techblogger911
Re: STICKY: USB boot now working on Pi3
Wed Apr 11, 2018 9:24 am
Is it working well? i want to know first to make sure. Thanks
PeterO
Wed Apr 11, 2018 9:47 am
cspan
Thu Apr 12, 2018 3:57 am
HawaiianPi wrote:
Fri Apr 06, 2018 11:55 am
So my recommendations are...
1. For simplicity with good performance, boot from one of the new "A1" class SD cards.
2. For the best overall performance, boot from a USB SSD drive.
3. If you need loads of storage, or need to record large amounts of data, go with a hard drive (preferably self-powered).
There's also no reason you cannot combine devices, like boot from an A1 SD card and use a hard drive for storage.
Thanks much, HawaiianPi!
If you don't mind a follow up question: as I plan to use the Pi as an everyday desktop computer (really), would you advise against using microSD for booting? I've read that the nature of flash memory is not terribly well suited to the high volumes of reading and writing one might get through daily desktop (and internet browsing) use; that SSD drives compensate for this to a degree with wear-leveling technology ... but I don't know if that tech is also in microSD cards (I do happen to have an A1 Sandisk Ultra microSD) or in USB flash memory sticks.
Were it not for that concern, I'd happily run the OS off the microSD and use an external, non-powered HDD for storage [I already have two of these in rotation to backup my desktop files. I like keeping my data files separate from OS files anyway.] Then, if the card gets corrupted, I put a backup card in place and resume my work, files safe, OS files easily replaced.
Since I had assumed this was an issue - I was leaning toward eschewing flash-based memory for booting and OS anyway. I already own a powered SATA docking station for 2.5/3.5 internal HDD, so I figured I'd probably buy a new internal HD and start booting from that for my Raspbian desktop. [I do have some older drives ... 80GB, 160GB, but they're so old, I'm not sure I should rely on them. OTOH, if my own files aren't on them, so what, right? Just keep a clone of the boot disk somewhere?]
Tinue
Tue May 01, 2018 6:25 pm
I usually need 2-3 tries (unplug/replug the power to the Raspberry Pi) before the Raspberry Pi 3 Plus boots from an external SSD. Direct reboot almost never works, I again have to unplug/replug one or more times. During a reboot the USB Disk remains powered, so it's not a question of startup time after power on.
It doesn't matter at all whether I use the Raspberry Pi 3 Plus' boot code, or a small SSD with the latest boot code from Github.
Hardware: The SSD is a Samsung 850 EVO. I use an unbranded eBay / Chinese USB3-SATA cable to connect.
Does anyone have direct experience with similar hardware? How can it be made to boot on the first try?
  • Different SSD, because maybe the Samsung in known to be difficult?
  • Different SATA-USB adapter or case? Is there one that is "known" to work?
Thanks for any hint!
captanjack
Sat May 05, 2018 12:38 pm
USB boot now working on Pi3 lets see this tuts it help u lot
https://www.ultimate-tech-news.com/how- ... ning-tool/
BerythaBeasley
Tue May 08, 2018 9:36 am
I had the same error in Raspbian migrating from RP3B to RP3B+.
The solution was to modify “/etc/apt/sources.list” and /etc/apt/sources .list.d/raspi.list” and set them to “stretch”.
Later, apt-get dist-upgrade, and just move SD card from old to new Raspi.
It booted without any error.
HawaiianPi
Fri Jun 15, 2018 12:27 pm
It is almost certainly the SATA-USB adapter (I am pretty sure I have tested my system with a Samsung EVO 850 SSD). Could also be an inadequate power supply. I have a few different SATA-USB adapters I have tried that worked reliably for me.
ELUTENG USB3 to SATA III Cable
Sabrent USB 3.0 to SSD / 2.5-Inch SATA Hard Drive Adapter
Grandey hot selling USB 3.0 to 2.5in SATA 3 Hard Drive Adapter Cable
I like the ELUTENG adapter best, due to its reliable operation (cold boot or reboot on 1st try), good performance and short USB cable.
The Sabrent is also excellent if you want an actively LED and longer USB cable (not tested as extensively, but no problems when I tried it).
The Grandey was cheaper when I bought it. At the current $7.75 price I'd rather have the ELUTENG or Sabrent (however, it does work well).
Both tested with a 128GB Silicon Power A55 SATA3 SSD, and a MyDigitalSSD SuperBoot 2 mSATA SSD (in a 2.5" adapter).
For the tiny mSATA form factor 128GB MyDigitalSSD SuperBoot 2 this external enclosure also works well.
Click picture for link.
See this thread for details. viewtopic.php?f=63&t=210497
Tinue
Fri Jun 15, 2018 2:24 pm
Thanks for the product suggestions! Gordon built me a bootcode.bin with a 10 Second timeout (see https://github.com/raspberrypi/firmware/issues/994), and with this one I can boot reliably.
If you were successful with a Samsung 850 and one of your adapters, and I was successful with my no-name China adapter and an old Intel SSD, it must be the combination of my adapter and the Samsung that creates problems.
I'll try to get one of the adapters that you mentioned shipped to Switzerland; Hopefully I can then boot without an SD card and a special-built bootcode.bin.
HawaiianPi
Sat Jun 16, 2018 2:32 am
It occurred to me that I probably tested the Samsung EVO850 SSD before I received the Grandey adapter (which came slow boat from China), so I did a quick retest today. FYI: My 500GB EVO850 is an mSATA form factor drive, so I used a 2.5" adapter (like the 2nd picture in my post above).
As before, the 500GB EVO850 worked fine with the ELUTENG and Sabrent USB3-SATA3 adapter cables (cold boot and reboot), but did not work reliably with the Grandey cable, or with the PC PARTS 239 external enclosure I normally use it in (reboots were unreliable), so it is more picky than the other two SSD models I tested.
I tested it on both my Pi3B and Pi3B+ to see if the improved bootloader on the newer model would help. It didn't (same results on both models). Also note that I only retested the ELUTENG SATA cable (I did not retest the ELUTENG mSATA enclosure). The results with the PC PARTS brand enclosure is particularly interesting, because it uses the same controller as the ELUTENG USB3-SATA3 cable.
EDIT:
I don't normally use the 500GB mSATA Samsung EVO850 on the Pi, but since I have it of course I had to try it. What I actually use it for is a large capacity, ridiculously fast USB flash drive in the PC PARTS 239 USB 3.0 enclosure.
janos1
Fri Jul 06, 2018 11:16 am
Hi to all,it is possible to start my PI 3 B+ but no SD card slot,it broke off?Thank you
HawaiianPi
Fri Jul 06, 2018 11:35 am
Yes, the newer 3B+ model comes from the factory with USB boot enabled out of the box. Just write the latest Raspbian Stretch image to a USB drive the same way you'd write an SD card (use Etcher). Most USB drives will work, but there are a few that may be incompatible, so if one doesn't work, try another.
My 3B+ is currently booting from an mSATA SSD in a tiny USB 3.0 external enclosure (see picture a few posts up)
janos1
Fri Jul 06, 2018 12:26 pm
Thank you for your help,just one more Q my sd reader plate the tiny metal on the back site is broke off,am steel able to try USB boot?
HawaiianPi
Fri Jul 06, 2018 4:30 pm
Yes, you can try USB boot, assuming nothing else was damaged on your Pi3B+ when the SD card slot was broken. As I said above, the 3B+ has USB boot enabled out of the box, so there is no need to set OTP bits like there was on the older model Pi3B (USB boot OTP bit is already set).
  1. Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
  2. Grab the Etcher software from https://etcher.io/
  3. Use Etcher to write the Raspbian image to your USB drive
    • You don't need to extract the image or format the drive prior to writing
    • Just run Etcher, choose the Raspbian .zip you downloaded, pick your USB drive and write
    • If you have trouble, verify the SHA256 checksum of the download
    • Writing an image to your USB drive will erase everything previously on it (backup important data)!
  4. Once Etcher has finished writing and verifying the USB drive you can use it to boot your Pi3B+
janos1
Sat Jul 07, 2018 10:46 pm
Thank you for your replay and help,look like something else is wrong because do not boot .Probable when i try to re solder i did something wrong or the overflow solder i try to clean up i made something more.Thank you for your time and help.
lorry
Fri Sep 07, 2018 11:16 am
Hi
PI2B v1.2 able to USB Boot w/o SD Card by just setting the OTP bits?
Thanks!
DyraSan
Mon Nov 26, 2018 11:57 am
Step 1: Install and update Raspbian
Step 2: Enable USB boot mode
Step 3: Prepare your USB mass storage device
Step 4: Boot your Raspberry Pi from the prepared USB mass storage device
pws
Tue Dec 25, 2018 7:27 pm
This is a nice compact case that has been quite reliable on a 3B+. Bootable/rebootable!
Seatay Aluminum Tool-Free 2.5 Inch SATA to USB 3.0 External Hard Disk Drive Enclosure for 9.5mm 7mm 2.5" SATA HDD and SSD Support UASP
https://www.amazon.com/Aluminum-Tool-Fr ... ree%2B2.5
Powered through the Pi (no USB hub or external pwr supply for the SSD).
gilsulate
Location: 26000 Springbrook Ave. #201 Santa Clarita, Ca 91380
Thu Feb 14, 2019 10:10 am
Any random USB stick is almost certainly going to have something on it, possibly with multiple partitions.
HawaiianPi
Fri Feb 15, 2019 6:30 am
And your point is ... :?
If you write a Raspbian image to the drive, it doesn't matter what was previously on it.
DianeChurchill
Mon Feb 18, 2019 11:32 am
Hello, I've googled around and seen various answers ranging from no to virtual plug-and-play on this topic. I have a Raspberry pi 3 B+ that I'm trying to boot from USB, which has the Raspian image on it and nothing else. I want to avoid buying one of those pre-loaded SDs if possible; however when I just tried to boot it it produced no output whatsoever, as though it cannot find a bootable device. It has never been booted. Will I have to get the SD or is there a way to do this?
HawaiianPi
Mon Feb 18, 2019 7:53 pm
The 3B+ has USB boot enabled by default, so you should be able to use it without a micro SD card. That being said, the Pi boot-loader is not compatible with all USB drives, and there are lots of other reasons it might not be booting, but since you provided no information about your setup or procedures there's not much we can do to help you troubleshoot.
  1. What are you using for a power supply?
  2. What kind of USB drive?
  3. How did you write the image to the USB drive?
  4. What version of Raspbian?
  5. What else is connected to the Pi (details, please)?
radnor302
Tue Feb 26, 2019 2:06 pm
Good morning to all!
I am sorry for asking I'm sure "THE" question again but I'm stuck!
I have a 3B. I did set the OTP bit and will confirm it went from 102... to 302... (Wanted to see the value before programming it)
I have a stick I loaded NOOBS on - black screen.
trashed all the partitions on the stick. made a fat32 partition and only put bootcode.bin on - black screen (didn't expect anything except the rainbow screen)
Bought a microsd - installed NOOBS on it. Booted from microsd slot and installed OS fine (WORKS!!! J)
Trashed partitions on new sd card. reinstalled NOOBS. Try to boot from USB (via adapter) - black screen.
Have an OLD external HDD with it's own PS. Tried using it - black screen.....
I'm using DD to copy img files.
Needless to say I've not had a lot of luck....
ONCE I think I had the rainbow screen and figured I was getting close. But since that, I have not been able to do it again. So maybe it was just wishful thinking....
TIA for the help!
Todd
HawaiianPi
Tue Feb 26, 2019 6:34 pm
Don't use NOOBS. Use one of the Raspbian images.
NOOBS is not an image.
  2. Grab the Etcher image writing software from https://www.balena.io/etcher/
  3. Use Etcher to write the Raspbian image to your USB drive (directly from the .zip download).
    • You don't need to extract the image or format the drive prior to writing.
    • Just run Etcher, choose the Raspbian .zip you downloaded, pick your USB drive and write.
    • If you get a warning when writing a large USB drive, make sure you selected the correct drive an continue.
    • If you have trouble, verify the SHA256 checksum of the download.
    • Once Etcher has successfully written and verified the image, it will safely eject the USB drive.
The USB drive is ready to boot your Pi 3B+ (or 3B with the USB boot OTP bit set).
Things to try if it doesn't boot:
Format an SD card with the FAT32 file system and copy just the bootcode.bin file from the small FAT32 "boot" partition of the Raspbian imaged USB drive to the SD card. Insert that SD card into your Pi and boot it with the USB drive connected (it should boot from the USB drive). You can also download bootcode.bin here (bootcode.bin). This is also how you USB boot from an older model Raspberry Pi (1B+ or 2Bv1.1).
If it still doesn't boot, power everything down and make a file named "timeout" on the bootcode.bin only SD card, then try again.
If it still does not boot, your device is probably not compatible with USB boot mode.
If it DOES boot when using bootcode.bin with the timeout file, then you may be able to get it working by setting another OTP bit that increases the wait time for the USB drive to become ready from the default 2 seconds to 5 seconds (this is a permanent change). To enable the additional wait time for USB drives, add "program_usb_boot_timeout=1" to config.txt on a Raspbian SD card and boot it once in the system. After that the system will wait up to 5 seconds for USB drives to become ready.
radnor302
Tue Feb 26, 2019 10:59 pm
Thank you the reply.
Still no joy..... Did every step.
Once I did the FAT32 with bootcode.bin I had the rainbow screen.
Then I added the file timeout (empty file) to the FAT32 partition.
Now it sends me a "B" in morse code (3 short flashes followed by a long from the green led next to the power led)
davidcoton
Tue Feb 26, 2019 11:15 pm
Isn't that "V", as in Beethoven's 5th symphony? IIRC "B" is dah-di-di-dit. :ugeek:
Signature retired
