techstreat
Start Program on boot, and every 30 minutes
Wed Sep 27, 2017 1:46 pm
Hi
I have setup a DC++ hub using opendchub on raspberry pi for my college. Hub works just fine
I just wanted to know how to start the opendchub at boot??
@reboot command in crontab doesn't seem to work, then i read somewhere this is a known issue in debian, any workarounds??
Martin Frezman
Re: Start Program on boot, and every 30 minutes
Wed Sep 27, 2017 1:57 pm
There really ought to be a sticky for this.
This question gets asked every few days. Searching the forum should get you lots of answers (some good, some not so good...)
If this post appears in the wrong forums category, my apologies.
Wed Sep 27, 2017 4:14 pm
You need to consider what happens if your machine boots at 29 minutes past or 1 minute to the hour and your program takes more than a minute to run. That will get messy. The running instance needs to hold a lock file for the duration of its processing or you'll get multiple instances running.
Also does your program have a GUI interface? Because starting GUI stuff from rc.local or crontab is a non-starter.
This is a doctor free zone.
Martin Frezman
Wed Sep 27, 2017 4:25 pm
Funny. I do both all the time.
It's easy when you know how.
techstreat
Thu Sep 28, 2017 10:18 am
Yeah i tried searching none seemed to work with opendchub, but none the less i got it working using crontab
*/30 * * * * /usr/local/bin/opendchub
