solar3000
/etc/network/interfaces changed,weird 2 LAN IPs instead of 1
Fri May 15, 2015 3:40 pm
I copied some of the old 'interfaces' parameters like address, netmask, and gateway.
It seems to work, but hostname -I says I have two IPs.
I only have a ethernet connected. No wifi.
What's the proper configuration for static IP for just eth0 now?
Antikythera
MarkHaysHarris777
Re: /etc/network/interfaces has changed
Fri May 15, 2015 4:09 pm
solar3000 wrote:I copied some of the old 'interfaces' parameters like address, netmask, and gateway.
I'm not sure what you're asking. Normally, you will have at least two IP addresses: 1) your loop back address, and 2) your network address. Typically your loop back address (ipv4) is going to be 127.0.0.1 and you network address will be 192.168.xxx.xxx depending on your home router, dhcp, etc.
If you're using ipv6 things are a little different... and often ipv6 loop backs will be configured preparing for the time when ipv6 is the standard everywhere (still not there yet).
There is no 'proper' static configuration for ip/ it depends on whether you're using ipv4 or ipv6, whether you get your static address from dhcp (yes, that's possible) or whether you hard-code it (not a good idea, but folks still do that) and how your router's subnet is configured... some use 192.168.1.xxx some use 192.168.0.xxx just depends. Some folks use the reserved addresses in the 10.xxx.xxx.xxx range too.
Do some readng.
marcus
:ugeek:
hippy
Fri May 15, 2015 4:41 pm
There does seem to be something odd going on. I also have just a wired connection, IPV4, no Wi-Fi, and for me -
hostname -i gives 127.0.1.1
hostname -I gives 198.162.0.203
I'm not sure why it's 127.0.1.1 rather than 127.0.0.1 but otherwise both IP addresses are correct ( loop-back / DHCP assigned ). hostname -h suggests -I should be showing both but I don't know. It does however suggest that neither of the OP's addresses would be the loop-back address, unless for some reason that is appearing for the OP but not for me.
My /etc/network/interface file shows -
iface eth0 inet manual
Where I would have expected dhcp ( or static ) rather than manual. But I am seemingly getting an IP address via DHCP. That suggests something else beyond /etc/network/interfaces is affecting things.
When I changed that to a static , rebooted, then -
hostname -I gives 192.168.99.99 192.168.0.203
So now I have two IP addresses just as the OP described, a manual and a DHCP, and it does seem something beyond /etc/network/interfaces is involved. I'll admit that I could well have edited something else which I have now forgotten about which enables DHCP but everything I've read suggests the settings are only controlled by the interfaces file and am not sure where else to look.
solar3000
Fri May 15, 2015 6:41 pm
in the new 2015-05-05 raspbian look in /etc/network/
you'll see interfaces then theres interfaces.dpkg-old
the 'old' is what's been there all along.
the 'interfaces' config has changed.
The format is different. No one seems to notice.
Antikythera
MarkHaysHarris777
Fri May 15, 2015 6:49 pm
What does ifconfig show?
sudo ifconfig
marcus
:ugeek:
hippy
Fri May 15, 2015 7:15 pm
MarkHaysHarris777 wrote:What does ifconfig show?
For me, with "iface eth0 inet manual" and getting its IP address via DHCP ...
eth0      Link encap:Ethernet  HWaddr b8:27:eb:b6:78:11
          inet addr:192.168.0.203  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2281 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1116 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:115191 (112.4 KiB)  TX bytes:101193 (98.8 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:82 errors:0 dropped:0 overruns:0 frame:0
          TX packets:82 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:6552 (6.3 KiB)  TX bytes:6552 (6.3 KiB)
With "iface eth0 inet static" ...
          inet addr:198.162.99.99  Bcast:198.162.99.255  Mask:255.255.255.0
          RX packets:2714 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1386 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:136474 (133.2 KiB)  TX bytes:123923 (121.0 KiB)
          RX packets:84 errors:0 dropped:0 overruns:0 frame:0
          TX packets:84 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6652 (6.4 KiB)  TX bytes:6652 (6.4 KiB)
"hostname -I" shows ...
"ip a" shows ...
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
    link/ether b8:27:eb:b6:78:11 brd ff:ff:ff:ff:ff:ff
    inet 192.168.99.99/24 brd 192.168.99.255 scope global eth0
    inet 192.168.0.203/24 brd 192.168.0.255 scope global eth0
"netstat -nr" shows ...
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG        0 0          0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U         0 0          0 eth0
192.168.99.0    0.0.0.0         255.255.255.0   U         0 0          0 eth0
spl23
Fri May 15, 2015 7:44 pm
With the new network mods, DHCP is taken care of by a new package called dhcpcd. In order for this to work, the iface lines in /etc/network/interfaces need to be "manual" rather than "dhcp". This is why the file has changed, and why we've backed it up in case you want to go back, in which case you will need to uninstall raspberrypi-net-mods.
hippy
Fri May 15, 2015 8:24 pm
spl23 wrote:With the new network mods, DHCP is taken care of by a new package called dhcpcd. In order for this to work, the iface lines in /etc/network/interfaces need to be "manual" rather than "dhcp". This is why the file has changed, and why we've backed it up in case you want to go back, in which case you will need to uninstall raspberrypi-net-mods.
That explains it. Many thanks.
With raspberrypi-net-mods described in the middle of "Another raspbian desktop user interface update" I thought it only affected the desktop interface side of things". Turning the TV on and re-booting shows dhcpcd doing its stuff right there -
dhcpcd[2032] : eth0 : rebinding lease of ...
So, to have only a static address, it's either enter it via the new network GUI or use the -S option as described here - http://roy.marples.name/man/html8/dhcpcd.html
Going the GUI route seems to have worked for me, got just the static address specified ( and the other static address specified in /etc/network/interfaces ), but did have to re-boot after changing the setting to get it to take effect. Using Apply wasn't enough.
Also, after re-booting the GUI icon is stuck on "eth0: Link is up, configuring".
solar3000
Fri May 15, 2015 9:05 pm
Thanks from me too.
OK so from now on the proper way to configure my eth0 is....
The old way is to /etc/network/interfaces.
The new is?
Antikythera
spl23
Sat May 16, 2015 2:52 pm
As hippy says, either use the GUI in the desktop, or modify the Ethernet lines in /etc/network/interfaces as before if you want a static address.
MrEngman
Sat May 16, 2015 3:05 pm
Really? I just thought it looked a real mess so replaced it with what I usually use and had no problems with eth or wifi not working. And what is raspberrypi-net-mods? Where is there documentation on the new network set up if there is any.
My Pi A running 2015-05-05 /etc/network/interfaces is
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet dhcp
And I presume raspberrypi-net-mods is still installed as I haven't a clue what it is or why it is needed or not. Why is it necessary to go playing with the configuration when it worked perfectly well previously. Just going to make it doubly confusing for people setting up the networks, and don't say use X.
I guess if it ain't broke, fix it so it is.
MrEngman
solar3000
Mon May 18, 2015 3:43 pm
I forgot to mention. Adding an entry to /etc/network/interfaces creates one IP.
The new 2015 05 05 's setup creates its own ip. so that looks like why I got two IPs when I typed hostname -I. No no one seems to know this. and it looks like no one knows how to set up a static IP in the new system either.
Antikythera
hippy
Mon May 18, 2015 5:19 pm
solar3000 wrote:I forgot to mention. Adding an entry to /etc/network/interfaces creates one IP.
The new 2015 05 05 's setup creates its own ip. so that looks like why I got two IPs when I typed hostname -I. No no one seems to know this and it looks like no one knows how to set up a static IP in the new system either.
Using the GUI and specifying an IP address ( with /etc/network/interfaces set to "manual" ) gave me just a single static IP, though not entirely without other problems as described above.
solar3000
Mon May 18, 2015 5:42 pm
guess I'll just have to accept this for now.
I'll try again later.
Antikythera
ben2202
Thu May 21, 2015 1:07 pm
See my answer in this post : viewtopic.php?t=110557&p=762332
Maybe the solution is to stay in manual (not static) and editing the /etc/dhcpcd.conf to add the reservation at this end.
Regards,
Ben
solar3000
Thu May 21, 2015 5:22 pm
ben, I just saw your answer.
I also just discovered the dhcpcd.conf file. I grep -ir my ip that was set using the gui from the systray and there it is. so now I guess I should just leave the /etc/network/interface file alone and just use the /etc/dhcpcd.conf file alone. I just edited the last few lines.
Antikythera
koudstaald
Tue Jun 02, 2015 4:11 am
This issue is also discussed in viewtopic.php?f=66&t=111887
Creating a static IP the usual way in /etc/network/interfaces does indeed give the pi a static IP but the dhcpcd also collects a IP from my dhcp server. The pi has two IP addresses one static and one dhcp.
You suggest to use the -S option, but I cannot figure out where to implement this option. Does not seem to be a place to do so in the dhcpcd.conf file.
Any suggestion?
koudstaald
Tue Jun 02, 2015 5:54 am
I finally decided to give up configuring dhcpcd for static ip (unable to figure out how to configure dhcpcd with static IP and not end up with two IP addresses - one static and on dhcp).
However, rather than removing raspberrypi-net-mods I decided to remove the dhcpcd service with the following command line:
sudo update-rc.d -f dhcpcd remove
This will not boot dhcpcd at start up and all the settings from the /etc/network/interfaces are being properly implemented.
To reinstate the dhcpcd service use:
sudo update-rc.d dhcpcd defaults
Although I do not use WIFI and the GUI, I now have the option the enable and disable the dhcpcd service without installing raspberrypi-net-mods
MJneer
Mon Aug 17, 2015 7:57 pm
Thanks for figuring this one out.
Unfortunately because of the title of this thread it is really hard to find it for people by googling.
Is it possible to change the title of this thread or maybe tag it somehow?
Most people will be looking for a solution to the inevitable consequence of the update, that is:
My Raspi 2 has two IPs
Fix double IP on Raspberry PI 2
No internet access after changing /etc/network/interfaces
so they end up with : viewtopic.php?t=110557&p=762332 (where they will not find a solution btw.)
Most galls are confused since it works for some (pre-update people who didn't care to run $ sudo-apt get update , for some time) and to those who did, and got their shiny new network update that makes the dhcp invincible.
I understand the intention of the rapberrypi fundation to have people learn Linux and leave the old networking stuff for those who want to revert, but that's a bit far going. It also makes those more knowledgeable scratch their head as to why the update is executed like this as far as I can see... Last time I checked good programming practice says you should not repeat code or functionality(?)
Hope this thread will become more visible from search engines with this post alone.
Greetings
xelius
Wed Sep 02, 2015 10:26 pm
I got this solved by editing /etc/network/interfaces as usual and added the line below to /etc/dhcpcd.conf
denyinterfaces eth0
more details about dhcpcd.conf: http://roy.marples.name/man/html5/dhcpcd.conf.html
bogavante
Tue Sep 08, 2015 9:23 pm
I blindly followed @koudstaald's solution in this thread and I executed this on my headless Pi2 w latest Raspbian which was having 2 ip address(1 static + 1 dhcp):
It seems like on my ignorance, I removed something that was crucial for the Pi2 to be recognized in the network, cause it has disappeared from it.
What have I done? Is there any way I can re-gain ssh access or am I out of luck?
Many thanks.
Higgs
Fri Sep 18, 2015 5:26 pm
Yoly Moley.........
Just getting around to trying a wifi on my Pi2 and have been going around in circles until by chance landing on this thread.
There are so many old posts about using "static" or "dhcp" in the interfaces file that I have been using those references to troubleshoot without knowing that they no longer apply (they just kept killing the Pi network connection as I went through the different suggestions).
So now I know that "static" and "dhcp" are no longer used and to leave the param as "manual". geez......
Still have a gateway that is showing up as "*", but at least dhclient run at a terminal fixes that.
There really needs to be a big bulletin board that has changes to software functionality prominently displayed in a big font that says "START HERE BEFORE LOOKING FOR POSTS TO FIX PROBLEMS!"
Edit:
Having discovered these changes in /etc/network/interfaces it has taken me only a few more minutes of trial-and-error to set a static IP for my wireless by ADDING THE CHANGES IN /etc/dhcpcd.conf rather than hacking away in /etc/network/interfaces and just breaking things without knowing why......
And it now has the proper gateway on bootup.
dmatzen
Fri Oct 02, 2015 7:29 pm
For me the simple solution turned out to be adding the line in /etc/dhcpd.conf to exclude the interface.
Thanks to xelius!
by xelius » Wed Sep 02, 2015 10:26 pm
CODE: SELECT ALL
denyinterfaces eth0
paulv
Tue Oct 06, 2015 8:51 am
I also struggled a bit to get things right with Jessie, but after some cursing (why change it without a proper warning or how to), I am actually liking the new situation.
I modified my /etc/network/interfaces back to the original state:
auto lo
auto eth0
allow-hotplug eth0
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
Note the "manual" entries, no "dhcp"!
I modified /etc/wpa_supplicant/wpa_supplicant.conf to only have the ssid and psk information and commented everything else out.
update_config=1
network={
   ssid="xxxx"
   psk="yyyy"
#   scan_ssid=1
#   proto=WPA2          # can be RSN (for WPA2) or WPA (for WPA1)
#   key_mgmt=WPA-PSK    # can be WPA-PSK or WPA_EAP (for enterprise networks)
#   pairwise=CCMP TKIP  # can be CCMP( for WPA2) or TKIP (for WPA1), or both
#   auth_alg=OPEN       # can be OPEN, LEAP and SHARED
#   group=CCMP TKIP
#   priority=1
If you also have multiple access points (home, work, school), you now only need to change this file and add more network sections (with different names) here. If needed, you can reactivate the scan and priority options.
I have not tried this, but if you want to use both wlan0 and wlan1, I understand you need to use two different wpa.conf files. Look at wpa_supplicant(8).
Because you need sudo to access this file, as before, your network access information is more protected then having it in the "public" /etc/network/interfaces file.
I then added this at the very end of the "new" /etc/dhcpcd.conf file:
# Static IP configuration
interface eth0
static ip_address=192.168.100.21/24
static routers=192.168.100.1
static domain_name_servers=8.8.8.8 8.8.4.4
interface wlan0
static ip_address=192.168.100.20/24
[Edited] Note that every interface section is all by itself. Settings are not shared, so you need to add the information for every interface separately!
It says this in the manual:
interface Subsequent options are only parsed for this interface.
With this setup, I can switch between LAN and/or WLAN, and have either one or both active depending on the LAN cable plugged in, or the WIFI dongle plugged in, or both.
With these settings, you will now only have the above IP addresses active (depending on cable and/or dongle) and there is no gost IP anymore.
Like I said, after some cursing, I believe it's better and more simple now. I hope this helps others too.
Paul
coding
Thu Oct 08, 2015 10:39 pm
Hey, I'm sorry but... I don't understand all those undocumented changes. I believe all tutorials all over the Internet about how to properly configure /etc/network/interfaces are now outdated and useless. And without a good tutorial, I think it's too complicated for average users to create a working configuration without having two IPs and such. I also have two IPs now since I reinstalled Raspbian, and I don't know what to do now because nobody updated his tutorial yet. :(
