lasersrl
Official drawing dimensions for the 7" touch screen display?
Tue Feb 02, 2016 1:21 pm
Hi! I've been looking for the official drawing dimensions of the official Raspberry 7" display, but without any success. Does anyone have the official measures for this product? Not only the external ones, but a complete document with all the drawing dimensions.
Please, can anyone help?
lasersrl
Re: Official drawing dimensions for the 7" touch screen disp
Thu Feb 04, 2016 7:17 am
Thanks! This is what I was looking for!
vdesmedt
Sat May 14, 2016 4:13 pm
Am I the only one not finding the radius of the rounded corner of the lens ?
jakeh12
Sat May 14, 2016 4:46 pm
vdesmedt wrote:Am I the only one not finding the radius of the rounded corner of the lens ?
Hi, I made couple covers. It appears to be radius close to 7 mm, but I just eyeballed it.
vdesmedt
Sun May 15, 2016 6:42 am
jakeh12 wrote:It appears to be radius close to 7 mm, but I just eyeballed it.
Thanks Jakeh12, I made the same measurement but it is comfortable to know you had some concrete successes with it ;)
Many thanks
src123
Mon Dec 05, 2016 11:57 am
am i the only one who is not getting the dimensions between the outer and the inner screw drills?
JimmyN
Mon Dec 05, 2016 2:42 pm
src123 wrote:am i the only one who is not getting the dimensions between the outer and the inner screw drills?
All the mounting hole dimensions are there, and can be referenced from the edge of the screen and/or the metal back pan. Like many drawings you have to do some math to obtain dimensions not specifically detailed on the drawing.
Example:
The M3.0 holes for mounting the display are 14.95 down from the top of the back pan (21.58 - 6.63 = 14.95) and the mounting holes for the RPi board (M2.5) are 20.8 down from the top of the back pan. So there is a difference of 5.85. Or you could go the other way and work from the edge of the glass. The display mounting holes are 21.58 down from the edge of the glass, the RPi mounting holes are 20.8 + 6.63 = 27.43 from the edge of the glass, giving you the same 5.85 difference between the two.
src123
Tue Dec 06, 2016 9:37 am
Thanks @jimmy.. it was silly of me.. I missed the 6.63 measurement! Thanks again
erichmeyn
Fri Sep 21, 2018 10:16 pm
aBUGSworstnightmare wrote:
Tue Dec 06, 2016 8:41 pm
STL file from spark fun https://cdn.sparkfun.com/3D_Models/prod ... 33/stl.zip
I loaded that stl while rebuilding the screen from the drawing and I noticed that it's bigger than the measurements given, as you can see from the overlap lines in the picture provided; has anyone confirmed that this build is accurate or if the drawing is not?
I have no issues printing it and comparing it to the rpi 7" screen I currently have; but to save time while building I'd prefer not to have to redesign what I'm building in post.
erichmeyn
Fri Sep 21, 2018 10:41 pm
The filet radius I came up with is 6.01211 mm, that is if the stl file listed that I compared it too is accurate which I'm starting to doubt now based on the measurements of my own screen on my retropi console
I measured 110.76mm on my screen which is what I'll use as a confirmation of my template and the official drawings accuracy.
Based on that, the filet radius is based on my measurements and I will confirm this with a quick print is 3.88mm
**EDIT**
I just printed a screen template and the STL provided I believe is designed to deal with shrinkage following a print job, but since I print nearly everything with some variation of Taulman Nylon this will not work; the drawing provided in previous posts is the correct sizing for sure.
Having said that; the corner filet I printed just now fits perfect, the filet radius is 7.017mm
If you use the drawing to build the screen or use it as a reference, the measurements provided should work perfectly.
After I finish building my new console, I'll post the correct to scale screen as an STL so you can use it for future projects.
garthwebb
Re: Official drawing dimensions for the 7" touch screen display?
Sat Mar 16, 2019 5:36 pm
I found an error in the dimensions provided in the doc posted at the beginning of this thread. The diagram for the back of the display seems to be flipped exactly 180 degrees. Given nobody else has mentioned this, I wonder if the design has changed?
From numbers in the doc, I used Illustrator to draw the back of the screen; the outer rounded frame, the inner square LCD boundary, and the four screen mounting holes (I stopped there). The doc clearly shows the ribbon cable exiting the bottom of the drawing.
The mounting holes seemed too low when compared to my physical screen however. So, I superimposed my Illustrator drawing over the photo of the back shown in the install guide (second step). This photo also clearly shows the ribbon cable exiting the bottom of the screen. When superimposed to align the drawing mounting holes with the photo's holes, the photo's LCD frame boundary does not align with my drawing's LCD boundary. When flipped 180 it matches exactly.
Has anyone else noticed this? Or am I crazy?
garthwebb
Sat Mar 16, 2019 5:45 pm
One other interesting note; the LCD screen's rectangular boundary is not centered within the outer frame, so orientation also makes a difference wrt alignment. However, it appears that this alignment is correct, and its just the mounting holes that are misaligned.
Return to “Official Foundation Display”
