mjshanbom
Games not working
Thu Mar 26, 2015 2:27 pm
I was surfing the internet. when i tried leaving and opening up a game nothing happened. My games will not open, What should i do.
Do not say play less games.
DirkS
Re: Games not working
Thu Mar 26, 2015 6:37 pm
Which game? If it's an online game using for example flash then that's to be expected.
mjshanbom
Thu Mar 26, 2015 6:47 pm
Anything in the games folder on the desktop.
Python games and minecraft
mjshanbom
Fri Mar 27, 2015 2:34 pm
mjshanbom wrote:I was surfing the internet. when i tried leaving and opening up a game nothing happened. My games will not open, What should i do.
Help
obcd
Fri Mar 27, 2015 3:50 pm
Try to launch the games from within a terminal window and see what output you get.
If it's not starting, I would expect an error message on the terminal screen.
You really aren't telling much about your setup, so it's hard to give more accurate help.
mjshanbom
Fri Mar 27, 2015 3:58 pm
Can you give me the code to open a sample game
My setup is basically in a normal xsession trying to open the games.
I do not have anything downloaded but chromium
obcd
Fri Mar 27, 2015 4:08 pm
"python games" icon launches the following command:
sh -c $HOME/python_games/launcher.sh
so you can open an LXTerminal session and type that line.
if you "for instance" don't have a python_games folder in your home folder, it should tell you.
mjshanbom
Fri Mar 27, 2015 4:14 pm
It is still not launching how do I create the needed directory
obcd
Fri Mar 27, 2015 5:05 pm
What output do you see in LXTerminal when you run the command?
mjshanbom
Fri Mar 27, 2015 8:49 pm
None I try doing it and the terminal says no such directory
DirkS
Fri Mar 27, 2015 8:54 pm
Which distro did you install?
Where did you get it from?
mjshanbom
Fri Mar 27, 2015 11:10 pm
What does that mean
mjshanbom
Wed May 06, 2015 10:11 pm
Any more help
kusti8
Wed May 06, 2015 10:13 pm
It means what Operating System did you install and did you use the .img file or NOOBS?
mjshanbom
Wed May 06, 2015 10:17 pm
Raspbian and noobs
