alvaro36horas
How many i2c buses can I use with new RaspberryPi 2 B model?
Tue Jun 16, 2015 2:54 pm
I am not sure if the second i2C bus (pin 27 BCM0: ID_SD and pin 28 BCM1: ID_SC) is only for use with i2c EEPROM for configuration purposes.
Thank you.
joan
Re: How many i2c buses can I use with new RaspberryPi 2 B mo
Tue Jun 16, 2015 3:37 pm
It is not intended for general use. Nothing prevents you from using it at the moment though. I don't know if such use will be compromised by a future update
6by9
Tue Jun 16, 2015 7:57 pm
There's no real reason why it can't be used as long as you don't want to use the camera module - that uses the I2C-0 peripheral direct from the GPU, and there is no arbitration between the two processors.
Memory says that there are no pullups fitted to those pins, so you may need to fit your own.
alvaro36horas
Wed Jun 17, 2015 8:55 am
I understand 6by9. ;)
Thanks 6by9 and Joan, yours answers were very useful.
Best regards,
Álvaro
Richard-TX
Sat Jun 27, 2015 5:42 am
I use both buses all the time. Works great.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
joan
Sat Jun 27, 2015 8:05 am
Of course it is also possiible to bit-bang I2C on any pair of spare gpios.
Bit-bang does allow for repeated starts and clock stretching.
My offering.
