I have downloaded the 2016-02-26-raspbian-jessie-lite.img and provisioned an SD card for use with my brand new Pi 3
. I am having problems with my networking. I installed wicd-curses package and on some reboots the network connection does connect successfully on others it does not. I cannot seem to determine the issue. Help would be greatly appreciated. It seems to connect temporarily and then get disconnected. The wicd.log text follows:
2016/03/22 15:39:19 :: ifconfig eth0
2016/03/22 15:39:19 :: ifconfig wlan0
2016/03/22 15:39:24 :: ifconfig eth0
2016/03/22 15:39:24 :: ifconfig wlan0
2016/03/22 15:39:29 :: ifconfig eth0
2016/03/22 15:39:29 :: ifconfig wlan0
2016/03/22 15:39:34 :: ifconfig eth0
2016/03/22 15:39:34 :: ifconfig wlan0
2016/03/22 15:39:39 :: ifconfig eth0
2016/03/22 15:39:39 :: ifconfig wlan0
2016/03/22 15:39:44 :: ifconfig eth0
2016/03/22 15:39:44 :: ifconfig wlan0
2016/03/22 15:39:48 :: ifconfig wlan0
2016/03/22 15:39:48 :: ifconfig eth0
2016/03/22 15:39:48 :: iwconfig wlan0
2016/03/22 15:39:48 :: GetCurrentNetworkID: Returning -1, current network not found
2016/03/22 15:39:49 :: GetCurrentNetworkID: Returning -1, current network not found
2016/03/22 15:39:49 :: Reading wired profile wired-default
2016/03/22 15:39:49 :: found ip in configuration None
2016/03/22 15:39:49 :: found broadcast in configuration None
2016/03/22 15:39:49 :: found netmask in configuration None
2016/03/22 15:39:49 :: found gateway in configuration None
2016/03/22 15:39:49 :: found search_domain in configuration None
2016/03/22 15:39:49 :: found dns_domain in configuration None
2016/03/22 15:39:49 :: found dns1 in configuration None
2016/03/22 15:39:49 :: found dns2 in configuration None
2016/03/22 15:39:49 :: found dns3 in configuration None
2016/03/22 15:39:49 :: found beforescript in configuration None
2016/03/22 15:39:49 :: found afterscript in configuration None
2016/03/22 15:39:49 :: found predisconnectscript in configuration None
2016/03/22 15:39:49 :: found postdisconnectscript in configuration None
2016/03/22 15:39:49 :: found encryption_enabled in configuration None
2016/03/22 15:39:49 :: found default in configuration True
2016/03/22 15:39:49 :: found dhcphostname in configuration trusign-b3a3
2016/03/22 15:39:49 :: found lastused in configuration True
2016/03/22 15:39:51 :: ifconfig eth0
2016/03/22 15:39:51 :: iwconfig wlan0
2016/03/22 15:39:51 :: ifconfig wlan0
2016/03/22 15:39:53 :: iwconfig wlan0
2016/03/22 15:39:53 :: Executing /etc/network/if-down.d/resolvconf with params
2016/03/22 15:39:53 :: /etc/network/if-down.d/resolvconf returned 0
2016/03/22 15:39:53 :: Executing /etc/network/if-down.d/upstart with params
2016/03/22 15:39:53 :: /etc/network/if-down.d/upstart returned 0
2016/03/22 15:39:53 :: Executing /etc/network/if-down.d/wpasupplicant with params
2016/03/22 15:39:53 :: /etc/network/if-down.d/wpasupplicant returned 0
2016/03/22 15:39:53 :: /sbin/dhcpcd -k wlan0
2016/03/22 15:39:53 :: ifconfig wlan0 0.0.0.0
2016/03/22 15:39:53 :: /sbin/ip route flush dev wlan0
2016/03/22 15:39:53 :: ifconfig wlan0 down
2016/03/22 15:39:54 :: ifconfig wlan0 up
2016/03/22 15:39:54 :: Executing /etc/network/if-post-down.d/avahi-daemon with params
2016/03/22 15:39:54 :: /etc/network/if-post-down.d/avahi-daemon returned 0
2016/03/22 15:39:54 :: Executing /etc/network/if-post-down.d/wireless-tools with params
2016/03/22 15:39:54 :: /etc/network/if-post-down.d/wireless-tools returned 0
2016/03/22 15:39:54 :: Executing /etc/network/if-post-down.d/wpasupplicant with params
2016/03/22 15:39:54 :: /etc/network/if-post-down.d/wpasupplicant returned 0
2016/03/22 15:39:54 :: wpa_cli -i wlan0 terminate
2016/03/22 15:39:54 :: Executing /etc/network/if-down.d/resolvconf with params
2016/03/22 15:39:54 :: /etc/network/if-down.d/resolvconf returned 0
2016/03/22 15:39:54 :: Executing /etc/network/if-down.d/upstart with params
2016/03/22 15:39:54 :: /etc/network/if-down.d/upstart returned 0
2016/03/22 15:39:54 :: Executing /etc/network/if-down.d/wpasupplicant with params
2016/03/22 15:39:54 :: /etc/network/if-down.d/wpasupplicant returned 0
2016/03/22 15:39:54 :: /sbin/dhcpcd -k eth0
2016/03/22 15:39:54 :: ifconfig eth0 0.0.0.0
2016/03/22 15:39:54 :: /sbin/ip route flush dev eth0
2016/03/22 15:39:54 :: ifconfig eth0 down
2016/03/22 15:39:54 :: ifconfig eth0 up
2016/03/22 15:39:54 :: wpa_cli -i eth0 terminate
2016/03/22 15:39:54 :: found lastused in configuration True
2016/03/22 15:39:54 :: Executing /etc/network/if-pre-up.d/wireless-tools with params
2016/03/22 15:39:54 :: /etc/network/if-pre-up.d/wireless-tools returned 0
2016/03/22 15:39:54 :: Executing /etc/network/if-pre-up.d/wpasupplicant with params
2016/03/22 15:39:54 :: /etc/network/if-pre-up.d/wpasupplicant returned 0
2016/03/22 15:39:54 :: Putting interface down
2016/03/22 15:39:54 :: ifconfig eth0 downGetCurrentNetworkID: Returning -1, current network not found
2016/03/22 15:39:54 :: Releasing DHCP leases...
2016/03/22 15:39:54 :: Setting false IP...
2016/03/22 15:39:54 :: GetCurrentNetworkID: Returning -1, current network not found
2016/03/22 15:39:54 :: Stopping wpa_supplicant
2016/03/22 15:39:54 :: Flushing the routing table...
2016/03/22 15:39:54 :: Putting interface up...
2016/03/22 15:39:55 :: GetCurrentNetworkID: Returning -1, current network not found
2016/03/22 15:39:55 :: ifconfig wlan0
2016/03/22 15:39:55 :: ifconfig eth0
2016/03/22 15:39:55 :: Reading wired profile wired-default
2016/03/22 15:39:55 :: found ip in configuration None
2016/03/22 15:39:55 :: found broadcast in configuration None
2016/03/22 15:39:55 :: found netmask in configuration None
2016/03/22 15:39:55 :: found gateway in configuration None
2016/03/22 15:39:55 :: found search_domain in configuration None
2016/03/22 15:39:55 :: found dns_domain in configuration None
2016/03/22 15:39:55 :: found dns1 in configuration None
2016/03/22 15:39:55 :: found dns2 in configuration None
2016/03/22 15:39:55 :: found dns3 in configuration None
2016/03/22 15:39:55 :: found beforescript in configuration None
2016/03/22 15:39:55 :: found afterscript in configuration None
2016/03/22 15:39:55 :: found predisconnectscript in configuration None
2016/03/22 15:39:55 :: found postdisconnectscript in configuration None
2016/03/22 15:39:55 :: found encryption_enabled in configuration None
2016/03/22 15:39:55 :: found default in configuration True
2016/03/22 15:39:55 :: found dhcphostname in configuration trusign-b3a3
2016/03/22 15:39:55 :: found lastused in configuration True
2016/03/22 15:39:56 :: Running DHCP with hostname trusign-b3a3
2016/03/22 15:39:56 :: /sbin/dhcpcd -h trusign-b3a3 --noipv4ll eth0
2016/03/22 15:39:56 :: dhcpcd[16304]: sending commands to master dhcpcd process
2016/03/22 15:39:56 :: DHCP connection successful
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/000resolvconf with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/000resolvconf returned 0
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/avahi-daemon with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/avahi-daemon returned 0
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/mountnfs with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/mountnfs returned 0
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/openssh-server with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/openssh-server returned 0
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/upstart with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/upstart returned 0
2016/03/22 15:39:56 :: Executing /etc/network/if-up.d/wpasupplicant with params
2016/03/22 15:39:56 :: /etc/network/if-up.d/wpasupplicant returned 0
2016/03/22 15:39:56 :: Connecting thread exiting.
2016/03/22 15:39:56 :: IP Address is: None
2016/03/22 15:39:57 :: ifconfig eth0
2016/03/22 15:39:57 :: iwconfig wlan0
2016/03/22 15:39:57 :: ifconfig wlan0
2016/03/22 15:40:00 :: Sending connection attempt result success
2016/03/22 15:40:00 :: ifconfig eth0
2016/03/22 15:40:00 :: ifconfig wlan0
2016/03/22 15:40:00 :: Forced disconnect on
2016/03/22 15:40:00 :: iwconfig wlan0
2016/03/22 15:40:00 :: Executing /etc/network/if-down.d/resolvconf with params
2016/03/22 15:40:00 :: /etc/network/if-down.d/resolvconf returned 0
2016/03/22 15:40:00 :: Executing /etc/network/if-down.d/upstart with params
2016/03/22 15:40:00 :: /etc/network/if-down.d/upstart returned 0
2016/03/22 15:40:00 :: Executing /etc/network/if-down.d/wpasupplicant with params
2016/03/22 15:40:00 :: /etc/network/if-down.d/wpasupplicant returned 0
2016/03/22 15:40:00 :: /sbin/dhcpcd -k wlan0
2016/03/22 15:40:00 :: ifconfig wlan0 0.0.0.0
2016/03/22 15:40:00 :: /sbin/ip route flush dev wlan0
2016/03/22 15:40:00 :: ifconfig wlan0 down
2016/03/22 15:40:00 :: ifconfig wlan0 up
2016/03/22 15:40:00 :: Executing /etc/network/if-post-down.d/avahi-daemon with params
2016/03/22 15:40:00 :: /etc/network/if-post-down.d/avahi-daemon returned 0
2016/03/22 15:40:00 :: Executing /etc/network/if-post-down.d/wireless-tools with params
2016/03/22 15:40:00 :: /etc/network/if-post-down.d/wireless-tools returned 0
2016/03/22 15:40:00 :: Executing /etc/network/if-post-down.d/wpasupplicant with params
2016/03/22 15:40:00 :: /etc/network/if-post-down.d/wpasupplicant returned 0
2016/03/22 15:40:00 :: wpa_cli -i wlan0 terminate
2016/03/22 15:40:00 :: /sbin/dhcpcd -k eth0
2016/03/22 15:40:00 :: ifconfig eth0 0.0.0.0
2016/03/22 15:40:01 :: /sbin/ip route flush dev eth0
2016/03/22 15:40:01 :: ifconfig eth0 down
2016/03/22 15:40:01 :: ifconfig eth0 up
2016/03/22 15:40:01 :: Executing /etc/network/if-post-down.d/avahi-daemon with params
2016/03/22 15:40:01 :: /etc/network/if-post-down.d/avahi-daemon returned 0
2016/03/22 15:40:01 :: Executing /etc/network/if-post-down.d/wireless-tools with params
2016/03/22 15:40:01 :: /etc/network/if-post-down.d/wireless-tools returned 0
2016/03/22 15:40:01 :: Executing /etc/network/if-post-down.d/wpasupplicant with params
2016/03/22 15:40:01 :: /etc/network/if-post-down.d/wpasupplicant returned 0
2016/03/22 15:40:01 :: wpa_cli -i eth0 terminate
2016/03/22 15:40:05 :: ifconfig eth0
2016/03/22 15:40:05 :: ifconfig wlan0
