Canedje
compare unity8_t to a string not working
Tue Nov 29, 2016 7:20 pm
I do try to test an unity8_t var (payload) with a string (p).
I do convert a string to an unity8_t var called p, by:
String test = "message received : Ben je er al?";
const uint8_t* p = reinterpret_cast<const uint8_t*>(test.c_str());
Then I do compare "p" with a websocket called "payload" by:
if ( payload == p) {
If I print both p and payload I do see no difference but the if test is false?
How is this possible?
What am I doing wrong?
PeterO
Re: compare unity8_t to a string not working
Tue Nov 29, 2016 7:59 pm
Do you understand what a pointer is ?
PeterO
Canedje
Tue Nov 29, 2016 8:04 pm
yes I do.
In the past I did programming. That is a while ago.
PeterO
Tue Nov 29, 2016 8:34 pm
Canedje wrote:yes I do..
Are you sure ? You are comparing pointers to two strings and wondering why they aren't the same. You need to compare the strings themselves, not their addresses.
PeterO
Canedje
Tue Nov 29, 2016 9:08 pm
Thanks.
I know that a pointer is an adress to the value and not the value itself.
I still having trouble comparing a uint8_t with a string.
I do try to compare the uint8_t var named "payload" with a string named "test"
If both the value is : "Ben je er al?" the if statement is true.
I don't know how the codse looks like to change uint8_t pointer the string itself string
How to make the code to compare these in a if test.
Canedje
Wed Nov 30, 2016 12:22 pm
Thanks again.
This was what I needed.
Return to “C/C++”
