That's the one, bang on it works fine now DougieDougieLawson wrote:sudo apt-get install python{,3}-minecraftpi
Thanks a lot everyone!
Has been the only Raspbian option since September........gman98 wrote:Quick question on Jessie, is it now part of NOOBS? If I downloaded the latest NOOBS is there an option (or the only option) to install Jessie?
They're cheaper in Tesco, Sainsburys, Morrisons or ASDA's.fred bloggs wrote: Many thanks, a nice and simple instruction, I will get a new SD card from Maplins this afternoon and try tonight when I get home.
I feel you pain, man.AdamMercado wrote:B.Goode wrote:I think you might be following an outdated tutorial.
Try this one: https://www.raspberrypi.org/learning/ge ... ecraft-pi/
(There will not be an mcpi folder in your home directory unless you choose to create one. If you are able to run and interact with MineCraft then it is clearly installed.)
Thanks for the reply. That is exactly the tutorial I was following. I entered the first line of code and got an error. I'm not near the Pi now so I can't check the exact verbiage of the error. I did some reading trying to find a solution and came across the 'stuffaboutcode' website. There I read that there should be an mcpi folder and I needed to copy some files from it.
Now I'm really stumped
