lmoss30
usb boot on pi3
Mon Feb 29, 2016 10:03 pm
I know this is probably everywhere but with the release of pi3 could someone indicate how to set the system upto to run noobs of a usb drive is this even possible or is it just the os that runs on the usb drive? And you still need something on the sd card?
mimi123
Re: usb boot on pi3
Tue Mar 01, 2016 3:19 pm
lmoss30 wrote:I know this is probably everywhere but with the release of pi3 could someone indicate how to set the system upto to run noobs of a usb drive is this even possible or is it just the os that runs on the usb drive? And you still need something on the sd card?
you can boot from USB and from network on the Pi3 without a MicroSD at all
The tools are still not public though
r3d4
Re: usb boot on pi3
Sat Mar 05, 2016 6:34 pm
What tools! :shock:
Re: usb boot on pi3
Sat Mar 05, 2016 6:43 pm
What tools! :shock:
Tools to make a bootable image perhaps?
Maybe just a suitable bootcode.bin file needs to be created.
gkreidl
Re: usb boot on pi3
Sat Mar 05, 2016 9:11 pm
I don't believe that will ever work on a Pi3, because of the USB hub. Maybe on a pure A3 or a compute module.
Minimal Kiosk Browser (kweb)
Re: usb boot on pi3
Sat Mar 05, 2016 9:18 pm
gkreidl wrote:I don't believe that will ever work on a Pi3, because of the USB hub. Maybe on a pure A3 or a compute module.
viewtopic.php?f=91&t=138786#p921177
AFAIA the LAN9514 does have the PXE feature if implemented: http://www.microchip.com/wwwproducts/en/LAN9514
Ethernet features:
10/100 Ethernet controller supports numerous power management wakeup features, including Magic Packet™, Wake-on LAN (WOL) and Link Status Change
Retired disgracefully.....
......to an uncomplicated life !
gregeric
Re: usb boot on pi3
Sat Mar 05, 2016 9:33 pm
There are references to "BCM2710 Boot" (the old USB boot with updated part number) & "Raspberry Pi Boot Generic STORAGE DEVICE 0250" in bootrom, suggesting two USB boot modes, but surely only relevant to 3A or CM3, or user-modified 3B.
Re: usb boot on pi3
Sat Mar 05, 2016 9:36 pm
gregeric wrote:There are references to "BCM2710 Boot" (the old USB boot with updated part number) & "Raspberry Pi Boot Generic STORAGE DEVICE 0250" in bootrom, suggesting two USB boot modes, but surely only relevant to 3A or CM3, or user-modified 3B.
Unless the base USB data lines are brought out to the micro USB power connector.
gregeric
Re: usb boot on pi3
Sat Mar 05, 2016 9:39 pm
You could be on to something there, PP2 / PP5 perhaps, needs confirmation?
jdb
Re: usb boot on pi3
Sun Mar 06, 2016 1:35 pm
The bootrom on Pi3 supports USB mass-storage class booting as well as tftp/PXE boot. What isn't in place yet is a bootcode.bin that understands it's been loaded from a USB device (and therefore should go look for a USB device/listen on tftp for start.elf).
Rockets are loud.
https://astro-pi.org
r3d4
Re: usb boot on pi3
Sun Mar 06, 2016 1:55 pm
jdb wrote:The bootrom on Pi3 supports USB mass-storage class booting as well as tftp/PXE boot. What isn't in place yet is a bootcode.bin that understands it's been loaded from a USB device (and therefore should go look for a USB device/listen on tftp for start.elf).
Thanks jdb :!: & *cheers along with enthused crowd* Get on with it :P
Now i just have to get a pi3 :D
Flagbit
Re: usb boot on pi3
Thu Mar 31, 2016 9:41 am
are there some news?
When could we probably be able to boot from USB only?
Kind Regards
Flagbit
-- My 2 Cents, Coin Heatsink: https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=141441
-- Snappy Pi 3: Coin Heatsink, 1300Mhz Overclocked stable (could void warranty), Ubuntu-Mate on USB-stick
DirkS
Re: usb boot on pi3
Thu Mar 31, 2016 11:02 pm
Flagbit wrote:When could we probably be able to boot from USB only?
When it's ready...
Flagbit
Re: usb boot on pi3
Fri Apr 01, 2016 8:44 pm
@Dirks
When is it probably ready ?
kusti8
Re: usb boot on pi3
Fri Apr 01, 2016 8:49 pm
Flagbit wrote:@Dirks
Sometime between now and infinity. The Foundation never releases a time line or progress and the latest is they are still working on it.
davidcoton
Re: usb boot on pi3
Fri Apr 01, 2016 9:39 pm
The day before it is announced.
Signature retired
Flagbit
Re: usb boot on pi3
Fri Apr 01, 2016 10:12 pm
so you also don't know it.
Let's them post it when they know it or release it.
Kind regards
Flagbit
Psypro
Re: usb boot on pi3
Sat Apr 02, 2016 7:02 am
Use : http://www.berryterminal.com/doku.php/berryboot
If you want to install to usb hdd.
DirkS
Re: usb boot on pi3
Sat Apr 02, 2016 8:56 am
Psypro wrote:Use : http://www.berryterminal.com/doku.php/berryboot
That is not the same as booting from a USB device, you will still need an SD card to boot from...
BTW: you don't need to use berryboot to have the root filesystem on a USB HDD
Re: usb boot on pi3
Sat Apr 02, 2016 4:38 pm
I suspect the local star (known as "The Sun") will go to a red dwarf before we reach infinity (or the Restaurant at the End of the Universe). Hopefully the RPI3 USB boot driver will appear sometime before that event.
This is a doctor free zone.
Re: usb boot on pi3
Sat Apr 02, 2016 6:14 pm
Flagbit,
It's probably ready now.
The probability may be very low. But probable none the less.
Flagbit
Re: usb boot on pi3
Sat Apr 02, 2016 7:04 pm
42
mole
Re: usb boot on pi3
Thu Apr 07, 2016 1:46 pm
I've hooked up Pi3 to Ethernet and power up without SD card. I don't see any DHCP request packet usually initiated by PXE boot. In fact, the Ethernet link LED is not blinking at all without SD card. How does the bootrom on Pi3 load anything from tftp server?
mimi123
Re: usb boot on pi3
Fri Apr 08, 2016 2:56 pm
I think that it's BOOTP
manawyrm
Re: usb boot on pi3
Sat Apr 09, 2016 9:00 pm
Yes, the PI doesn't even enable link on the LAN port.
I have sniffed on the port with wireshark and couldn't see any packets as well.
That doesn't look good for one of my most wanted features ):
