reltek
How to create shortcut on the desktop?
Wed Jan 13, 2016 4:16 pm
On Raspbian, How do you create a shortcut on the desktop? I have a program that I wrote within a folder and I want a desktop shortcut for this program. I followed many tutorials online, but none helped so far. They all pretty much told me to create a empty text file and place the following lines in it. So, I did.
[Desktop Entry]
Type=MyProgram
Encoding=UTF-8
Name=MyProgram
Comment=MyProgram
Icon=/usr/MyProgram/MyProgram.ico
Exec=/usr/MyProgram/MyProgram
Terminal=false
Categories=Internet;
Then, they say to place this newly created file in the desktop folder. After doing that, I rebooted RasPI. Now, on the desktop I do see the icon for MyProgram but without that little black and white arrow in the corner to indicate that it is a shortcut. When I double click on the shortcut, MyProgram starts to run. However, my program is starting up as if its starting from the desktop not from within its own folder. I want to be able to click on a shortcut for my program which actually starts from within MyProgram folder. Could someone please help me or point me in the right direction.... Hopefully, this post is not too confusing... :)
reltek
Re: How to create shortcut on the desktop?
Wed Jan 13, 2016 9:18 pm
:D Solved it...
In addition what I have in the file, you also need to have a working folder. Basically the following line.
path=/home/pi/MyProgram/
Now it works like a real shortcut.
It really is strange no one seem to mention it anywhere about this. I accidentally found out while I was trying different things.
JacKAsterisK
Fri Feb 14, 2020 3:29 pm
That path entry worked, thanks! Also, I had to change the type to Application in my case.
Return to “Raspbian”
