on new board.
I've got to run FatdogArm on a Raspberry Pi 2 and using Berryboot as bootloader.
http://murga-linux.com/puppy/viewtopic. ... &start=210
It needs testing.
__________________________________________________________________
Return to “Puppy”
