pinilpypinilpy
running x86 linux programs on the raspberry pi
Mon Feb 05, 2018 1:04 am
I managed to get an i386 wheezy chroot running on stretch (pi2) with qemu-i386-static. as far as I know, to get a working version of wine you need to compile eltech's 2g/2g version from their github page. I have not tried it. everything works but it runs slowly. it took half a minute to start PuTTY.
(ps. another way to get wine working is to compile the pi's kernel with a 3g/1g memory split) :(
qemu only uses one core, so it might be a good idea to overclock.
instructions:
sudo su
apt-get update && apt-get install qemu qemu-user qemu-user-static binfmt-support debootstrap binutils
mount -t binfmt_misc none /proc/sys/fs/binfmt_misc
        echo -1 > /proc/sys/fs/binfmt_misc/status
        echo ':i386:M::\x7fELF\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x03:\xff\xff\xff\xff\xff\xfe\xfe\xff\xff\xff\xff\xff\xff\xff\xff\xff\xfb\xff\xff:/usr/bin/qemu-i386-static:' > /proc/sys/fs/binfmt_misc/register
debootstrap --arch=i386 --foreign wheezy chroot-wheezy-i386 http://ftp.de.debian.org/debian
(as user) cd chroot-wheezy-i386
cp /usr/bin/qemu-i386-static usr/bin/
id (need for later)
cd
sudo su
  DEBIAN_FRONTEND=noninteractive DEBCONF_NONINTERACTIVE_SEEN=true LC_ALL=C LANGUAGE=C LANG=C chroot chroot-wheezy-i386 /debootstrap/debootstrap --second-stage
echo "deb http://ftp.ca.debian.org/debian/ wheezy main" > chroot-wheezy-i386/etc/apt/sources.list.d/wheezy.list (or mirror of your choice)
env -i TERM=xterm /usr/sbin/chroot chroot-wheezy-i386 /bin/su -l root (welcome to your new debian wheezy chroot!)
apt-get update && apt-get install libsm6 libxext6 libfreetype6 libpng12-0 libmpg123-0 sudo(ignore errors)
 adduser --uid (insert uid here) pi
exit
mount --bind /home/pi /home/pi/chroot-wheezy-i386/home/pi  mount --bind /dev /home/pi/chroot-wheezy-i386/dev mount --bind /proc /home/pi/chroot-wheezy-i386/proc
exit
next part:
to use the chroot:
sudo su
xhost +
env -i TERM=xterm /usr/sbin/chroot chroot-wheezy-i386 /bin/su -l root (or pi)
export DISPLAY=:0.0
anything (and everything)you put in the pi's home/pi directory will appear in the chroot's pi directory
I may have made a few mistakes, and all thanks goes to bernhardu @ the WineHQ Forums (link to original post by bernhardu -https://forum.winehq.org/viewtopic.php? ... =25#p84325)
have fun! :P
(and bye-bye exagear)
mikerr
Re: running x86 linux programs on the raspberry pi
Tue Mar 13, 2018 3:39 pm
That gets an x86 environment- to add and use Wine for windows apps, I also did the next stage
- compiled the pi kernel for 3/1G and packaged it all into a ready made .img based on latest Stretch:
https://sourceforge.net/projects/pi-qemu-wine/
Using it is as "easy" as:
double click in the wine-user icon
type:
wine ~/.wine/drive_c/windows/notepad.exe
Flabou
Wed Aug 08, 2018 2:24 pm
I am trying to achieve the same results as you but with the most recent version of Raspbian/Debian (stretch). I've been at this for quite a while and I also read in the original thread that the host and guest OS should be the same version. Which isn't the case for Raspberry pi 3 version provided by mikerr (it runs stretch host with wheezy guest), I don't know for the Raspberry Pi 1 version provided by AlbrechtL. I don't know if this impacts performance/compatibility a lot but I am having trouble running the program I need so I want to give it a shot.
However, I don't understand everything and I have some differences with you, especially in the lines :
First of all I can't mount none because I already have the following mounted on binfmt_misc:
pi@raspberrypi:~ $ mount | grep binfmt
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
I tried doing the echos anyway, I also tried unmounting everything before mounting none, but in both case I was unable to run
However, having installed qemu using apt-get as suggested, I see there is already an entry in binfmt_misc which points to the binary qemu-i386-static. So I tried leaving everything as it is and it did launch the second phase of the debootstrap and started configuring and unpacking everything, but then it reached "Unpacking the base system" and it got stuck there for around 7 hours (I'm guessing it's too long) before I had to stop it. I had the exact same results on two different systems (a Raspberry Pi 1 and a beaglebone black wireless).
Can someone explain me why we have to mount "None" to binfmt_misc? I understand that binfmt is a feature which allows to detect executables and execute them through the correct interpreter (in this case qemu-i386-static). So I believe it should work the way I have done it (it was able to start the second stage which means it clearly used the correct interpreter otherwise I would have a "Bad exec format" error). The next thing I want to try is to create the debootstrap chroot system on standard i386 system and then copy and paste the chroot folder, is that a good idea? It means I wouldn't even need the --foreign argument and could do it in one go.
Also I don't understand why the 3G/1G is necessary on raspberry pi 3 but not on pi 1? Are they compiled with a different kernel? How do you find the virtual memory split value of the running kernel? Is it better to compile a new kernel 3G/1G or to compile a wine version which is 2G/2G like it was done by exagear?
One last question if anyone know : In the older version of this tutorial, qemu was in version 1.4.0 and required a NPTL patch as well as a system call patch to work. Here you install it without any patch, is this okay? Did qemu correct those "problems"?
Thanks in advance for your help.
liveis.life
Fri Aug 24, 2018 4:42 pm
Hi
I tried all step by step with no errors. but when i enter
i get
Segmentation fault
what should i do?
Fri Aug 24, 2018 6:02 pm
Forget it. Either buy the Eltechs stuff or buy an X86_64 based computer.
This is a doctor free zone.
jdonald
Fri Nov 16, 2018 6:48 am
Thanks so much for building that image, mikerr. Works like a charm when I try it with a basic helloworld C exercise.
    $ sudo apt install gcc-mingw-w64-i686
    $ i686-w64-mingw32-gcc hello.c -o hello.exe
    $ file hello.exe
    hello.exe: PE32 executable (console) Intel 80386, for MS Windows
    $ cp hello.exe ~/chroot-wheezy-i386/home/wine-user/
Then in the Wine x86 user shell:
    $ wine hello.exe
    hello, world!
Haven’t read that whole thread, but I don’t see why this should be a restriction. If the guest OS is only used for sandboxing Wine i386, it might as well be wheezy or anything. Your other questions are good and I don't have answers, but I can say I'm grateful to have the pre-made image so that I don't have to go through the same headaches.
I tried all step by step with no errors. but when i enter wine ~/.wine/drive_c/windows/notepad.exe i get Segmentation fault what should i do?
The Notepad window pops up for me when I run exactly that command in the Wine x86 shell. Are you following pinilpypinilpy’s complete tutorial? If so, maybe you should skip it and just use mikerr's handy image :)
For what it’s worth I’m running on a Pi 3.
tenochtitlanuk
Fri Nov 16, 2018 1:27 pm
If you haven't seen it, Dougie is referring to https://eltechs.com/product/exagear-desktop/
Minecon724
Sat Dec 29, 2018 11:09 am
How to delete it? :roll:
jdonald
Sat Dec 29, 2018 4:52 pm
Try this:
sudo umount ~/chroot-wheezy-i386
rm -rf ~/chroot-wheezy-i386
sudo apt remove qemu qemu-user qemu-user-static binfmt-support debootstrap binutils
Some things might remain like the userid, but it will free up the bulk of disk space used here.
Return to “Advanced users”
