FerociousRPi
Raspbian GUI login prompt?
Tue Jun 30, 2015 10:18 pm
Hello all,
Is there any way to get Raspbian GUI login prompt/window? Needing something similar to screenshot.
https://ubuntu-mate.org/gallery/Screens ... IGHTDM.png
Thx
klricks
Re: Raspbian GUI login prompt?
Wed Jul 01, 2015 1:09 pm
  • 1. First if not already done, you must use sudo raspi-config and set boot to desktop then reboot.
    2. Open a LXterminal then do:
    sudo leafpad /etc/lightdm/lightdm.conf
    3. Find this line: (approximately line 78 in file)
    autologin-user=pi
    4. Comment out (disable) that line by inserting a # like this:
    #autologin-user=pi
    5. Save and exit then reboot.
Note: If you ever go back and do set to desktop with raspi-config again, (Step 1), then the changes to lightdm.conf will revert back to the default (no login). If so simply redo the edit again - (Steps 2-5).
FerociousRPi
Wed Jul 01, 2015 8:50 pm
Thank you so much! This worked (see screenshot) and also added a new user account w/o sudo.
https://www.raspberrypi.org/documentati ... e/users.md
1.- Is there a way to set the default environment to Xsession only option? (see screenshot)
2.- Also on the screenshot is there a way to change the missing icon pic above the word raspberrypi? (see screenshot)
3.- Was wondering if there is any way to restrict what programs users have access too?
AndyD
Wed Jul 01, 2015 9:04 pm
FerociousRPi wrote:2.- Also on the screenshot is there a way to change the missing icon pic above the word raspberrypi? (see screenshot)
See my post in this thread.
haridsv
Tue Sep 15, 2015 2:37 pm
    autologin-user=pi
    #autologin-user=pi
Thank you so much! For some reason, I had to search for a quite a few keywords before finding this simple solution.
Return to “Raspbian”
