imrehg
Rotate to 90 or 270 degrees
Tue Nov 29, 2016 1:58 pm
Hi, I'm using the 7" display, using the default Raspbian image, and trying to rotate both the screen and the touch events to 90 degrees. I've seen that I need to use the "lcd_rotate" setting in config.txt. Been trying the range of settings (found e.g. in this blogpost), but looks like the 90 and 270 degree settings don't work.
lcd_rotate=0 # normal WORKS
lcd_rotate=1 # rotate 90 degrees DOESN'T WORK
lcd_rotate=2 # rotate 180 degrees WORKS
lcd_rotate=3 # rotate 270 degrees DOESN'T WORK
lcd_rotate=0x10000 # flip screen horizontally WORKS
lcd_rotate=0x20000 # flip screen vertically WORKS
Any other setting it might need, or am I missing anything? Been trying to increase "gpu_mem" as well, but makes no difference in the outcome. Feedback is really appreciated.
Re: Rotate to 90 or 270 degrees
Tue Nov 29, 2016 4:49 pm
What OS? What version of the firmware/kernel?
Backup /boot and /lib/modules then try sudo rpi-update and retest your rotate settings.
aBUGSworstnightmare
Tue Nov 29, 2016 5:21 pm
do you have a frame buffer defined? Maybe try doing it like this (with the right resolution of 800x480pixels of course):
# uncomment to force a console size. By default it will be display's size minus
# overscan.
# Portrait or Landscape Setting - only uncomment one block at a time
# Portrait-1 ( normal )
display_rotate=0
framebuffer_width=960
framebuffer_height=160
# Landscape-2 ( upside down )
#display_rotate=2
#framebuffer_width=960
#framebuffer_height=160
#Portrait-1 ( right side up )
#display_rotate=1
#framebuffer_width=160
#framebuffer_height=960
# Portrait-2 ( left side up )
#display_rotate=3
Sorry, don't have an official display but this works for me when using DPI
imrehg
Tue Nov 29, 2016 5:57 pm
Raspbian (as mentioned in the original post), updated to the latest firmware and kernel (4.4.32-v7+), after updating everything. Still 90 and 270 degree rotation does not work with the display.
display_rotate=0
Yes, display_rotate works for what it does, but the point of lcd_rotate is to rotate both the display and the touchscreen settings. The display_rotate setting only translates the display, and thus the touches show on the wrong place.
JimmyN
Tue Nov 29, 2016 6:51 pm
imrehg wrote: Yes, display_rotate works for what it does, but the point of lcd_rotate is to rotate both the display and the touchscreen settings.
Only lcd_rotate=0, and lcd_rotate=2 rotate the touch inputs along with the screen (0 and 180deg). As noted in the blog link you posted, when rotating 90 and 270 lcd_rotate doesn't rotate the touch correctly.
Maybe you should clarify what "doesn't work" means. The display doesn't rotate to either 90 or 270, or the screen rotates but the touch inputs don't? Those are two different issues, but unfortunately both are covered by "doesn't work".
imrehg
Wed Nov 30, 2016 9:34 pm
Hi, excuse me that I'm confused by this:
The blogpost did note say anything like that, the copy of the settings above in the thread is the report of the settings results with my annotations. The blogpost says: "...Therefore, if you have an LCD screen with touch capability, it is usually better to use the following commands [lcd_rotate instead of display_rotate as above, as these will rotate the display and touch sensors:..." According to them all values should be correctly rotate both display and touch.
"Not working" means, that neither the screen nor touch rotates: setting "lcd_rotate=1" or "lcd_rotate=3" just shows the original screen orientation (0 deg rotation, same as lcd_rotate=0)
newsordice
Thu Dec 01, 2016 7:47 pm
Hello, author of the blog post mentioned by the OP. :)
I've been looking over my post and testing out the different options for lcd_rotate, it looks like only lcd_rotate=0 and lcd_rotate=2 are working. The other options I'd listed lcd_rotate=1 and lcd_rotate=3 do not work, in that the screen does not rotate 90 or 270 degrees and nor do the touch events.
I've updated my post to remove the incorrect lines and added an edit note to explain. My apologies if I'd caused any issues here.
I'm looking into a way to get the screen and touch events to rotate 90 or 270 degrees, not having much luck so far, but will let you know if I get any success.
Thanks,
newsordice
imrehg
Mon Dec 05, 2016 3:31 pm
Hey, thanks for the feedback, that's sounds all good :) Let's see what we can figure out (and maybe fix, *knock-on-wood*)
newsordice
Sat Dec 17, 2016 7:24 pm
I've been trying lots of different things to get an LCD rotation to work 90 or 270 degrees. I came across this forum post: viewtopic.php?f=108&t=120793 which suggests installing xinput.
Following the instructions by lanewinfield on Tue Sep 22, 2015 7:18 pm (first page about a quarter of the way down), I was able to get the screen to rotate 90 degrees using the /boot/config.txt file and display_rotate=1.
I was then able to follow lanewinfield's other instructions to swap the axes, but this was when the Pi was already booted up. The moment I rebooted, the display was still rotated to portrait but the touch events had reverted, so that when I touched the right of the screen the cursor arrow was at the bottom of the screen, for example.
I tried following suggestions throughout the rest of the post, including creating a file screenflip.sh in /etc/xdg/lxsession/LXDE-pi/ and making it run at autostart, as suggested by twuelfing on Sat Oct 10, 2015 7:26 pm (near the bottom of the first page with the blue text), but that didn't seem to work, and nor did the others.
I'm a little frustrated that what seems like a simple thing to do actually seems to be almost impossible!
rkanton
Tue Dec 20, 2016 10:54 pm
I'm running Jessie logging in as "pi" user.
Edit "/home/pi/.config/lxsession/LXDE/autostart" and add the following line:
@/home/pi/ts_input.sh
Edit "/home/pi/ts_input.sh" and add the "xinput" lines corresponding to your "display_rotate" value
For display_rotate=1 add in ts_input.sh:
#!/bin/bash
/usr/bin/xinput set-prop 'FT5406 memory based driver' 'Evdev Axes Swap' 1
/usr/bin/xinput --set-prop 'FT5406 memory based driver' 'Evdev Axis Inversion' 0 1
For display_rotate=3 add in ts_input.sh:
#!/bin/bash
/usr/bin/xinput --set-prop 'FT5406 memory based driver' 'Evdev Axis Inversion' 1 0
Make sure you chmod 755 /home/pi/ts_input.sh
That worked for me.
sfriedlander
Wed Feb 13, 2019 6:38 pm
Is there a confirmed solution to the touchscreen not having touches in the right spot on 90 or 270 degrees with the official 7" Raspberry Pi touchscreen?
As with many others, I got the display to rotate, but not the touches.
aBUGSworstnightmare
Thu Feb 14, 2019 2:09 pm
see here https://www.raspberrypi.org/forums/view ... 6#p1348198
some other threads cover the topic as well.
procount
Thu Feb 14, 2019 2:21 pm
I've never had any problems rotating my display 90 degrees.
Have you tried
display_lcd_rotate=
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
6by9
Thu Feb 14, 2019 3:29 pm
lcd_rotate activates horizontal and vertical flips in the panel itself. Transpose is not supported in the panel, therefore 90 and 270 degrees will never work through that config option. It is specific to the lcd display, so can munge the touchscreen input.
display_rotate tells the composition engine to apply flips and/or transpose. This is generic, so can't munge touchscreen input - use the x-input mappings that have already been linked to.
display_lcd_rotate is the newer option as the early phase of the multiple frame buffer stuff, and allows you to specify different rotate options for lcd and HDMI displays.
bedtime
Thu Mar 14, 2019 8:32 pm
#!/bin/bash
#!/bin/bash
That worked for me.
I'm running Stretch, and this worked perfectly for me. Thanks!
Return to “Official Foundation Display”
