JGHunter
Quake and Quake III, but not Quake II?
Sat Apr 15, 2017 4:07 pm
I've been searching around hoping for a way to get Quake II on my RetroPie, however all I ever see is how Quake and Quake III are available with Ports. If Quake III is possible, surely II is?
If it is possible, how can I go about getting Quake II to work? Should I use Ports, or a PC engine, or what? Very confused! Thanks
I have two things: a Raspberry Pi and dreams...
raysaaron
Re: Quake and Quake III, but not Quake II?
Sat Apr 22, 2017 10:18 am
I think someone ported quake2 to Pi b+ not PI 2 and 3.there is no way to get it working
raysaaron
Thu May 04, 2017 1:14 pm
i have just messed around with https://github.com/yquake2/yquake2 branch opengl es i have got it compiling but gives me a black screen
runboy93
Fri Jun 23, 2017 11:03 pm
Have anyone tried to compile recently and able to play quake II?
Or have you tried urho3d?
ofc there is always Exagear + Quake 2 D: but not port.
spidey57
Wed Jul 26, 2017 11:06 pm
Quake2 does run on a Raspberry Pi 3!
Using 2017-07-05-raspbian-jessie with the latest yamagi-master source code v7.02pre.
Install dependencies build-essential libgl1-mesa-dev libsdl2-dev libogg-dev libvorbis-dev libopenal-dev zlib1g-dev then compile as per instructions.
Place pak0.pak & yq2.cfg in the baseq2 directory and ./quake2 to start.
Will also work with the experimental OpenGL driver.
But will fail with "Bus error" after a few minutes - any ideas?
Quake2 will also run on the Raspberry Pi Zero-W in dedicated server mode.
spidey57
Thu Aug 03, 2017 4:43 pm
Okay lets start over... Quake2 running on Raspberry Pi 3!
using 2017-07-05-raspbian-jessie.img
We need
https://github.com/yquake2/yquake2/tree/opengl_es
Latest commit 9f638c7 on 26 May 2012
download the zipfile & extract
sudo apt-get install build-essential libgl1-mesa-dev libsdl2-dev libogg-dev libvorbis-dev libopenal-dev zlib1g-dev
sudo apt-get install libsdl1.2-dev
edit makefile
# Refuse all other platforms as a firewall against PEBKAC
# (You'll need some #ifdef for your unsupported plattform!)
ifeq ($(findstring $(ARCH), i386 x86_64 sparc64),)
$(error arch $(ARCH) is currently not supported)
endif
change to
ifeq ($(findstring $(ARCH), i386 x86_64 sparc64 armv7l),)
endif
make
add pak0.pak & yq2.cfg to /baseq2
NB Just google q2-314-demo-x86 and extract pak0.pak
./quake2
Also works with GL driver
sudo raspi-config
activate experimental GL driver & 64 mb gpu memory
40 fps with q2demo1.dm2
NB for better performance append
set s_initsound 0
set r_shadows 0
set gl_shadows 0
set gl_dynamic 0
to /baseq2/yq2.cfg
don't forget to add a cpu heatsink
Happy fragging.
Quake2 will also run on the Raspberry Pi Zero-W. Just take the SD card from the Raspberry Pi 3 put into the Pi Zero-W and boot up.
10 fps with q2demo1.dm2
Shafticus
Mon Aug 07, 2017 7:18 pm
For those googling for running Quake 2 - This will not work on RetroPie using these instructions. RetroPie is not compatible with the GL Driver turned on. I'm trying to get more information on how to get it to work for RetroPie users. spidey57 seems to be pretty knowledgeable in such things, so thought I would beg his advice further.
I think this was a typo:
sudo apt-get install apt-get install build-essential libgl1-mesa-dev libsdl2-dev libogg-dev libvorbis-dev libopenal-dev zlib1g-dev
Should be:
After that compiling was fine. I ended up putting the files in /opt/retropie/ports/quake2/
When setting up a script to run it like other RetroPie ports, I found that it couldn't find the base directory for the files. I checked the git page and ended up with this:
"sudo /opt/retropie/ports/quake2/quake2 +set basedir /opt/retropie/ports/quake2/"
That is as far as I got. Ended up with this:
Yamagi Quake II v4.21
Client build options:
+ CD audio
+ OGG/Vorbis
+ OpenAL audio
+ Zip file support
Platform: Linux
Architecture: Unknown
Byte ordering: little endian
Added packfile '/opt/retropie/ports/quake2//baseq2/pak0.pak' (1106 files).
Using '/root/.yq2/baseq2' for writing.
execing default.cfg
execing yq2.cfg
couldn't exec config.cfg
basedir is write protected.
Console initialized.
------- sound initialization -------
not initializing.
----- refresher initialization -----
LoadLibrary("/opt/retropie/ports/quake2//ref_gl.so")
Input initialized.
Refresher build options:
- OpenGL ES
+ Dynamic Quake GL
+ Retexturing support
+ Vertex arrays
- Gamma via X11
Refresh: Yamagi Quake II OpenGL Refresher
Using libGL.so.1 for OpenGL.
SDL video driver is "fbcon".
setting mode 4: 640 480
SDL SetVideoMode failed: OpenGL not available
Reverting to gl_mode 4 (640x480) and windowed mode.
recursive shutdown
Error:
pi@retropie:/opt/retropie/configs/ports/yquake2
Any help is greatly appreciated. I'm hoping that there is not a fundamental incompatibility with RetroPie and yquake2.
spidey57
Mon Aug 07, 2017 8:56 pm
typo corrected
thx
LeSanglier
Wed Aug 16, 2017 8:20 am
Hi spidey57 ! :D
Your tutorial runs perfectly !! ;-)
I can play now Quake 2 on my Raspi3 ! \o/
Mon blog sur le Raspberry Pi : http://framboisepi.fr/
Pour avoir plus de chance d'avoir une réponse à votre question,
allez sur le forum français Rasberry Pi : http://forum.raspfr.org
BenMcLean
Mon Aug 21, 2017 10:07 pm
So, are binaries going to be distributed or does everyone need to compile their own?
lejionator
Sun Sep 17, 2017 11:38 pm
And about the Mission packs of Quake2 to Raspberry???
BenMcLean
Mon Sep 18, 2017 4:13 pm
Anyone? Binaries?
The mission packs involve no additional code, so if Quake II works, it follows that the mission packs work.
If it works then the only thing left to do at this point is for someone to distribute the binaries and someone to write a module for the RetroPie setup script to dowbload them.
rpiMike
Mon Sep 18, 2017 5:23 pm
I've just built this and get the same 'bus error' others have mentioned after about 1 minute :(
BenMcLean
Mon Sep 18, 2017 5:31 pm
Oh. It's dissappointing to hear that. I hope someone can take a look at this soon. Quake II is a great party game for co-op.
spidey57
Mon Sep 18, 2017 9:44 pm
Quake2 mission packs on Raspberry Pi 3 (Rogue "Ground Zero" & Xatrix "The Reckoning")
First up .... follow my notes as per
viewtopic.php?f=78&t=180667#p1194521
For Rogue - get the source:-
https://github.com/yquake2/rogue/releas ... ROGUE_2_04
unzip
cd rogue dir
make
create a new dir rogue in same dir as quake2/baseq2
copy the compiled game.so here from the release dir
also copy the pak0.pak from your original Rogue cd
start game with
./quake2 +set game rogue
For Xatrix - get the source:-
https://github.com/yquake2/xatrix/relea ... ATRIX_2_05
unzip
cd xatrix dir
make
create a new dir xatrix in same dir as quake2/baseq2
also copy the pak0.pak from your original Xatrix cd
start game with
./quake2 +set game xatrix
Happy fragging.
BenMcLean
Mon Sep 18, 2017 9:51 pm
Oh, so unlike in Quake 1, you're saying the Quake 2 expansions DO require code changes? That's very interesting. I didn't know that.
When might we see some binaries distributed?
osu
Sat Sep 23, 2017 10:51 am
Here's a little known fact. Nobody uses OpenGL ES on Linux except Android devs. Enable the open source driver and use OpenGL.
BenMcLean
Thu Nov 30, 2017 7:16 pm
No progress on this?
VincentGR
Thu Dec 14, 2017 3:48 pm
Hello everybody, totally new to Raspberry/Linux.
I tried the above and it came with an error:
src/refresh/files/jpeg.c:30:21: fatal error: jpeglib.h: No such file or directory
So I've installed this:
sudo apt-get install libjpeg-dev
Tried again and:
src/refresh/files/jpeg.c:55:1: error: conflicting types for ‘jpeg_mem_src’
jpeg_mem_src(j_decompress_ptr cinfo, unsigned char *mem, unsigned long len)
No idea what it means and what to do :D
Thanks in advance,
Dimitris.
spidey57
Sat Dec 16, 2017 6:44 pm
Using the latest
raspbian debian stretch with desktop november 2017 2017-11-29 kernel v4.9
gave me the exact same error!
Use this as suggested earlier:-
http://downloads.raspberrypi.org/raspbi ... jessie.zip
VincentGR
Sat Dec 16, 2017 6:47 pm
Not gonna install again the OS.
Maybe if I have a spare SD an then move it.
Thank you very much!!!
jdonald
Sun Dec 17, 2017 3:05 am
Yeah, good catch. Would be great if spidey57 could edit his instructions above to include this package!
Inspecting /usr/include/jpeglib.h, it seems earlier versions of gcc were more lenient while gcc 6 on Stretch requires the const-ness to match. You can fix like so:
--- a/src/refresh/files/jpeg.c
+++ b/src/refresh/files/jpeg.c
@@ -52,7 +52,7 @@ jpg_skip_input_data(j_decompress_ptr cinfo, long num_bytes)
 void
-jpeg_mem_src(j_decompress_ptr cinfo, unsigned char *mem, unsigned long len)
+jpeg_mem_src(j_decompress_ptr cinfo, const unsigned char *mem, unsigned long len)
However, once I had this running it then became evident in the settings that it's rendering using OpenGL, not GLES, so what was the point of pulling a branch named opengl_es? (For what it's worth I tried setting gl_driver in ~/.yq2/baseq2/config.js to libGLESv1_CM.so.1 which resulted in a crash in qglPolygonMode, libGLESv2.so.2 crashed in qglAlphaFunc.)
If we're using OpenGL + GLX anyway, might as well build the master branch:
git clone https://github.com/yquake2/yquake2.git
Most of the other steps such as installing dependencies, running make, and copying pak{0,2}.pak are still required.
The resulting build works better (significantly higher framerate), does not require the above change to Makefile nor jpeg.c, and even allows selecting between OpenGL 3.2 and 1.4. The improvements seem reasonable considering the opengl_es branch was last updated 6 years ago, compared to the master branch 11 hours ago.
VincentGR
Sun Dec 17, 2017 2:38 pm
@jdonald
It works with OpenGL1.4 like a charm.
I have 60-40 fps at 640x480 with no overheat.
Thank you very much.
BenMcLean
Sun Dec 17, 2017 7:57 pm
Can we get binaries distributed?
VincentGR
Sun Dec 17, 2017 8:29 pm
If it is legal and the site permits it, there is no reason I wouldn't upload them.
Return to “Gaming”
