ericp
Installing newer version of NodeJS on Pi 3
Fri Mar 18, 2016 5:40 pm
How can I install a newer version of Node Js on the Raspberry Pi 3?
node version: v0.10.29
npm version: 1.4.21
I have Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Release: 8.0 Codename: jessie
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
Thank you for any help.
LewisCowles1986
Re: Installing newer version of NodeJS on Pi 3
Fri Mar 18, 2016 9:28 pm
git clone https://github.com/creationix/nvm.git ~/.nvm && cd ~/.nvm && git checkout v5.9.0
Then whenever you want to use node run
source ~/.nvm/nvm.sh
or add that line to your `.bashrc` or `.profile`
ericp
Fri Mar 18, 2016 11:23 pm
Thank you, but I still get "v0.10.29" when I run "node -v".
Am I missing something?
asandford
Sat Mar 19, 2016 12:03 am
ericp wrote:How can I install a newer version of Node Js on the Raspberry Pi 3?
npm version: 1.4.21
pi@raspberrypi:~ $  node -v
v0.10.29
pi@raspberrypi:~ $  sudo su -
root@raspberrypi:~ # apt-get remove nodered -y
root@raspberrypi:~ # apt-get remove nodejs nodejs-legacy -y
root@raspberrypi:~ # apt-get remove npm  -y # if you installed npm
root@raspberrypi:~ # curl -sL https://deb.nodesource.com/setup_5.x | sudo bash -
root@raspberrypi:~# apt-get install nodejs -y
root@raspberrypi:~# node -v
v5.9.0
root@raspberrypi:~# npm -v
3.7.3
LewisCowles1986
Sat Mar 19, 2016 12:47 am
ericp wrote:Thank you, but I still get "v0.10.29" when I run "node -v".
try running
apt-get remove --purge node* npm*
LewisCowles1986
Sat Mar 19, 2016 12:52 am
The reason to apt-get remove is because you may have a version installed via package manager. Otherwise I'd suggest reading the documentation on node version manager (nvm) as it might be you did not run the command exactly as it was typed. In any case you should be up and running soon ;)
ericp
Sun Mar 20, 2016 1:56 pm
v0.10.29
v5.9.0
3.7.3
Thank you asandford that worked for me.
surbyte
Thu May 05, 2016 6:49 pm
The right sequence for me
v0.10.29
root@raspberrypi:~ # apt-get remove --purge node* npm*
v5.11.0
3.8.6
KLL
Fri May 06, 2016 1:52 pm
i just install on my new RPI 3
mkdir node
cd node
wget https://nodejs.org/dist/latest/node-v6.1.0-linux-armv7l.tar.gz
tar -xvf node-v6.1.0-linux-armv7l.tar.gz
cd node-v6.1.0-linux-armv7l
sudo cp -R * /usr/local/
sudo reboot
node -v
v6.1.0
npm -v
3.8.6
may i add here a question?
for MONGO i still do the
wget https://github.com/tjanson/mongodb-armhf-deb/releases/download/v2.1.1-1/mongodb_2.1.1_armhf.deb
sudo dpkg -i mongodb_2.1.1_armhf.deb   //error
sudo apt-get -f install                // does the libboost thing
( what gives a MongoDB shell version: 2.4.10 ) and then a
wget http://andyfelong.com/downloads/core_mongodb.tar.gz
wget http://andyfelong.com/downloads/tools_mongodb.tar.gz
tar xvf core_mongodb.tar.gz
tar xvf tools_mongodb.tar.gz
sudo strip mongo*
sudo chown root:root mongo*
sudo chmod 755 mongo*
sudo service mongodb stop
sudo mv mongo* /usr/bin
what gives a MongoDB shell version: 3.0.9
anybody knows a better way / to a newer version???
audstanley
Tue Dec 27, 2016 9:08 pm
To Install Latest version of NodeJs and the node-install utility to switch versions:
wget -O - https://raw.githubusercontent.com/audstanley/NodeJs-Raspberry-Pi/master/Install-Node.sh | sudo bash
node -v
This works with EVERY raspberry pi as well as Beaglebone.
Make sure you check out the source code:
https://github.com/audstanley/NodeJs-Raspberry-Pi
Smartguy01
Fri May 26, 2017 1:53 pm
This is awesome, thanks so much for sharing your script. This seemed to work fine for me - I have node v7.10.0 up and running properly.
Thanks again!
Fri May 26, 2017 11:07 pm
The best way I have found to install node.js is to use the Node Version Manager, nvm, as mentioned above.
Get and install nvm:
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.2/install.sh | bash
Use nvm to download and install the latest node.js version:
nvm install node
Job done.
Except, read the instructions for nvm here: https://github.com/creationix/nvm/blob/ ... all-script
When you want to upgrade node to a newer version, or downgrade sometimes, nvm can do that very easily.
KLL
Sat May 27, 2017 12:47 am
@Heater, is node-red still running?
Sat May 27, 2017 1:23 am
KLL,
...is node-red still running?
I'm not sure I understand your question. I never use node-red, neat though it is.
If you mean, "does installing node.js with nvm break node-red?" then I'm fairly confident it will not. nvm does not actually install anything to your "system", it puts everything in your user directory and arranges symlinks to the version of node you ask for.
I guessing though.
KLL
Sat May 27, 2017 1:28 am
pls test and confirm, i read "best methods" already at a other post and then had to reinstall raspbian
Sat May 27, 2017 1:36 am
KLL,
Sorry, no can do, I'm travelling, no Pi to hand till I get home in a month or so..
If you have something that works then stick with it.
I'm not sure why you had to re-install raspbian just to get node.js and node-red working again. Removing and re-installing those packages should have done the trick.
KLL
Sat May 27, 2017 1:51 am
i am ON THE ROAD too
https://goo.gl/maps/vTBQocVdcVv
will test at next system setup, thanks.
Sat May 27, 2017 8:47 am
Wow, looks much nicer than San Jose.
KLL
Tue Jun 06, 2017 2:32 pm
ok, i checked, node red still running ( sorry i doubted you )
? open new terminal?
pi@RPI0:~ $ nvm current
system
pi@RPI0:~ $ nvm --version
0.33.2
pi@RPI0:~ $ npm -v
bash: npm: command not found
pi@RPI0:~ $ node -v
v0.10.29
nvm install node
0.33.2
pi@RPI0:~ $ npm -v
5.0.0
pi@RPI0:~ $ node -v
v8.0.0
Tue Jun 06, 2017 3:03 pm
Great stuff.
I'd be inclined to remove that ancient node v0.10.29 just to avoid any confusion in the future.
$ sudo apt-get remove nodejs
Or what ever the Raspbian node.js packages is called.
asandford
Wed Jun 07, 2017 12:09 am
Heater wrote:Great stuff.
I posted over a year ago:
It still might be relevant as the version of Node-Red that shipped then required it.
There is a script that will update nodejs, NR and npm (for NR):
root@weatherpi:~# update-nodejs-and-nodered
Root user detected. Typically install as a normal user. No need for sudo.
Are you really sure you want to install as root ? (y/N) ? y
This script will remove any pre-installed versions of node.js and Node-RED
and replace them with node.js 6.x LTS (boron) and the latest Node-RED from Npm.
To do this it runs commands as root - please satisfy yourself that this will
not damage your Pi, or otherwise compromise your configuration.
Doing this may also be 'a bad thing' if you have installed lots of extra nodes.
Especially if they have any native binary component. Some nodes in your
~/.node-red directory will probably need to be re-installed afterwards, some
may need you to run npm update, and some may require you to run npm rebuild.
Are you really sure you want to do this ? (y/N) ? y
Running for user root at /root
This can take 20-30 minutes on a Pi 1 - please wait.
  Stop Node-RED                       ✔
  Remove old version of Node-RED      ✔
  Remove old version of node.js       -
  Update node.js LTS                  ✔   Node v6.10.3   Npm 3.10.10
  Clean npm cache                     ✔
  Install Node-RED core               ✔   0.16.2
  Install extra nodes                 ✔
  Install serialport node             ✔
  Npm rebuild existing nodes          ✔
  Add menu shortcut                   ✔
  Update systemd script               ✔
  Update update script                ✔
Any errors will be logged to   /var/log/nodered-install.log
HTH
KLL
Wed Jun 07, 2017 1:49 am
asandford wrote:There is a script that will update nodejs, NR and npm (for NR):
thanks, also works perfect without sudo..
pi@RPI0:/ $ nodejs -v
v6.10.3
pi@RPI0:/ $ npm -v
3.10.10
see file:
cat /usr/bin/update-nodejs-and-nodered
asandford
Wed Jun 07, 2017 2:19 am
Old habit, Unix admin from 2000, I do everything as root.
Wed Jun 07, 2017 2:52 am
Why not just:
$ npm install -g node-red
or
$ npm install node-red
As intended?
Same for installing node-serial port and other modules.
asandford
Wed Jun 07, 2017 11:50 pm
Heater wrote:Why not just:
or
As intended?
The devs at Node-Red suggest using the script they supplied to upgrade, so I guess that I am using what is intended to be used. Have a look here
To upgrade, run the following command as your normal user (typically pi):
Note - If the serialport nodes do not appear when you restart, please re-run the update command. If the update command does not run or is not found then use the bash command from above.
