stickneyar
crontab -e will not edit crontab but crontab -l will list it? - pi Jesse
Wed Sep 27, 2017 8:37 pm
I have tried to edit the crontab file to run a program at reboot,
when I enter sudo crontab -e it indicates no file exists for pi
when I enter sudo -E crontab -e I get the file I previously edited using sudo nano crontab -e and it is correct, but when I go to save it ctr-X it saves it to /tmp/crontab.xxxxx/crontab where xxxxx is different every time.
If I go to /tmp directory no crontab.xxxx file or directory exist.
I have changed the save directory to /tmp/crontab many times and when I exit no change is made.
If I enter sudo crontab -l it displays my file perfectly.
Any ideas
Ray
pcmanbob
Re: crontab -e will not edit crontab but crontab -l will list it? - pi Jesse
Wed Sep 27, 2017 9:40 pm
Buy using sudo crontab -e you are editing roots Cron file.
If you want to edit pi's Cron file the use crontab -e
crontab always saves to a temp file first once it checks the file for sanity it installs in the Cron file.
It normally repots this as installing new Cron file
Wed Sep 27, 2017 9:53 pm
Stop using sudo.
This is a doctor free zone.
Martin Frezman
Wed Sep 27, 2017 10:00 pm
And, for that matter, stop using crontab.
cron (and crontab) has all sorts of traps that catch up the unwary. Unless you really have a reason to use this bit of 70s/80s technology (or if, like many of us, you grew up on cron/crontab and you really, thoroughly, understand it), you're better off just skipping it.
Other, more modern methods exist. Probably the most straightforward is to setup a "systemd" service.
Note that I said "most straightforward"; I didn't say "the best".
If this post appears in the wrong forums category, my apologies.
