Project XXX
Re: Pi Zero driving unusual TFT display (768x128pixel)
Sat Nov 19, 2016 11:40 pm
Is it possible that you can PM me the PCB-Files for the LQ092B5DW01 + BOM , cause if the "only" thing you need for it to work is software dependent, then mabye I can try to do some testing on that part, and see if i can find the right settings for it?
Regrads
aBUGSworstnightmare
Sun Nov 20, 2016 7:47 am
Project XXX wrote:Is it possible that you can PM me the PCB-Files for the LQ092B5DW01 + BOM , cause if the "only" thing you need for it to work is software dependent, then mabye I can try to do some testing on that part, and see if i can find the right settings for it?
Regrads
nice proposal :lol: so, let me make another one!
1) look at these two links: https://www.raspberrypi.org/documentati ... /README.md and http://www.pollin.de/shop/downloads/D120858D.PDF.
The first will direct you to the RPi DPI description, the second to the LQ092B5DW01 data sheet.
2) Spend some time on designing your own PCB, get it manufactured, assembled and tested
Ahh, btw:
LQ092B5DW01 testing
timing is still not perfect but I'm nearly there. The PCB to the right (blue one) is a Step-Up for generating 18V BL voltage, the smaller green one is an adapter PCB for the displays FPC connector (Backlight is 10-pol FPC connector).
aBUGSworstnightmare
Tue Nov 22, 2016 3:24 pm
Made a first test with RPi3 as host - looks good (sorry for bad picture quality; intend to prepare a short demo video latest tomorrow).
LQ092B5DW01 - test with RPi3
Picture shows typical setup; now time to start and prepare a suitable BL driver PCB
Project XXX
Tue Nov 29, 2016 10:07 pm
Have you prepared a suitable BL driver PCB yet? Cause mabye I'll like to buy 4 of them ;-)
aBUGSworstnightmare
Wed Nov 30, 2016 6:51 am
Project XXX wrote:Have you prepared a suitable BL driver PCB yet? Cause mabye I'll like to buy 4 of them ;-)
Simpelst BL driver is a resistor in the backlight supply. I'm using a step-up DC/DC (http://www.banggood.com/XL6009-Step-Up- ... mds=search) to get 19V for BL supply (white only, red is not used atm), limiting the current to 125mA with a series resistor.
I'm in design phase at the moment, testing my concept. I will have tow driver chips (one for red @12V and one for white @19V) which can be controlled by PWM. It will have a FH28-series connector for the BL FPC, but I'm aiming to use it for other modules as well (that's why all 8 strings will be available from test points in addition).
I have not started layouting it yet. First I want to make shure the concept idea for BL control is working. I will post all info to the 9.2in display here viewtopic.php?f=41&t=166561
Sanjeevan92
Fri Apr 05, 2019 8:49 am
I'd be interested to hear more about the PCB you've designed for it.
Can we discuss about it ?
I need this type of kit for my project
Sanjeevan
