CCoates
Pi 2 & Synology box
Sat Jul 04, 2015 9:53 am
Ive been trying all morning to get the Nas box mounted using all sorts of dffering guides
Is there an easy way to do this??
CCoates
Re: Pi 2 & Synology box
Sat Jul 04, 2015 9:59 am
The Nas box is a Synology DS112j
drgeoff
Sat Jul 04, 2015 7:44 pm
What OS on the RPi?
Synology NASs support NFS which is the native network file system in Linux. You do have to enable it on the Synology.
CCoates
Sat Jul 04, 2015 9:38 pm
Raspbian install from Noobs, I have created a mounting folder. And followed a tutorial but no luck
CCoates
Sun Jul 05, 2015 7:47 pm
drgeoff wrote:What OS on the RPi?
I enabled this, all the guides mention it
morgad
Sun Jul 05, 2015 8:39 pm
fwiw I have the following line in my /etc/fstab
192.168.1.3:/volume1/dp /home/pi/dp nfs user,nfsvers=4,rw,auto,hard,intr,rsize=8192,wsize=8192,_netdev 0 0
which gives directory lines in the following format
-rwxrwxrwx 1 4294967294 4294967294 367041766 Jan 1 2012 discoveries-prep-orig.zip
drwxrwxrwx 926 4294967294 4294967294 20480 Jun 4 20:10 discoveries-scan
drwxrwxrwx 3 4294967294 4294967294 4096 Jun 20 14:04 Downloads
drwxrwx--- 11 4294967294 4294967294 4096 Jun 22 19:19 Dropbox
where the 4294967294 should read 'pi', no ideas if it works as have not used nfs in anger - just the samba connction to my Windows box
@drgeoff - why do you think Synology supports nfs *properly*? - I saw a note somewhere that to get uid/guid working correctly you had to have a working kerberos server
my 414slim also has problems with -
* ssh (can log in as root, but not a normal user)
* ntp (their config file is rubbish - it ignores any servers you have on your LAN, and they also violate the terms of use for the ntp pool)
* dropbox (sometimes completly ignores files if more than one put at remote end at same time, only fixed by unlinking and re-linking
and these are just the bits I have used so far :(
best regards
Dave
drgeoff
Sun Jul 05, 2015 10:12 pm
morgad wrote:
@drgeoff - why do you think Synology supports nfs *properly*? - I saw a note somewhere that to get uid/guid working correctly you had to have a working kerberos server.
Show me the word "properly" in what I wrote. :)
The Synology NAS units which run DSM are Linux boxes.
http://raspberrypi.stackexchange.com/qu ... nology-nas
CCoates
Wed Jul 08, 2015 9:09 pm
UPDATE:
I have now managed to mount the drive.
However it is forgotten after each reboot so each time I am having to re run the folloing code in LX Terminal
sudo mount -t nfs 192.168.0.17:/volume1/kodi /mnt/kodi
Is there anyway round this?
myoung008
Wed Jul 08, 2015 9:59 pm
CCoates wrote:sudo mount -t nfs 192.168.0.17:/volume1/kodi /mnt/kodi
Add the following to your /etc/fstab:
192.168.0.17:/volume1/kodi /mnt/kodi nfs defaults 0 0
That may or may not be what you're actually looking for, but it is equivalent to your mount command.
