Robertus wrote:Hi,
i have a little problem because copy and paste doesn't work for me.
I use RDP in windows 7 64bit ( default remote ) for my raspbian ( sudo apt-get install xrdp)
but copy and paste from windows to raspbian and viceversa doesn't work
Please someone can help me about that?
I read a lot of stuff without success.
You are correct C&P does not work with RDP.
As an alternative I found that C&P does work from a SSH connection using PuTTy.
From RPi to Windows: Select text with mouse left button hold and drag (press no other keys). Then on the Windows side use Paste menu or CTRL-V
From Windows to RPi: Copy text then on the RPi put cursor at insertion point. Be sure to place cursor with arrow keys and NOT mouse! Then right click the mouse.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
