The guide that I found on youtube failed to work for me because of unmet dependencies:
The following packages have unmet dependencies:
jackd1 : Depends: libjack0 (= 1:0.124.1+20140122git5013bed0-3.1+fixed1~raspbian1) but it is not going to be installed
Depends: libdb5.1 but it is not installable
E: Unable to correct problems, you have held broken packages.
disabling onboard sound card...
setting default sound card to usb...
sed: can't read /etc/modprobe.d/alsa-base.conf: No such file or directory
forcing usb 1.1 and turning off turbo mode on eth...
cp: cannot stat â./ampbrownie/config_ampbrownie.txtâ: No such file or directory
cp: cannot stat â./ampbrownie/gx_head_rcâ: No such file or directory
cp: cannot stat â./ampbrownie/ampbrownie.gxâ: No such file or directory
Setup has finished. You will want to:
- reboot and remove your keyboard and mouse
- have your guitar/soundcard/midi controller hooked up
- play some sweet tunes
use "sudo reboot" to reboot now.
The person in the video is explaining that the GUI can be "forwarded" through ssh to another computer... Does the other computer have to be running *nix?
Is there something like a mobile client for guitarix? So you can control it with an Android tablet?
Thanks in advance!
