sabareeshchambayil
Contact: Yahoo Messenger
Damaged MicroSD slot
Sun Nov 06, 2016 2:49 pm
My raspberry pi2 sd card slot damaged and pi not booting.i figured out its problem with microsd card slot and managed to run for 2 months with inserting a small piece paper along with micro sd card.
Now that Is not working(paper piece fix).
And I found a pin bend downward and tried to pick it up little with a small needle and the result is broken pin.So I thought it's better to replace the card slot and removed the microsd slot from pcb .
Now the problem is micro card slot is not available in my area .
Tried the mobile spare shops and I figured out the raspberry pi2 card slot is not using by any mobile.
What's I am supposed to do now.?
From Anywhere I can get MicroSD slot to repair my pi
Re: Damaged MicroSD slot
Sun Nov 06, 2016 3:58 pm
Put your Pi in the trash and get a new one.
Fixing it will likely cost more time and money than it's worth.
Tinderbox (UK)
Sun Nov 06, 2016 6:08 pm
There is supposedly a thread on how you can boot from an usb 2.0 port instead of the microsd.
viewtopic.php?f=63&t=155167
John.
Raspberry Pi 3 Model B
DirkS
Sun Nov 06, 2016 6:11 pm
Tinderbox (UK) wrote:There is supposedly a thread on how you can boot from an usb 2.0 port instead of the microsd.
John.
Only works on a Pi3B. OP has a model 2B
karrika
Mon Nov 07, 2016 6:47 am
This could be a suitable replacement. And it looks as shipping to India is supported for free.
http://www.ebay.com/itm/10Pcs-TransFlas ... Sw9VZXO-Wi
As 10 pieces only cost 1€ (shipping included) it is worth a try. My guess is 30 minutes work with a soldering iron and good magnifying glass. You also get 9 spares in case you ruin it again.
My suggestion is to unsolder it first. Then apply solder on the bare pads and clean up the area with alcohol. After that put the new part in the correct place. Solder one corner to the board to keep it in place. Then heat up the pads with a clean soldering iron. No more tin. Keep the iron at 255 degrees Celcius. (Or use hot air through a very small nozzle if you have this option available.)
It is definitely worth to spend a little time in fixing this. €35 for 30 minutes of work. And you learn to work with small electronics at the same time.
lumsdot
Mon Nov 07, 2016 8:59 am
You will struggle to solder that without bridging gaps
gregeric
Mon Nov 07, 2016 9:18 am
lumsdot wrote:You will struggle to solder that without bridging gaps
Drag soldering FTW. Seeing it for the first time was like watching a magic act.
Burngate
Mon Nov 07, 2016 10:34 am
gregeric wrote:Drag soldering FTW. Seeing it for the first time was like watching a magic act.
Beautiful, init?
karrika
Mon Nov 07, 2016 2:23 pm
Beautiful, init?
Drag soldering is more difficult than spreading the tin first and then heating. But if you get bridges you can use drag soldering to get rid of the bridges. I hate to clean up afterwards. That is why I don't use this technique much.
DavidS
Mon Nov 07, 2016 2:30 pm
Easier and less expensive to do it correctly, use some solder paste, and a home made solder mask. Cheaper in amount of solder used, electricity used, and time consumed. Also gives better results, can still be done with a soldering iron for repairs like that.
karrika
Mon Nov 07, 2016 6:29 pm
DavidS wrote:Easier and less expensive to do it correctly, use some solder paste, and a home made solder mask. Cheaper in amount of solder used, electricity used, and time consumed. Also gives better results, can still be done with a soldering iron for repairs like that.
Most people don't have fresh solder paste in their fridge. Also making a solder mask is difficult and costly. Applying a layer of tin on the pads before you set the connector on the board does the same thing without a need for professional equipment.
If you have a smd workstation then things are easier.
sabareeshchambayil
Tue Nov 08, 2016 8:20 am
OK friends.
Thanks for replies.
One more thing I need to know- what are the two pins in black circle?
Pi2 Micro sd slot pcb
gregeric
Tue Nov 08, 2016 9:29 am
They are likely unused pads for the card-detect switch built into the socket.
sabareeshchambayil
Tue Nov 08, 2016 10:10 am
gregeric wrote:They are likely unused pads for the card-detect switch built into the socket.
So they should be jumpered to make sure memory card will work
sabareeshchambayil
Tue Nov 08, 2016 10:14 am
Some of the compatible micro sd slot are available in aliexpress but without card detect
gregeric
Tue Nov 08, 2016 10:22 am
You can safely ignore them, they are not required for correct operation.
All that is needed is GND, 3V3, CLK, CMD & D0-D3 (the 8 pads in a row, function not in my quoted order though). And the shield soldering, so that the socket is anchored mechanically.
