therudy
Force deluge to use VPN on disconnect
Fri Jan 08, 2016 3:38 pm
Hi guys !
warning : i'm new user of linux ! :)
i have installed raspbian with openvpn (running good) and deluge (running good) for download torrent,
But i want to force deluge to use ONLY the ip of openvpn to download (If VPN disconnect, its stopping download),
and, i want to force my openvpn to auto-reconnect the vpn if the vpn is disconnected (if its not inclued in openvpn?)
actually i use in .sh : openvpn --script-security 2 --config /etc/openvpn/nameofvpn.ovpn (and it work fine on raspbian launch)
can you help me ? :)
I'm french,
thank you very much :)
tcraig37
Re: Force deluge to use VPN on disconnect
Sat Mar 16, 2019 5:35 pm
Did you have any luck with this?
Return to “Raspbian”
