napajedlaci.cz
The duration of the script in milliseconds
Thu Jun 23, 2016 10:02 am
This script works with seconds. But I need to display milliseconds. How? :?
#!/bin/bash
start=`date +%s`
#some script
end=`date +%s`
runtime=$((end-start))
echo $runtime
dasmanul
Re: The duration of the script in milliseconds
Thu Jun 23, 2016 10:32 am
"date +%s%N" will give you nanoseconds.
napajedlaci.cz
Thu Jun 23, 2016 10:37 am
But the results will decimal :(
Result: 8673728690
epoch1970
Thu Jun 23, 2016 10:49 am
1,000,000 nanoseconds = 1 millisecond
Just divide/truncate the ns value and you'll get ms.
napajedlaci.cz
Thu Jun 23, 2016 11:06 am
I do not understand as much as it used to script
#!/bin/bash
start=`date +%s%N`
#some script
end=`date +%s%N`
echo $runtime
dasmanul
Thu Jun 23, 2016 11:28 am
/usr/bin/printf "%.0f\n" $(echo "scale = 1; $runtime / 1000000" | bc)
shuckle
Thu Jun 23, 2016 11:29 am
#!/bin/bash
start=`date +%s%N`
#some script
end=`date +%s%N`
echo $runtime
echo $((runtime/1000000))
bc <<< "scale=4;$runtime/1000000"
napajedlaci.cz
Thu Jun 23, 2016 1:39 pm
unfortunately does not work:
runtime=/usr/bin/printf "%.0f\n" $(echo "scale = 1; $runtime / 1000000" | bc)
I do not echo statement. I want time to leave the string as runtime.
Runtime'll send over curl.
curl -F "data="$runtime http://www.example.com/send_time.php
dasmanul
Thu Jun 23, 2016 1:58 pm
Try
runtime=$(/usr/bin/printf "%.0f\n" $(echo "scale = 1; $runtime / 1000000" | bc))
napajedlaci.cz
Thu Jun 23, 2016 2:37 pm
Unfortunately, only I get zero. :?
SonOfAMotherlessGoat
Thu Jun 23, 2016 2:39 pm
Don't you need a Z shell for floating point ops (or bc as mentioned in one of the proposed solutions?)
Account Inactive
napajedlaci.cz
Thu Jun 23, 2016 3:10 pm
Unfortunately, I do not understand. It can be stated in the script? :oops:
stderr
Thu Jun 23, 2016 6:03 pm
napajedlaci.cz wrote:Unfortunately, only I get zero. :?
Are you running all the code or just that one line? You'll notice it refers to the same variable that it sets, so it would be good to have it set before calling it. Or you'll get zero.
swampdog
Thu Jun 23, 2016 6:44 pm
Bash has a builtin "time".
$ time foo
and go from there.
