Bosse_B
Power supply for multiple RPi units
Thu Nov 05, 2015 9:16 am
I have several RPi unit sitting on my desktop and each has a charger plug as power supply occupying one power wall outlet each.
Now I am getting annoyed about this situation and want to get a single multi-channel power supply/charger instead.
Is there any recommendation as to which product I should choose?
I see several on the market and they often cite an "intelligent sensing" of the device type connected to adjust the charging level.
But that is in my view not good for a Pi unit since the power connector just has the power lines connected, no intelligent communication channel available.
A reliable say 6-channel charging station capable of supplying up to 2A per channel would be fine.
Any experiences/advice here?
Bo Berglund
Sweden
Re: Power supply for multiple RPi units
Thu Nov 05, 2015 9:56 am
Bosse_B wrote:I have several RPi unit sitting on my desktop and each has a charger plug as power supply occupying one power wall outlet each.
http://www.ianker.com/Wall-Chargers/category-c78-s1
Retired disgracefully.....
......to a more gentile life !
fruit-uk
Thu Nov 05, 2015 10:56 am
I have an 8A PSU (supposedly medical grade cert IIRC) that outputs to DIN. I have several splitters plugged to this with DC connectors to power all my HA and network stuff
Bosse_B
Thu Nov 05, 2015 11:11 am
I'd rather have a supply that can sit on my desktop with multiple USB sockets for the power lines to the RPi units I have.
Don't want to wire up something non-standard....
Bo Berglund
Sweden
Bosse_B
Thu Nov 05, 2015 11:14 am
This company seems to have a range of products that might fit the bill.
However they tote the Power-IQ functionality to "adapt" the current limit to the device type connected.
I do not believe that the RPi has any reporting facility built into the Micro-USB power connector, so how does this work out?
Will the Anker unit simply switch to 500 mA feed, which is insufficient for any RPi unit or what will happen?
Bo Berglund
Sweden
Thu Nov 05, 2015 11:31 am
viewtopic.php?f=63&t=117029&p=796825
Searching the forum Anker Products get a far few mentions over the last few years.....
fruit-uk
Thu Nov 05, 2015 12:16 pm
fruitoftheloom wrote:Searching the forum Anker Products get a far few mentions over the last few years.....
I'm confused by that statement - and suspect a non-native English speaker may be too.
I think what you are implying is that they used to be considered very good with many mentions here but with fewer recent mentions they may not be considered that good any more?
Thu Nov 05, 2015 12:21 pm
I think that should have been "a fair few mentions", meaning "quite a lot". I've been very impressed with my Anker supply.
Thu Nov 05, 2015 1:11 pm
Yes quite so, unfortunately my keyboard can not type :roll:
fruit-uk
Thu Nov 05, 2015 1:13 pm
Thanks, I got completely the wrong impression then :)
Bosse_B
Thu Nov 05, 2015 1:35 pm
rpdom wrote: I think that should have been "a fair few mentions", meaning "quite a lot". I've been very impressed with my Anker supply.
What Anker type do you use, and how many RPi do you connect?
Bo Berglund
Sweden
Thu Nov 05, 2015 4:12 pm
Mine is one of the older 5-port models. At most, I've had three Pi's (one being a Pi2B), a hard disk and some speakers running off it. The Pi 2B has never indicated low power.
BMS Doug
Thu Nov 05, 2015 4:18 pm
I've got 3 of the 5 port models, two of them have lost some output channels (I'm guessing that some internal fuses have blown) I know the cause and I was very cross with her.
Even where some channels have ceased to power an output the remaining channels still work.
Doug.
Bosse_B
Thu Nov 05, 2015 4:54 pm
Fine, then I will start looking for a Swedish place to buy it from. :) :D
Bo Berglund
Sweden
stderr
Thu Nov 05, 2015 5:29 pm
Bosse_B wrote:I see several on the market and they often cite an "intelligent sensing" of the device type connected to adjust the charging level.
What does that mean in the context of something that doesn't have a battery?
I know you said you didn't want something non-standard, but using a reasonable amount of 5v from the power supply of a computer that isn't turned off but rarely can work. This is especially true if you find out you are using a mainboard that doesn't itself use a lot of 5v because it's doing its own conversion to the very low voltages from 12v.
Bosse_B
Thu Nov 05, 2015 6:32 pm
Exactly! That is why I am asking. If it is indeed trying to manage the charging then it will stop if it detects a battery malfunction. I don't want that kind. OTOH USB chargers are basically supplying power to devices that are managing their charging process internally so in this context what it could do is only setting a current limit value based on some sensing. Which I don't want....
Well, I don't fancy building my own distribution panel with a number of USB sockets soldered together if I can buy a ready-made unit that fits the needs...
I have found that Deltaco markets a unit (USB-AC115) that has 10 connectors, 5 of which are high-current (2.4A) whereas the remaining ones are 1A each. But all 10 cannot be used simultaneously so the unit is 5x2.4A OR 10x1A depending on a switch setting. Its form factor is not very good for my needs, though. I would like a vertical stack rather than a flat surface unit with connectors spread out over the top surface.
Bo Berglund
Sweden
stderr
Fri Nov 06, 2015 2:55 am
Bosse_B wrote:Well, I don't fancy building my own distribution panel with a number of USB sockets soldered together
If I was running off the main box's power supply, after making sure I was well within spec, I'd probably just use splitters and Molex power to microUSB cables. Of course I'd have to find such a thing, but it seems like someone should be selling them out of China or something.
Which is really a common issue, certainly with the wall wart types I've seen. Kind of the point is to reduce the amount of stuff plugged into the wall, so when it doesn't really let you use a lot of full power USB ports, you aren't gaining much, I think.
Aydan
Fri Nov 06, 2015 11:17 am
I think you misunderstand this limitation. This means you cannot use all ports at the same time with rated current. You'll have to find out how much current can be supplied in total. Since the pi only uses .7 amps that means you can connect 4 Pi's and only have the equivalent of one high-current port used. Of course if you start connecting USB devices then you'll have to recalculate the total current draw.
Regards
Aydan
fruit-uk
Fri Nov 06, 2015 11:25 am
stderr wrote:If I was running off the main box's power supply, after making sure I was well within spec, I'd probably just use splitters and Molex power to microUSB cables.
I use this sort of thing http://cpc.farnell.com/powerpax/c3704/l ... dp/PW03123 but I'm sure they won't suit everyone.
Bosse_B
Fri Nov 06, 2015 12:12 pm
fruit-uk wrote:I use this sort of thing http://cpc.farnell.com/powerpax/c3704/l ... dp/PW03123 but I'm sure they won't suit everyone.
Right, there is no sign of any USB connector in that cable...
Neither the A plug nor the MicroUSB that plugs into the Pi....
Bo Berglund
Sweden
fruit-uk
Fri Nov 06, 2015 1:04 pm
You are correct.
My equipment requires a variety of connectors. I make up leads with a DC connector at one end and whatever I need at the other
I understand this would not suit you for the reasons you gave earlier, however my post was in response to stderr's
Aydan
Mon Nov 09, 2015 3:10 pm
I just found this on amazon.de
6x2.5A USB power supply
Regards
Aydan
electronicman
Tue Nov 17, 2015 12:05 am
I have 4 Pi's running from 4 USB connectors that are fed from an old 35 Volt DC printer power supply connected though a DC to DC converter that puts out 5 Volts DC for the Pi's. Works very well, but it takes up some room on my work bench. One day I will try to fit into a smaller space like a black box to look more professional.
David
