Hello
I've read all the in-car PC threads - I have seen if anyone knows if there is any Sat-Nav software available for Linux ?
I'm guessing that most people are using USB Sat-Nav dongles ?
Best 3G integration ?
Any thoughts ?
L200man
What kind of glitches have you seen?mrtenchy wrote:I have just installed Navit directly on the hard float wheezy Raspbian OS.
It works except for some glitching with the map data files (needs checking what can be used / not used).
Should work a treat! ...
