ImmerStudent
Piface2 setup - no spi_bcm2708 (solved)
Wed Mar 11, 2015 1:32 am
Hi, I'm trying to set to PiFace Digital 2. I've followed all the instructions, enabled SPI using raspi-config, rebooted, commented out SPI_BCM2708 in the blacklist and run spidev setup. sudo modprobe spi-bcm2708 returns 'no such file or device' and spidev0.0 is not in dev. Therefore blink.py fails.
Any suggestions please?
bulletmark
Re: Piface2 setup - no spi_bcm2708
Thu Mar 12, 2015 10:18 pm
Since no-one has answered, you could try my installer:
sudo apt-get install python-pip
sudo pip install pifaceio
sudo install-spidev.sh
ImmerStudent
Fri Mar 13, 2015 3:54 am
Thanks, I executed the 3 commands successfully, but I still get 'no such device' when I execute modprobe spi-bcm2708
bulletmark
Fri Mar 13, 2015 6:02 am
That script would have told you to reboot when it finished. Did you do that?
Are you running raspbian, and if so is it up to date?
Please run that "sudo install-spidev.sh" command again and post the complete output here (in code tags).
Fri Mar 13, 2015 9:03 am
ImmerStudent wrote:Thanks, I executed the 3 commands successfully, but I still get 'no such device' when I execute modprobe spi-bcm2708
Have you enabled SPI in /boot/config.txt?
Add
dtparam=spi=on
and reboot. Or use the option in sudo raspi-config (advanced options).
This is a doctor free zone.
bulletmark
Fri Mar 13, 2015 9:06 am
DougieLawson wrote: Have you enabled SPI in /boot/config.txt?
My script does that, with everything else that is required. But, of course that only gets enabled after a reboot.
ImmerStudent
Fri Mar 13, 2015 11:55 am
Yes, I did a reboot, I am running raspbian, I did an update/upgrade and I updated the firmware and I had already enabled SPI in config.txt (dtparam=spi=on).
The version of Raspbian (from uname -r) is 3.18.6-v7i-aufs
The output from spidev.sh is:
<output>
Adding pi to spi group ..
groupadd: group 'spi' already exists
Adding user pi to group spi
Creating udev spi rules file ..
Removing blacklist for spi-bcm2708 ..
SPI already added to device tree
Reloading udev rules ..
User pi must log out and back in again.
</output>
I didn't log out, I rebooted.
Fri Mar 13, 2015 12:09 pm
What does lsmod show?
What does dmesg show?
What's in /etc/modules?
What's in /etc/modprobe.d/raspi-blacklist.conf?
bulletmark
Fri Mar 13, 2015 12:53 pm
ImmerStudent wrote: The version of Raspbian (from uname -r) is 3.18.6-v7i-aufs
That's quite a different kernel to the one on my RPis and from reading other recent posts around here (with similar problems, e.g. http://www.raspberrypi.org/forums/viewt ... 7&p=717710) it seems you installed Raspbian via BerryBoot? I'd say it's a Berryboot issue, perhaps you have to set that dtparam=spi boot option elsewhere?
ImmerStudent
Fri Mar 13, 2015 11:14 pm
Yes, I am using Berryboot. I have no idea how to change the boot parameters for Berryboot itself. Therefore are you saying that if I want to use Piface, I can't use Berryboot? That is sad, as I've set up a lot of stuff in the Raspbian image.
bulletmark
Fri Mar 13, 2015 11:29 pm
Sorry, I don't know anything about BerryBoot. Perhaps you should raise an issue at http://github.com/maxnet/berryboot/issues?
Ultimately you probably just need to add "dtparam=spi=on" to BerryBoot's config.txt, which I presume is in the root folder on your USB drive? Maybe try that first.
Fri Mar 13, 2015 11:39 pm
What's the partition layout on your Berryboot SDCard?
Is there more than one FAT/FAT32 partition?
If there is then what's on the one that isn't mounted as /boot? Mount it and take a look, it may have a copy of the RPi firmware (since Berryboot is the grandparent of NOOBS).
ImmerStudent
Sat Mar 14, 2015 4:28 am
Hi Dougie. I cut the Gordian knot by removing Berryboot from the equation and just using standalone Raspbian. Now the Piface works and I can find spidev0.0 etc!
So I can assume that Berryboot is the issue and I will leave the research to make Piface work with it to others more qualified.
As a former IBM mainframe sysprog and new to Linux, I have no idea how to find the partition layout or where I might find Berryboot's config.txt, as I have assumed that it would be opaque to the guest OS's file manager. I can only find the guest Raspbian's config.txt.
Thanks for your prompt help.
Now to reinstall my stuff on the new card (sigh)
Sat Mar 14, 2015 10:25 am
Get a USB SDCard reader. Mount the Berryboot card and take a look at it with fdisk -l.
I'm a mainframe sysprog and ex IBM'er, been doing that since Dec 1982.
MikeBlue
Sat Mar 14, 2015 7:17 pm
You are right for the config.txt in the bootberry.
You just need to use the booberry menu option and add the dtparam=spi=on to the config.txt.
I have tested this method it is perfect !.
Regards
ImmerStudent
Re: Piface2 setup - no spi_bcm2708 (solved)
Mon Mar 16, 2015 2:15 am
Dougie, I started in mainframe in 1978. Which doesn't alter the fact that I'm new to the chaos that is Linux.
Mike, I had already tried updating config.txt . Didn't work for me, so I went for the KISS solution.
