Krassegrand
JavaScript
Sat May 23, 2015 5:30 am
I am trying to watch a TV channel but I get the message
"To watch this program You need to enable JavaScript. Find out how.
If I recall right from earlier there is something else then Java for Linux, am I right?
Jörgen
joan
Re: JavaScript
Sat May 23, 2015 5:36 am
JavaScript is not Java. Your browser should have an option to allow JavaScript programs to run. Which browser are you using?
Krassegrand
Re: JavaScript
Sat May 23, 2015 5:55 am
Ok!
How is it done in Kiosk for Raspbian?
Jörgen
gkreidl
Re: JavaScript
Sat May 23, 2015 6:05 am
Krassegrand wrote:Ok!
Jörgen
There's an icon in the toolbar to switch JavaScript on and off.
You can also configure kweb(3) to enable it when it starts.
Minimal Kiosk Browser (kweb)
Krassegrand
Re: JavaScript
Sat May 23, 2015 6:13 am
I have chosen Configuration in the tool bar and enabled javaScript but I still get the same message! (To watch this program You need to enable JavaScript. Find out how.)
gkreidl wrote:You can also configure kweb(3) to enable it when it starts.
kweb(3)?
Is that done in the terminal?
It would be nice to have it starting by it self.
Jörgen
gkreidl
Re: JavaScript
Sat May 23, 2015 6:16 am
Krassegrand wrote:I have chosen Configuration in the tool bar and enabled javaScript but I still get the same message! (To watch this program You need to enable JavaScript. Find out how.)
kweb(3)?
Jörgen
No. On the configuration page (or with command line arguments if starting from a script, for example).
Krassegrand
Re: JavaScript
Sat May 23, 2015 6:23 am
Sorry!
I saw the JavaScript button now!
It was to simple for me to understand! ;)
Thank You!
Now I just need to get the VPN working!
Jörgen
Krassegrand
Re: JavaScript
Sat May 23, 2015 6:38 am
By the way, I still cant work out how to use the bookmarks in Kiosk!
Jörgen
gkreidl
Re: JavaScript
Sat May 23, 2015 7:00 am
Krassegrand wrote:By the way, I still cant work out how to use the bookmarks in Kiosk!
Jörgen
Manual, page 25.
Krassegrand
Re: JavaScript
Sat May 23, 2015 9:08 am
Jörgen
Manual, page 25.
:D ;)
Thank You!
