DarkPlatinum
Re: STICKY: PINN - An enhanced version of NOOBS.
Sat Dec 15, 2018 7:46 pm
I just decided to use the backup tool a couple of days ago. I am using PINN with a 1 TB seagate expansion HDD and a 32 GB sandisk ultra micro SD. I have added the "os" folder to a sandisk 64 Gb usb 3.0 thumbdrive (USB 2.0 write speeds on a pi). After clicking the backup button, it says "archiving" or something similar. I am perfectly fine with that. What I dont get is that I am getting 1.0mb/s which is awfully slow.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
procount
Sat Dec 15, 2018 10:21 pm
Like I mentioned in my release post, compressing images is quite a processor intensive task, and it is also hampered by the slow USB connection.
Compressing images is always much slower than decompressing them and this is included in the overall write speed you are experiencing.
You can backup an OS much quicker on a PC, and there are instructions on my wiki how to do it by creating a custom OS. But this method makes it quite simple and straightforward to backup an OS or create a custom OS without needing another computer.
DarkPlatinum
Sun Dec 16, 2018 11:20 am
So it is best just to so it overnight? It says it will take around 4 hours to complete.
procount
Sun Dec 16, 2018 12:14 pm
Yes.
Raspbian itself can take just over an hour.
procount
Mon Dec 17, 2018 10:46 pm
PINN has been updated to v3.0.1
V3.0.1
  • Backup/Download - Removed the need to reboot after a download or backup.
  • Wallpapers - removed wallpapers folder & allowed JPEGs
Well, every major release requires a minor point release, doesn't it?
In this case it's just to save a little space and improve the workflow.
Previously, it was necessary to reboot PINN in order to take account of new OSes, after downloading an OS from the internet, or after backing-up an OS to a local USB drive. However, that is no longer necessary with this new release and they will immediately appear in the OS lists.
The /wallpapers folder has been removed from this version to avoid some bloat, but if you are upgrading, it may still exist from your previous installation. Feel free to delete it if you no longer want it as it can always be dlwonlaoded again from sourceforge.
The default wallpaper.png has been converted to wallpaper.jpg to save some space. It my be replaced by your own wallpaper.jpg or wallpaper.png image.
Haris1977
Tue Dec 18, 2018 6:05 am
Thanks for your continuous work.
Procount any news about the renaming os option (in OS Boot Selector Menu)?
procount
Tue Dec 18, 2018 8:27 am
@Haris1977 - soon (-ish), but I had to complete the fundamentals in the backup feature first.
DarkPlatinum
Wed Dec 19, 2018 4:01 pm
So I tried the backup function overnight. I came back this morning and it says it has failed, read debug logs for errors.What should I do?
procount
Wed Dec 19, 2018 6:55 pm
@DarkPlatinum
open a github issue
Post the errors you read from the debug log
Tell me which model of Pi, which OSes you were backing up & which one it failed on.
Patrick76
Fri Dec 28, 2018 9:36 pm
Hello!
Where can a find changelog/ release notes since PINN 3.0.1 for PINN 3.0.2 & PINN 3.0.3?
procount
Sat Dec 29, 2018 12:10 am
beta-tester
Sun Jan 20, 2019 8:33 pm
hi,
when i boot my RPi 3 B+ where PINN 3.0.3 is installed, i get always the following message on screen just after the rainbow splash screen and just before the PINN wallpaper appears:
[2.05...] raspberrypi-firmware soc:firmware: Get Throttled mailbox call failed
[3.33...] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 beta: 7.11.15 Compiler: 1.21.2 ClmImport: 1.24.1 Creation: 2014-05-06 10:53:55 Inc Beta: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:11
any idea how i can get rid of that message?
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B (1GB), 64GB microSDXC1 class 10, HDMI 1920x1080, keyboard-mouse-combo (wireless), PiCamera, ethernet-cable, 5V/1.2A power supply, Wifi dongle (rt5370)
procount
Mon Jan 21, 2019 5:57 am
I know they are a bit annoying, but there's not much I can do. I think the first comes from the firmware and the second from the builtin wifi driver.
beta-tester
Mon Jan 21, 2019 4:37 pm
ok, thanks... i thought i only have to add a switch to cmdline.txt or config.txt to get rid of it... :(
but why i don't see those messages when booting raspbian without PINN or NOOBS? don't they use the same raspberry pi firmware?
and i can't remember that i saw those messages on an old version of PINN or was it because it was a RPi2B at that time?
DarkPlatinum
Mon Jan 21, 2019 6:02 pm
Why does it matter if its their or not? Its just text, don't affect performance in anyway.
procount
Mon Jan 21, 2019 6:04 pm
Maybe you could restrict the log level. I haven't tried yet.
The wifi driver and firmware are newer than previous versions, hence the change.
beta-tester
Tue Jan 22, 2019 3:13 pm
when you use PINN to boot your tiny home entertainment system (retropie and LibreELEC) you don't want to see any annoying text on the screen if you don't need... it breaks the nice looking
vinaypundith
Location: Lexington Park, MD, USA, North America, Earth
Tue Jan 22, 2019 3:53 pm
I once had 3 OSes installed with PINN. One day I tried to do a firmware update from within PINN, and it got interrupted due to loss of power. My Raspberry would then not boot at all, instead getting stuck at the rainbow screen. After doing some searching online, I replaced the PINN boot folder with a fresh one from the pinn-lite.zip file. At the next bootup, it automatically deleted all the partitions on the drive, erased all my OSes and the data saved with them, and came to OS installation screen!! Any idea why?
I'm setting up a webpage and email server on a Pi 3B+ running Ubuntu Mate 18.10.
Please read the Unanswered topics section and help with whatever you can!
DarkPlatinum
Tue Jan 22, 2019 4:09 pm
I once had 3 OSes installed with PINN. One day I tried to do a firmware update from within PINN, and it got interrupted due to loss of power. My Raspberry would then not boot at all, instead getting stuck at the rainbow screen. After doing some searching online, I replaced the PINN boot folder with a fresh one from the pinn-lite.zip file. At the next bootup, it automatically DELETED ALL THE PARTITIONS FROM THE DRIVE, erased all my OSes and the data saved with them, and came to OS installation screen!!!!!! Any idea why?
Maybe because it formats the drive on start up?
procount
Tue Jan 22, 2019 4:57 pm
@vinaypundith - That is unfortunate.
If you install pinn-lite.zip afresh, then it overwrites recovery.cmdline with the default version that includes the `runinstaller`option. This causes PINN to wipe your fresh SD card to make it suitable for use with PINN. If you have any existing OSes installed, then this will unfortunately wipe them out.
Whenever your PINN self-updates, it does not change recovery.cmdline for this reason.
This is detailed in the documentation ->https://github.com/procount/pinn/blob/m ... ne-options and applies to NOOBS as well.
procount
Tue Jan 22, 2019 5:00 pm
@beta-tester - try adding `loglevel=0` to recovery.cmdline (without the quotes).
EDIT: Yep, that seems to solve it!
beta-tester
Wed Jan 23, 2019 8:37 pm
no and yes... adding loglevel=0 to recovery.cmdline didn't removed the messages,
but with adding it to recovery.cmdline.new as well i got rid of the annoying messages.
now recovery.cmdline and recovery.cmdline.new have the following content:
quiet loglevel=0 ramdisk_size=32768 root=/dev/ram0 init=/init vt.cur_default=1 elevator=deadline repo_list=http://raw.githubusercontent.com/procount/pinn-os/master/os/repo_list.json
thank you for your help!
PS.: and with adding a config.txt to the same partition (folder) with the following content i got rid of the rainbow boot splash screen, the borders around the wallpaper and the name raspberry at boot time on my TV:
disable_splash=1
disable_overscan=1
cec_osd_name=PINN
Haris1977
Thu Jan 24, 2019 9:41 am
So, maybe @procount should add the `loglevel=0` to recovery.cmdline and recovery.cmdline.new by default? Or other problems may occur? :idea:
procount
Thu Jan 24, 2019 2:45 pm
It will be considered.
Loglevel=2 is the highest value that can be used on a 3B+ to suppress these messages. Need to test other models too.
