Adrianfu
internet radio issues
Mon Feb 15, 2016 9:17 am
I have been trying to get the Simon Monk internet radio working but having an issue with the display. All I get is a screen of dots on the OLED. I have formatted the SD card numerous times and followed the instructions in MagPi issue 35 to the letter but no luck. I am using a Pi2 with Jessie installed with all updates.
The error I get is is apparently something to do with a font file. Picture is attached. Any help would be appreciated.
Adrian
topguy
Re: internet radio issues
Mon Feb 15, 2016 10:42 am
Looks like "fonts-freefont-ttf" package contains the file at least, check if that is installed.
https://packages.debian.org/jessie/all/ ... f/filelist
Adrianfu
Mon Feb 15, 2016 12:40 pm
All the fonts are there.
Adrian
topguy
Mon Feb 15, 2016 1:19 pm
Then you should look up the docs of ImageFont class and see if there are some settings for which directories it will search for fonts.
Or you could try to use full path if you know where the fonts are stored.
Adrianfu
Mon Feb 15, 2016 3:26 pm
I have managed to get the OLED to show the radio station and title but I had to change which font the display uses
From this .............................
# Setup Display
device = ssd1306(port=1, address=0x3C)
#small_font = ImageFont.truetype('FreeMono.ttf', 12)
#large_font = ImageFont.truetype('FreeMono.ttf', 24)
to this..............................
small_font = ImageFont.load_default()
large_font = ImageFont.load_default()
Although it works I would like to change the large font to something larger. Any pointers?
Adrian
Adrianfu
Tue Feb 16, 2016 4:13 am
Thanks for the help. I have finally resolved the problem with the fonts on my internet radio.
I changed the lines
to
#small_font = ImageFont.truetype('ssd1306/fonts/FreeMono.ttf', 12)
#large_font = ImageFont.truetype('ssd1306/fonnts/FreeMono.ttf', 24)
And all is good.
Sorry if these problems have been dealt with in the past but I am a newbie at these Pi doodads.
Adrian
drjam
Sat Dec 17, 2016 9:00 am
wanted to say thanks for this, it helped me :)
Couple of pi 3's, a pi 2 and an assortment of hardware.
your move brain.....your move
