PandaHero23
Mac OS 9 On Raspberry Pi?
Thu Jan 14, 2016 3:59 pm
I was wondering if this was possible, i own all of the original install disks and was wondering if putting all of the OS files on to the MicroSD Card would work. Basically, i want to run Mac OS 9 with out an emulation, any ideas?
Re: Mac OS 9 On Raspberry Pi?
Thu Jan 14, 2016 7:17 pm
PandaHero23 wrote:I was wondering if this was possible, i own all of the original install disks and was wondering if putting all of the OS files on to the MicroSD Card would work. Basically, i want to run Mac OS 9 with out an emulation, any ideas?
MAC OS9 requires a machine with a PPC CPU, the RPi has an ARM CPU
So no way even with emulation......
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
stderr
Thu Jan 14, 2016 7:26 pm
PandaHero23 wrote:Basically, i want to run Mac OS 9 with out an emulation, any ideas?
Look on Craigslist for an old Apple Mac. Apple is, however, notorious for not supporting things very long. I'm running 10.4 or 10.5 and most everything wants something like 10.7 or better. Contrast this with Microsoft and you see people still running programs for the IBM XT. The same issues are replaying themselves with iOS and Android. The lowest thing you can use seems to be an iPhone 4!
DavidS
Thu Feb 04, 2016 6:02 am
Not without any emulation.
That said it should be possible to write an absolute minimal Operating system, that provides the needed interfaces to support a framebuffer only port of SheepShaver, then rewrite the PowerPC JIT in SheepShaver to target the ARM CPU instead of the x86, and you should get decent performance (especially not having any multitasking OS in the way, under SheepShaver).
That said, I hope that you have a lot of time on your hands if you intend to tackle this task, and a good familiarity with ARM programming, bare metal Raspberry Pi programming, and PowerPC machine language will all be very needed skills.
RPi = Way for me to have fun and save power.
100% Off Grid.
Household TTL Electricity Usage = 1.4KW/h per day.
500W Solar System, produces 2.8KW/h per day average.
gio74
Wed Jun 28, 2017 9:08 am
Using Mac OS9 on raspi is super easy
just follow this great tutorial
https://www.novaspirit.com/2017/04/13/r ... pberry-pi/
Wed Jun 28, 2017 10:03 am
gio74 wrote:Using Mac OS9 on raspi is super easy
The Original Poster from 18 months ago wanted to run MAC OS9 natively without Emulation :shock:
adieu
Derksen42
Tue Nov 13, 2018 6:47 pm
Had a bit of fun mashing the Raspberry Pi logo with the Apple logo. For anyone that wants to incorporate it into their Pi builds. I have it in EPS, SVG formats as well, just message me and I'll get something to you.
code_exec
Sun Nov 25, 2018 7:01 am
You cannot run a PowerPC OS on Raspberry Pi natively, but can use qemu-system-ppc. Since Mac OS 9 is so old, it should run at about the same speed as Windows 95 running in QEMU. Overall speed depends on your Pi model.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
Return to “Other”
