noiling
problem with gpio
Fri Feb 02, 2018 7:20 pm
in python i always get
i have a raspberry 3
>>> GPIO.setmode(GPIO.BCM)
File "<pyshell#0>", line 1, in <module>
NameError: name 'GPIO' is not defined
pcmanbob
Re: problem with gpio
Fri Feb 02, 2018 10:02 pm
Not much actual information in your post but I am guessing you have not got the line
import RPi.GPIO as GPIO
At the start of you python program
noiling
Sat Feb 03, 2018 4:34 am
thanks
i did right
now ive got the problem want to save my program
and later edit it
but if i save and open it then there arn the
in the next line
B.Goode
Sat Feb 03, 2018 10:00 am
The crystal ball is a little hazy this morning, but it seems likely that you are using the IDLE (or IDLE3) IDE and typing into the default Python Shell Window that appears when you start the IDE. This is nothing to do with the use of gpio.
The Python Shell Window gives you an 'immediate' mode or REPL where each line you enter is directly executed by the Python interpreter. This is not an appropriate way to create a python script that you wish to save and rerun.
From the File/New drop down menu option at the top left of the IDE create a new, blank, file which will not have the >>> prompt. Type your script there and then save it.
noiling
Sat Feb 03, 2018 10:08 am
ok thanks
now ive got the problem i dont understand what exaktly to import!!! here is my skript
import Tkinter
from Tkinter import*
import time
GPIO.setwarnings(False)
GPIO.setup(4, GPIO.Out)
def anzeige(lb):
    if GPIO.input(4):
        lb.config(text="GPIO 4 high")
    else:
        lb.config(text="GPIO 4 low")
    lb.after(100, anzeige, lb)
def an():
    GPIO.output(4, 1)
def aus():
    GPIO.output(4, 0)
root = Tk()
root.title("chris ist der beste superdaed")
Label(root, text="-----").pack()
lb = Label(root, text="an")
lb.pack()
Button(root, text="an", width=40, command=an).pack()
Button(root, text="aus", width=40, command=an).pack()
anzeige(lb)
mainloop()
the message i get is
import error, no modules named Tinker
noiling
Sat Feb 03, 2018 10:11 am
coding seems not to be the problem because another script (i did really code on my own) that works is
from time import sleep
GPIO.setup(4, GPIO.OUT)
GPIO.setup(17, GPIO.OUT)
print ("hallo")
for n in range(10):
    print (n)
    GPIO.output(4, 0)
    GPIO.output(17, 1)
    sleep(0.5)
    GPIO.output(4, 1)
    GPIO.output(17, 0)
    sleep(0.5)
print ("superdäd ist der beste")
GPIO.output(4,0)
B.Goode
Sat Feb 03, 2018 10:17 am
Python relies on indentation for its syntax. Posting plain text in the forum software removes indentation, making the script close to meaningless. Please use the Code tag mark-up provided by the Code button in the top row of the message edit screen. (You can retrospectively modify your existing post.)
Please post the whole of the error message, accurately. There is indeed no standard module named Tinker. It is also important to distinguish between the (different) module names needed for use with Python3 and Python respectively.
pcmanbob
Sat Feb 03, 2018 11:27 am
Are you running you code using python 3 by any chance.
python 2 import Tkinter
python 3 import tkinter (note not capitals.)
neilgl
Sat Feb 03, 2018 11:40 am
Probably the issue is that the module is named Tkinter in Python 2 and tkinter in Python 3.
This script a.py will fail if you run it from a terminal
python3 a.py
import Tkinter
print ("hello")
ImportError: No module named 'Tkinter'
but b.py is OK
import tkinter
from tkinter import*
print ("hello")
PingoBags
Sat Feb 03, 2018 12:18 pm
You could try using try except, that way it should work in python 2&3
try:
  import Tkinter
except ImportError:
  import tkinter
B.Goode
Sat Feb 03, 2018 12:31 pm
We really need to hear from the OP, @noilng, because none of these replies directly address the error that the OP reported:
The errors of capitalisation and plural indicate that has been transcribed inaccurately, so nothing can be inferred with confidence from the text of the error.
A cut and paste of the entire error feedback would allow us to see what version of Python is being used, and what the content of the live version of the script actually contains.
