Milliways
Stretch Networking
Fri Aug 18, 2017 6:55 am
I just installed Stretch, and performed a clean install.
As expected there also appears to be a (partial?) change to predictable network interface names https://www.debian.org/releases/stretch ... face-names
The Ethernet name is now based on MAC, but continues to use wlan0 for the Wireless Interface.
There seems to be no mention of the change in the release notes, and in particular, why Wireless Interface wlan0 remains.
Is there any reason for the partial change?
RaTTuS
Re: Stretch Networking
Fri Aug 18, 2017 7:20 am
Covfefe
Milliways
Fri Aug 18, 2017 8:24 am
I am aware of this, but I was looking for some Raspbian specific link, and specifically the reason why NOT wlan0.
Fri Aug 18, 2017 11:49 am
The WiFi chip is connected over sdio, not usb, this mac address naming is for usb attached devices.
elkberry
Fri Aug 18, 2017 7:44 pm
Using the officially posted "fix" for returning to the "unstable", yet stable naming scheme by setting the appropriate symlink caused my wireless LAN interface to completely disappear. Well done.
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
Sat Aug 19, 2017 8:03 am
No need for thanks, that needs to go upstream to the people in Linux land who made the change. Nothing to do with RPF.
Note also, the previous naming scheme was not stable. With two usb adaptors you could not guarantee which becomes eth0. That is why the change was made. Whether it's a good change, dunno.
runboy93
Sat Aug 19, 2017 10:02 am
https://raspberrypi.stackexchange.com/q ... 7921#37921
Raspberry Pi foundation can do nothing for this problem, we need wait longer for fix :/
Martin Frezman
Sat Aug 19, 2017 11:12 am
The Raspbian maintainers *could* change (fix) this, by any of the 3 documented methods (*), but it is not clear that they would be ideologically compatible with doing so. Like systemd, it seems this trend is, like it or not, the future. As a mentor told me back in the 80s, the key to survival in the world of Personal Computing is "Don't buck trends".
(*) I think (emphasis on that word) that the most straightforward method would be the "cmdline.txt" method, since I would assume that that file is not controlled by "upstream", as it is RPi-specific.
If this post appears in the wrong forums category, my apologies.
epoch1970
Sat Aug 19, 2017 11:35 am
I thought in this case you would use a udev rule and fix names according to MACs.
I'm pretty sure I did that and it was working. Was I lucky?
Return to “Raspbian”
