Re: Windows 10 Core IoT FAQ (Unofficial)
Thu Mar 03, 2016 8:55 am
mb2004 wrote:Is it possible to use ready (prepared) image for Raspberry Pi 3 Windows 10. Where can I download ?
You know you have to have windows 10 OS to prepare Raspberry Pi 3 Win10 image.
You will need the Insider Preview Windows 10 IoT Core Download for the RPi 3B, therefore you will need a Microsoft Account:
http://ms-iot.github.io/content/en-US/Downloads.htm
adieu
My other Computer is an Asus CS10 ChromeBit
mb2004
Thu Mar 03, 2016 9:34 am
Yes I know but I do not have Win 10 operating system. I'm looking direct image file to write sd card. Is it possible ?
Thu Mar 03, 2016 9:58 am
Windows 10 IoT Core relies on Windows 10 Desktop for deploying via Visual Studio.
If you RPi has an Internet connection via Ethernet an install is available via the NOOBS Installer
http://ms-iot.github.io/content/en-US/win10/Noobs.htm
https://www.raspberrypi.org/downloads/noobs
adieu
ms_koster
Sat Mar 05, 2016 11:15 am
ricl wrote:36. Is the Official Raspberry 800*480 screen supported by Windows 10 Core IoT
Microsoft added support for the screen in Insider Preview 10556
viewtopic.php?f=105&t=123420&p=831416#p831416
No Touch yet though :-(
Touch available in Insider Preview 10.0.14262.1000 (Feb 2016), maybe update this FAQ?
Martin
lesvaches
Tue Apr 26, 2016 3:00 pm
22. How do I view the screen on the Pi remotely (RDP):
Windows IoT Remote Client:
https://www.microsoft.com/store/apps/9nblggh5mnxz
ajayhakkumar
Thu Sep 22, 2016 4:14 am
Does Windows 10 Core IoT support MATLAB Runtime Compiler
mickel2009
Re: Windows 10 основных IoT FAQ (неофициальный)
Sun Oct 30, 2016 11:18 am
I can't install windows 10 iot core on raspberry pi 2. I've tried almost all methods. Picked up a microSD 8 GB class 6 explay. Installed the noobs from under it installed rasbian. Everything works. I Install windows RTM iot 10-black screen!. During installation it says that Flash drive does not match the speed. Installed WIndows 10 use windows 10 iot iot core dashboard - show multicolored square. Does this mean that the microSD card is not compatible?
Sun Oct 30, 2016 11:24 am
mickel2009 wrote:I can't install windows 10 iot core on raspberry pi 2. I've tried almost all methods. Picked up a microSD 8 GB class 6 explay. Installed the noobs from under it installed rasbian. Everything works. I Install windows RTM iot 10-black screen!. During installation it says that Flash drive does not match the speed. Installed WIndows 10 use windows 10 iot iot core dashboard - show multicolored square. Does this mean that the microSD card is not compatible?
You need a Class 10 Card ;)
adieu
mahjongg
Sun Oct 30, 2016 11:37 am
you also need a better power supply, indicated by the rainbow square that warns that you underpower the PI. try a different microUSB cable, a shorter thicker one. Or a new PSU.
Return to “Windows 10 for IoT”
