chrispercol
GPIO.HIGH turns relay on when off expected?
Mon Dec 25, 2017 9:24 pm
I'm using a relay to switch a power extension and think I may have incorrectly wired the relay. I would expect the code below to switch the power off but it switches the power on?
I have wired the first two connectors on K1 of this relay board I bought on Amazon.
https://www.amazon.co.uk/dp/B01BAFLMCI/ ... 41_TE_dp_1
Am I correct in thinking that GPIO.LOW should actually turn the relay on and if so how do I fix this?
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
# init list with pin numbers
pinList = [17]
# loop through pins and set mode and state to 'low'
for i in pinList:
  GPIO.setup(i, GPIO.OUT)
  GPIO.output(i, GPIO.HIGH)
# time to sleep between operations in the main loop
SleepTimeL = 2
# main loop
try:
  GPIO.output(17, GPIO.HIGH)
  print "ONE"
  time.sleep(SleepTimeL);
  print "Good bye!"
# End program cleanly with keyboard
except KeyboardInterrupt:
  print " Quit"
  # Reset GPIO settings
  GPIO.cleanup()
Ta,
Chris
gordon77
Re: GPIO.HIGH turns relay on when off expected?
Mon Dec 25, 2017 10:06 pm
Yes these relays are normally active low, meaning on when gpio is low.
mahjongg
Mon Dec 25, 2017 10:47 pm
read this, it might answer your questions: viewtopic.php?f=91&t=83372&p=1225448#p1225448
pcmanbob
Mon Dec 25, 2017 11:18 pm
As many people before you have found the 3.3V if the gpio is not high enough to turn the relay off.
You may find you will need to add some interface hardware to get this relay card to work with you pi.
viewtopic.php?f=28&t=197227
chrispercol
Mon Dec 25, 2017 11:40 pm
Thanks,
I think I am using a 5v pin. I'll use a 3.3v pin and see if the relay behaves as expected.
Chris
Cancelor
Tue Dec 26, 2017 6:17 am
Each relay has a block of three blue terminal connectors; connecting the power extension through pins 2 and 3 instead of pins 2 and 1 will invert the behaviour.
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
chrispercol
Tue Dec 26, 2017 11:41 am
Thanks, that's much appreciated. I will rewire and test.
My existing solution does work (inverted) but I felt a little uncomfortable using mains electricity and a relay which wasn't behaving as expected.
I'll be happy when on = on rather than off :D
Thanks again,
Chris
