With standard RPi-Cam-Web-Interface installation and using external motion detection settings then the http api supported by motion is used to retrieve the /etc/motion/motion.conf data and display it in the motion.php table. The api is also used to modify values. motionPars.json doesn't come into it.ScheissSchiesser wrote:Can somebody help me figure out why my motionPars.json file is not getting populated with the motion settings? This causes me to be unable to view/change the motion settings via the web interface.
I am having trouble determining which part of the RPi-Cam-Web-Interface code is responsible for doing that. It is probably something in the motion.php file, but I am having trouble understanding it. It might help to debug this problem if I could figure that out.
As it stands now, motionPars.json is an empty file. Bringing up the motion.php page via clicking on the "motion settings" button shows a blank page (no table), presumably because the motionPars.json file contains no data.
Any help/hints would be appreciated.
In /etc/motion/motion.conf there is a section that controls the API called HTTP based control. The installer should set that up to be
control_port 6642
control_localhost on
control_html_output off
This means queries are done on port 6642, only requests from same host are allowed, and responses are in a plain text format.
