pxf.hit
windows cannot access raspberrypi
Mon Jul 17, 2017 1:29 pm
as shown in this figure. I am using Win10 to access raspberry failed. cannot access.
My pi's IP is 192.168.2.104. So I tried to use the IP address to access it.
But it's failed again.
I also try to ping the IP, and it works.
So, my issue is that, I can find the Raspberry share folder on the network, but cannot access it.
Some one please help me, thanks.
drgeoff
Re: windows cannot access raspberrypi
Mon Jul 17, 2017 6:16 pm
pxf.hit wrote: So, my issue is that, I can find the Raspberry share folder on the network, but cannot access it.
What is your evidence for "I can find the Raspberry share folder on the network"? Being able to ping the RPi is not it.
I suspect that samba server is not running on your RPi. Is it even installed?
pxf.hit
Tue Jul 18, 2017 6:58 am
Thanks for your reply.
Use the windows network to view the shared computers in LAN.
And I have installed the samba.
LetHopeItsSnowing
Tue Jul 18, 2017 8:25 am
Is windows firewall restricting access?
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
mattmiller
Tue Jul 18, 2017 8:50 am
How did you install samba
What is your smb.conf file
I use this one
#======================= Global Settings =======================
[global]
workgroup = WORKGROUP
wide links = yes
unix extensions = no
dns proxy = no
#### Debugging/Accounting ####
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
security = user
map to guest = Bad User
guest account = pi
#======================= Share Definitions =======================
[root]
comment = Admin Config Share
path = /
browseable = yes
force user = root
force group = root
admin users = pi
writeable = yes
read only = no
guest ok = yes
create mask = 0777
directory mask = 0777
[pi]
comment = pi user /homepi folder
path = /home/pi
browseable = yes
force user = pi
force group = pi
admin users = pi
writeable = yes
read only = no
guest ok = yes
create mask = 0777
drgeoff
Tue Jul 18, 2017 1:17 pm
Is the samba server running?
pxf.hit
Mon Sep 11, 2017 2:24 am
Thank you all for your kind reply.
I have solve the issue of access. The problem is from the user credentials. Cause the first time I use the option of remenbering password.
After I clear the Windows Credentials. It's ok to access the samba.
