pizzaboy150
A basic OpenVG code template for Beginners
Sat Aug 26, 2017 9:15 pm
Hi All,
I have been messing with OpenVG for about a year now on and off. The learning curve is very steep and there are a lot of different concepts to learn.
just getting a working context and surface can be a pain sometimes and i created a handy template that is simple for the basic programmer (like myself) that gets you up and running quickly. I thought I would share the code which is all in one file for ease and I have also shared my makefile below.
#include <iostream>
#include "bcm_host.h"
#include "EGL/egl.h"
#include "VG/openvg.h"
using namespace std;
	BCM STUFF
EGL_DISPMANX_WINDOW_T nativewindow;
uint32_t display_width;
uint32_t display_height;
int startBCM() {
	//get the bcm setup
	bcm_host_init();
	//the variables
	DISPMANX_ELEMENT_HANDLE_T dispman_element;
	DISPMANX_DISPLAY_HANDLE_T dispman_display;
	DISPMANX_UPDATE_HANDLE_T dispman_update;
	DISPMANX_TRANSFORM_T dispman_trans;
	VC_RECT_T dst_rect;
	VC_RECT_T src_rect;
	// create an EGL window surface, passing context width/height
	int success = graphics_get_display_size(0 /* LCD */,
                        &display_width, &display_height);
	if ( success < 0 )
		return 1;
	// You can hardcode the resolution here:
	//display_width = 640;
	//display_height = 480;
	dst_rect.x = 0;
	dst_rect.y = 0;
	dst_rect.width = display_width;
	dst_rect.height = display_height;
	src_rect.x = 0;
	src_rect.y = 0;
	src_rect.width = display_width << 16;
	src_rect.height = display_height << 16;
	dispman_display = vc_dispmanx_display_open( 0 /* LCD */);
	dispman_update = vc_dispmanx_update_start( 0 );
	dispman_element = vc_dispmanx_element_add ( dispman_update,
	dispman_display, 0/*layer*/, &dst_rect, 0/*src*/,
			&src_rect, DISPMANX_PROTECTION_NONE, 0 /*alpha*/,
			0/*clamp*/, dispman_trans/*transform*/);
	nativewindow.element = dispman_element;
	nativewindow.width = display_width;
	nativewindow.height = display_height;
	vc_dispmanx_update_submit_sync( dispman_update );
	//DEBUG PRINT SCREEN DIMENSIONS
	cout << "Width  : " << display_width << endl;
	cout << "Height : " << display_height << endl;
	return 0;
	EGL stuff
EGLDisplay eglDisplay;
EGLSurface eglSurface;
EGLContext eglContext;
int startEGL() {
	//lets get EGL up and running using the native window
	//we use egl to create a context for OpenVG to use
	eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
	if(eglDisplay == EGL_NO_DISPLAY) {
		cout << "Error Creating EGL display!" << endl;
		return 1;
	//initialise EGL
	if(eglInitialize(eglDisplay, NULL, NULL) != EGL_TRUE) {
		cout << "Error Initialising EGL display!" << endl;
		return 2;
	//Create an EGL config for what we want
	EGLConfig config;
	EGLint numConfigs;
	EGLint configs[] = {
		EGL_RED_SIZE, 8,
		EGL_GREEN_SIZE, 8,
		EGL_BLUE_SIZE, 8,
		EGL_ALPHA_SIZE, 8,
		EGL_RENDERABLE_TYPE, EGL_OPENVG_BIT,
		EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
		EGL_NONE
	//Choose the config to use
	if(eglChooseConfig(eglDisplay, configs, &config, 1, &numConfigs) == EGL_FALSE) {
		cout << "Error With EGL config!" << endl;
		return 3;
	//tell EGL we are using OpenVG
	//IMPORTANT THIS MUST BE DONE BEFORE CREATING THE CONTEXT!
	if(eglBindAPI(EGL_OPENVG_API) != EGL_TRUE) {
		cout << "Error setting api to openvg!" << endl;
		return 7;
	//Now lets create the rendering context
	eglContext = eglCreateContext(eglDisplay, config, EGL_NO_CONTEXT, NULL);
	if(eglContext == EGL_NO_CONTEXT) {
		cout << "Error creating context!" << endl;
		return 4;
	//Create the window surface
	eglSurface = eglCreateWindowSurface(eglDisplay, config, &nativewindow, NULL);
	if(eglSurface == EGL_NO_CONTEXT) {
		cout << "Error creating surface!" << endl;
		return 5;
	//make context current
	if(eglMakeCurrent(eglDisplay, eglSurface, eglSurface, eglContext) != EGL_TRUE) {
		cout << "Error making context current!" << endl;
		return 6;
	return 0;
	Open VG Setup
int startVG() {
	//set the screen clear colour
	VGfloat color[4] = {0.2f,0.2f,0.2f,1.0f};
	vgSetfv(VG_CLEAR_COLOR, 4, color);
	return 0;
	Open VG Drawing
int drawVG() {
	//clear the screen
	vgClear(0, 0, (VGint)display_width, (VGint)display_height);
		DO ALL THE DRAWING FROM HERE
	return 0;
	Main Program Start
int main(int argc, char *argv[]) {
	//start up bcm and check for error
	if(startBCM() != 0) {
		cout << "Error starting BCM!" << endl;
		return 1;
	//setup EGL for our context
	if(startEGL() != 0) {
		cout << "Error starting EGL!" << endl;
		return 2;
	//Start OpenVG
	startVG();
	//Program loop
	int count = 0;
	while(count < 600) {
		//Drawing
		drawVG();
		//swap the buffers
		eglSwapBuffers(eglDisplay, eglSurface);
		//Increment timer thinking 60hz refresh here
		count++;
	//cleanup
	eglDestroySurface(eglDisplay, eglSurface);
	eglDestroyContext(eglDisplay, eglContext);
	eglTerminate(eglDisplay);
	return 0;
The Make File
all:
g++ -Wall clock.cpp -o clock -I/opt/vc/include -I/opt/vc/include/interface/vmcs_host -L/opt/vc/lib -lbcm_host -lEGL -lGLESv2 -lOpenVG
Hope someone finds it useful !!
Return to “OpenVG”
