Think I will try and source a few more verisons of mslug 4 & 5 and try all of them separately to see if they work, and if not, try from the command line like you say.
Cheers,
I don't think there is with the version of PiFBA floating around, it's based on a very old port of Final Burn Alpha for the GP2X and doesn't support a lot of the hardware/games the newer versions do.JTCook wrote:I was wondering how enable Outrun in Final Burn Alpha? I know there is code there to support it, but am wondering if it has been disabled in the emulator?
# Makefile for FBA, for use with GNU make
# The first pass makes sure all intermediary targets are present. The second pass updates
# any targets, if necessary. (Intermediary) targets which have their own unique rules
# are generated as required.
# Flags. Uncomment any of these declarations to enable their function.
# Specify the name of the executable file, without ".exe"
NAME = fbasdl
# Include Unicode support
UNICODE = 1
# Build A68K ASM 68000 core
# BUILD_A68K = 1
# Include x86 Assembly routines
# BUILD_X86_ASM = 1
# Build for x64 targets (MinGW64 and MSVC only, this will undefine BUILD_A68K and BUILD_X86_ASM)
# BUILD_X64_EXE = 1
# Build for Windows XP target (for use with Visual Studio 2012)
# BUILD_VS2012_XP_TARGET = 1
# Include 7-zip support
INCLUDE_7Z_SUPPORT = 1
# Include Toaplan sound sample hacks for games without MCU dumps
TOAPLAN_SOUND_SAMPLES_HACK = 1
# Include symbols and other debug information in the executable
# SYMBOL = 1
# Include features for debugging drivers
# DEBUG = 1
# Include rom set verifying features (comment this for release builds)
# ROM_VERIFY = 1
# Force recompilation of files that need it (i.e. use __TIME__, __DATE__, SPECIALBUILD).
FORCE_UPDATE = 1
# Use the __fastcall calling convention when interfacing with A68K/Musashi/Doze
# FASTCALL = 1
# Compress executable with upx (the DEBUG option ignores this)
# COMPRESS = 1
# Endianness
LSB_FIRST = 1
# Include png.h from burner.h
INCLUDE_LIB_PNGH = 1
# Check for changes in header files
DEPEND = 1
# DEBUG = 1
# Perl is available
PERL = 1
# Choose emulation cores
# BUILD_A68K = 1
BUILD_C68K = 1
BUILD_M68K = 1
USE_LIBAO = 1
# Declare variables
# Make a special build, pass the quoted text as comment (use FORCE_UPDATE declaration below to force recompilation of resources)
# SPECIALBUILD = "This text will appear in the property sheet of the .exe file"
ifndef CPUTYPE
CPUTYPE = ARM7
endif
# ifeq ($(CPUTYPE),i686)
# ppro = ppro
# endif
ifneq ($(CPUTYPE),i686)
NAME := $(NAME)$(CPUTYPE)
endif
# Specify paths/files
objdir = obj/dingux-gcc/
srcdir = src/
alldir = burn \
burn/devices \
burn/drv \
burn/drv/capcom \
burn/drv/cave \
burn/drv/cps3 \
burn/drv/dataeast \
burn/drv/galaxian \
burn/drv/irem \
burn/drv/konami \
burn/drv/megadrive \
burn/drv/pce \
burn/drv/neogeo \
burn/drv/pgm \
burn/drv/pre90s \
burn/drv/psikyo \
burn/drv/pst90s \
burn/drv/sega \
burn/drv/sms \
burn/drv/snes \
burn/drv/taito \
burn/drv/toaplan \
burn/snd \
intf \
intf/audio \
intf/audio/sdl \
intf/cd \
intf/cd/sdl \
intf/input \
intf/input/sdl \
intf/video \
intf/video/sdl \
intf/video/scalers \
cpu \
cpu/arm \
cpu/arm7 \
cpu/c68k \
cpu/cz80 \
cpu/h6280 \
cpu/hd6309 \
cpu/i8039 \
cpu/konami \
cpu/m68k \
cpu/m6502 \
cpu/m6800 \
cpu/m6805 \
cpu/m6809 \
cpu/nec \
cpu/pic16c5x \
cpu/s2650 \
cpu/sh2 \
cpu/tlcs90 \
cpu/z80 \
dep/scripts \
dep/generated \
sdl-dingux
incdir = $(foreach dir,$(alldir),-I$(srcdir)$(dir)) -I$(objdir)dep/generated -I/local/include -I/include/SDL -I$(SDKSTAGE)/opt/vc/include -I$(SDKSTAGE)/opt/vc/include/interface/vcos/pthreads \
-I$(SDKSTAGE)/opt/vc/include/interface/vmcs_host/linux -I/usr/include/SDL -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include
ifeq ($(OS),Windows_NT)
lib = -static -lstdc++ -lmingw32 -Wl,-Bdynamic -lSDL -lSDL_image -lz
else
lib = -lstdc++ -lSDL -lSDL_image -lz
endif
ifdef USE_LIBAO
lib += -lao
endif
drvobj += \
d_dodonpachi.o d_donpachi.o d_esprade.o d_feversos.o d_gaia.o d_guwange.o d_hotdogst.o d_korokoro.o d_mazinger.o \
d_metmqstr.o d_pwrinst2.o d_sailormn.o d_tjumpman.o d_uopoko.o \
d_cps1.o \
d_cps2.o \
d_cps3.o \
d_actfancr.o d_backfire.o d_boogwing.o d_cbuster.o d_cninja.o d_darkseal.o d_dassault.o d_dec0.o d_dec8.o \
d_dietgogo.o d_funkyjet.o d_karnov.o d_lemmings.o d_pktgaldx.o d_rohga.o d_sidepckt.o d_simpl156.o d_supbtime.o \
d_tumblep.o d_vaportra.o \
d_galaxian.o \
d_m62.o d_m63.o d_m72.o d_m90.o d_m92.o d_m107.o d_vigilant.o \
d_88games.o d_ajax.o d_aliens.o d_blockhl.o d_bottom9.o d_contra.o d_crimfght.o d_gberet.o d_gbusters.o d_gradius3.o \
d_gyruss.o d_hcastle.o d_hexion.o d_kontest.o d_mainevt.o d_mikie.o d_mogura.o d_nemesis.o d_parodius.o d_pooyan.o \
d_rollerg.o d_scotrsht.o d_simpsons.o d_spy.o d_surpratk.o d_thunderx.o d_tmnt.o d_twin16.o d_ultraman.o d_vendetta.o \
d_xmen.o \
d_neogeo.o \
d_pgm.o \
d_psikyo.o d_psikyo4.o d_psikyosh.o \
d_angelkds.o d_bankp.o d_dotrikun.o d_hangon.o d_outrun.o d_suprloco.o d_suprnova.o d_sys1.o d_sys16a.o d_sys16b.o d_sys18.o \
d_xbrd.o d_ybrd.o \
d_arkanoid.o d_ashnojoe.o d_asuka.o d_bublbobl.o d_chaknpop.o d_darius2.o d_darkmist.o d_exzisus.o d_flstory.o d_lkage.o \
d_minivdr.o d_othunder.o d_retofinv.o d_slapshot.o d_superchs.o d_taitob.o d_taitof2.o d_taitomisc.o d_taitox.o d_taitoz.o \
d_tnzs.o d_wyvernf0.o \
d_batrider.o d_batsugun.o d_battleg.o d_bbakraid.o d_demonwld.o d_dogyuun.o d_fixeight.o d_ghox.o d_hellfire.o \
d_kbash.o d_kbash2.o d_mahoudai.o d_outzone.o d_pipibibs.o d_rallybik.o d_samesame.o d_shippumd.o d_slapfght.o \
d_snowbro2.o d_tekipaki.o d_truxton.o d_truxton2.o d_vfive.o d_vimana.o d_zerowing.o \
d_4enraya.o d_1942.o d_1943.o d_ambush.o d_arabian.o d_armedf.o d_atetris.o d_aztarac.o d_baraduke.o d_bionicc.o \
d_blktiger.o d_blockout.o d_blueprnt.o d_bombjack.o d_capbowl.o d_commando.o d_cybertnk.o d_ddragon.o d_dkong.o \
d_dynduke.o d_epos.o d_exedexes.o d_funkybee.o d_galaga.o d_gauntlet.o d_ginganin.o d_gng.o d_gunsmoke.o d_higemaru.o \
d_ikki.o d_jack.o d_kangaroo.o d_kyugo.o d_ladybug.o d_lwings.o d_lastduel.o d_markham.o d_marineb.o d_meijinsn.o \
d_mitchell.o d_mole.o d_momoko.o d_mrdo.o d_mrflea.o d_mustache.o d_mystston.o d_ninjakd2.o d_pacland.o d_pacman.o d_pac2650.o \
d_pkunwar.o d_prehisle.o d_punchout.o d_psychic5.o d_quizo.o d_rallyx.o d_renegade.o d_rpunch.o d_route16.o d_scregg.o d_sf.o \
d_skyfox.o d_skykid.o d_snk68.o d_solomon.o d_sonson.o d_srumbler.o d_tail2nose.o d_tecmo.o d_terracre.o d_tigeroad.o d_toki.o \
d_vulgus.o d_wallc.o d_wc90.o d_wc90b.o d_wwfsstar.o d_xain.o \
d_1945kiii.o d_aerofgt.o d_airbustr.o d_aquarium.o d_blmbycar.o d_bloodbro.o d_crospang.o d_crshrace.o d_dcon.o \
d_deniam.o d_ddragon3.o d_diverboy.o d_drgnmst.o d_drtomy.o d_egghunt.o d_esd16.o d_f1gp.o d_fstarfrc.o d_funybubl.o \
d_fuukifg3.o d_gaelco.o d_gaiden.o d_galpanic.o d_galspnbl.o d_gotcha.o d_gumbo.o d_hyperpac.o d_jchan.o d_kaneko16.o \
d_lordgun.o d_mcatadv.o d_midas.o d_mugsmash.o d_mwarr.o d_news.o d_nmg5.o d_nmk16.o d_ohmygod.o d_pass.o d_pirates.o \
d_playmark.o d_powerins.o d_pushman.o d_raiden.o d_seta.o d_seta2.o d_shadfrce.o d_silkroad.o d_silvmil.o d_speedspn.o \
d_suna16.o d_taotaido.o d_tecmosys.o d_tumbleb.o d_unico.o d_vmetal.o d_welltris.o d_wwfwfest.o d_xorworld.o d_yunsun16.o \
d_zerozone.o \
d_parent.o \
#d_megadrive.o \
#d_pce.o \
#d_sms.o \
#d_snes.o
ifdef USE_LIBAO
depobj = ao_audio.o
endif
depobj += \
bzip.o config.o drv.o font.o stringset.o stubs.o \
input.o main.o neocdlist.o paths.o run.o tchar.o \
sdl_audio.o sdl_input.o sdl_menu.o sdl_progress.o \
sdl_run.o sdl_video.o snd.o \
ioapi.o unzip.o dat.o state.o zipfn.o \
gui_config.o gui_gfx.o gui_main.o gui_romlist.o gui_setpath.o \
interface.o \
cd_interface.o
depobj += \
$(drvobj) \
burn.o burn_gun.o burn_led.o burn_memory.o burn_sound.o burn_sound_c.o cheat.o debug_track.o hiscore.o load.o \
tiles_generic.o timer.o vector.o \
8255ppi.o 8257dma.o eeprom.o nmk004.o pandora.o seibusnd.o sknsspr.o slapstic.o t5182.o timekpr.o tms34061.o v3021.o vdc.o \
ay8910.o burn_y8950.o burn_ym2151.o burn_ym2203.o burn_ym2413.o burn_ym2608.o burn_ym2610.o burn_ym2612.o \
burn_ym3526.o burn_ym3812.o burn_ymf278b.o c6280.o dac.o es5506.o es8712.o flt_rc.o fm.o fmopl.o ics2115.o iremga20.o \
k005289.o k007232.o k051649.o k053260.o k054539.o msm5205.o msm5232.o msm6295.o namco_snd.o nes_apu.o rf5c68.o saa1099.o \
samples.o segapcm.o sn76496.o upd7759.o vlm5030.o x1010.o ym2151.o ym2413.o ymdeltat.o ymf278b.o ymz280b.o \
arm7_intf.o arm_intf.o h6280_intf.o hd6309_intf.o konami_intf.o m6502_intf.o m6800_intf.o m6805_intf.o m6809_intf.o \
m68000_intf.o nec_intf.o pic16c5x_intf.o s2650_intf.o tlcs90_intf.o z80_intf.o \
arm.o arm7.o h6280.o hd6309.o i8039.o konami.o m6502.o m6800.o m6805.o m6809.o nec.o pic16c5x.o s2650.o sh2.o tlcs90.o \
v25.o z80.o z80daisy.o \
cave.o cave_palette.o cave_sprite.o cave_tile.o \
cps2_crpt.o cps.o cps_config.o cps_draw.o cps_mem.o cps_obj.o cps_pal.o cps_run.o cps_rw.o cps_scr.o cpsr.o cpsrd.o \
cpst.o ctv.o fcrash_snd.o kabuki.o ps.o ps_m.o ps_z.o qs.o qs_c.o qs_z.o sf2mdt_snd.o \
cps3run.o cps3snd.o \
deco16ic.o \
gal_gfx.o gal_run.o gal_sound.o gal_stars.o \
irem_cpu.o \
k051316.o k051733.o k051960.o k052109.o k053245.o k053247.o k053251.o k053936.o k054000.o konamiic.o \
neo_decrypt.o neo_palette.o neo_run.o neo_sprite.o neo_text.o neo_upd4990a.o neogeo.o \
pgm_crypt.o pgm_draw.o pgm_prot.o pgm_run.o \
psikyo_palette.o psikyo_sprite.o psikyo_tile.o psikyosh_render.o \
fd1089.o fd1094.o genesis_vid.o mc8123.o sys16_fd1094.o sys16_gfx.o sys16_run.o \
cchip.o pc080sn.o pc090oj.o taito.o taito_ic.o taito_m68705.o tc0100scn.o tc0110pcr.o tc0140syt.o tc0150rod.o \
tc0180vcu.o tc0220ioc.o tc0280grd.o tc0360pri.o tc0480scp.o tc0510nio.o tc0640fio.o tnzs_prot.o \
toa_bcu2.o toa_extratext.o toa_gp9001.o toa_palette.o toaplan1.o toaplan.o \
#megadrive.o \
#pce.o \
#sms.o \
#snes_65816.o snes_io.o snes_main.o snes_ppu.o snes_spc700.o
ifdef BUILD_M68K
ifdef DEBUG
depobj += m68kdasm.o
endif
endif
autobj += $(depobj)
ifdef BUILD_A68K
a68k.o = $(objdir)cpu/a68k/a68k.o
endif
ifdef BUILD_C68K
autobj += c68k.o
endif
autdep = $(autobj:.o=.d)
driverlist.h = $(srcdir)dep/generated/driverlist.h
ctv.h = $(srcdir)dep/generated/ctv.h
toa_gp9001_func.h = $(srcdir)dep/generated/toa_gp9001_func.h
neo_sprite_func.h = $(srcdir)dep/generated/neo_sprite_func.h
cave_tile_func.h = $(srcdir)dep/generated/cave_tile_func.h
cave_sprite_func.h = $(srcdir)dep/generated/cave_sprite_func.h
psikyo_tile_func.h = $(srcdir)dep/generated/psikyo_tile_func.h
pgm_sprite.h = $(srcdir)dep/generated/pgm_sprite.h
build_details.h = $(srcdir)dep/generated/build_details.h
ifdef BUILD_M68K
allobj = $(objdir)cpu/m68k/m68kcpu.o $(objdir)cpu/m68k/m68kopnz.o $(objdir)cpu/m68k/m68kopdm.o $(objdir)cpu/m68k/m68kopac.o $(objdir)cpu/m68k/m68kops.o
endif
allobj += \
$(foreach file,$(autobj:.o=.c), \
$(foreach dir,$(alldir),$(subst $(srcdir),$(objdir), \
$(firstword $(subst .c,.o,$(wildcard $(srcdir)$(dir)/$(file))))))) \
$(foreach file,$(autobj:.o=.cpp), \
$(firstword $(subst .cpp,.o,$(wildcard $(srcdir)$(dir)/$(file))))))) \
$(foreach file,$(autobj:.o=.asm), \
$(firstword $(subst .asm,.o,$(wildcard $(srcdir)$(dir)/$(file)))))))
ifdef BUILD_A68K
allobj += $(a68k.o)
endif
alldep = $(foreach file,$(autobj:.o=.c), \
$(firstword $(subst .c,.d,$(wildcard $(srcdir)$(dir)/$(file))))))) \
$(firstword $(subst .cpp,.d,$(wildcard $(srcdir)$(dir)/$(file)))))))
# Specify compiler/linker/assembler
HOSTCC = gcc-4.8
HOSTCXX = g++-4.8
CC = gcc-4.8
CXX = g++-4.8
LD = $(CXX)
AS = as
HOSTCFLAGS = $(incdir)
CFLAGS = -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -O2 -fomit-frame-pointer -Wno-write-strings -DLSB_FIRST
CXXFLAGS = -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -O2 -fomit-frame-pointer -Wno-write-strings -fpermissive \
-DLSB_FIRST
CFLAGS += -U__cdecl -U__fastcall -D__cdecl="" -D__fastcall=""
CXXFLAGS += -U__cdecl -U__fastcall -D__cdecl="" -D__fastcall=""
ifdef USE_LIBAO
CFLAGS += -DUSE_LIBAO
CXXFLAGS += -DUSE_LIBAO
endif
DEF = -DCPUTYPE=$(CPUTYPE) -DUSE_SPEEDHACKS -DBUILD_SDL
ifdef SPECIALBUILD
DEF += -DSPECIALBUILD=$(SPECIALBUILD)
endif
ifdef DEBUG
DEF += -DFBA_DEBUG -g
HOSTCFLAGS += -DFBA_DEBUG -g
endif
ifdef BUILD_A68K
DEF += -DBUILD_A68K
endif
ifdef BUILD_C68K
DEF += -DBUILD_C68K
endif
ifdef BUILD_M68K
DEF += -DBUILD_M68K
endif
DEF += -DFILENAME=$(NAME)
ifdef PROFILE
CFLAGS += -pg
else
LDFLAGS =
endif
CFLAGS += $(DEF) $(incdir)
CXXFLAGS += $(DEF) $(incdir)
ifndef DEBUG
LDFLAGS += -s
endif
ASFLAGS = -O1 -mcpu=cortex-a7
CFLAGS_CONSOLE = -mno-cygwin -mconsole -pipe -Wall -W $(DEF) $(incdir)
ASFLAGS += -f coff
else
ASFLAGS += -f elf
endif
# Specify paths
vpath %.asm $(foreach dir,$(alldir),$(srcdir)$(dir)/ )
vpath %.cpp $(foreach dir,$(alldir),$(srcdir)$(dir)/ )
vpath %.c $(foreach dir,$(alldir),$(srcdir)$(dir)/ )
vpath %.h $(foreach dir,$(alldir),$(srcdir)$(dir)/ )
vpath %.o $(foreach dir,$(alldir),$(objdir)$(dir)/ )
vpath %.d $(foreach dir,$(alldir),$(objdir)$(dir)/ )
# Rules
.PHONY: all init cleandep clean
ifeq ($(MAKELEVEL),0)
ifdef DEPEND
all: init $(autdep) $(autobj)
@$(MAKE) -f Makefile.rpi2
else
all: init $(autobj)
endif
else
all: $(NAME)
endif
# Rule for linking the executable
ifeq ($(MAKELEVEL),1)
$(NAME): $(allobj)
@echo
@echo Linking executable $(NAME)...
@mkdir -p bin
@$(LD) $(CFLAGS) $(LDFLAGS) -o bin/$@ $^ $(lib)
@mkdir -p bin/skin
@cp src/sdl-dingux/skin/*.png bin/skin/
endif
# Generate the gamelist
burn.o burn.d: driverlist.h
$(driverlist.h): $(drvobj) $(srcdir)dep/scripts/gamelist.pl
ifdef PERL
@perl $(srcdir)dep/scripts/gamelist.pl -o $@ -l gamelist.txt \
$(filter %.cpp,$(foreach file,$(drvobj:.o=.cpp),$(foreach dir,$(alldir), \
$(firstword $(wildcard $(srcdir)$(dir)/$(file))))))
else
@echo
@echo Warning: Perl is not available on this system.
@echo $@ cannot be updated or created!
@echo
endif
endif
# Compile 68000 cores
# A68K
ifdef BUILD_A68K
$(a68k.o): fba_make68k.c
@echo Compiling A68K MC68000 core...
@$(HOSTCC) $(HOSTCFLAGS) $(LDFLAGS) -DWIN32 -Wno-unused -Wno-conversion -Wno-missing-prototypes \
-s $< -o $(objdir)/dep/generated/fba_make68k
@$(objdir)dep/generated/fba_make68k $(@:.o=.asm) \
$(@D)/a68k_tab.asm 00
@echo Assembling A68K MC68000 core...
@$(AS) $(ASFLAGS) $(@:.o=.asm) -o $@
endif
# Musashi
ifdef BUILD_M68K
$(objdir)cpu/m68k/m68kcpu.o: $(srcdir)cpu/m68k/m68kcpu.c $(objdir)dep/generated/m68kops.h $(srcdir)cpu/m68k/m68k.h $(srcdir)cpu/m68k/m68kconf.h
@echo Compiling Musashi MC680x0 core \(m68kcpu.c\)...
@$(CC) $(CFLAGS) -c $(srcdir)cpu/m68k/m68kcpu.c -o $(objdir)cpu/m68k/m68kcpu.o
$(objdir)cpu/m68k/m68kops.o: $(objdir)cpu/m68k/m68kmake $(objdir)dep/generated/m68kops.h $(objdir)dep/generated/m68kops.c $(srcdir)cpu/m68k/m68k.h $(srcdir)cpu/m68k/m68kconf.h
@echo Compiling Musashi MC680x0 core \(m68kops.c\)...
@$(CC) $(CFLAGS) -c $(objdir)dep/generated/m68kops.c -o $(objdir)cpu/m68k/m68kops.o
$(objdir)cpu/m68k/m68kopac.o: $(objdir)cpu/m68k/m68kmake $(objdir)dep/generated/m68kops.h $(objdir)dep/generated/m68kopac.c $(srcdir)cpu/m68k/m68k.h $(srcdir)cpu/m68k/m68kconf.h
@echo Compiling Musashi MC680x0 core \(m68kopac.c\)...
@$(CC) $(CFLAGS) -c $(objdir)dep/generated/m68kopac.c -o $(objdir)cpu/m68k/m68kopac.o
$(objdir)cpu/m68k/m68kopdm.o: $(objdir)cpu/m68k/m68kmake $(objdir)dep/generated/m68kops.h $(objdir)dep/generated/m68kopdm.c $(srcdir)cpu/m68k/m68k.h $(srcdir)cpu/m68k/m68kconf.h
@echo Compiling Musashi MC680x0 core \(m68kopdm.c\)...
@$(CC) $(CFLAGS) -c $(objdir)dep/generated/m68kopdm.c -o $(objdir)cpu/m68k/m68kopdm.o
$(objdir)cpu/m68k/m68kopnz.o: $(objdir)cpu/m68k/m68kmake $(objdir)dep/generated/m68kops.h $(objdir)dep/generated/m68kopnz.c $(srcdir)cpu/m68k/m68k.h $(srcdir)cpu/m68k/m68kconf.h
@echo Compiling Musashi MC680x0 core \(m68kopnz.c\)...
@$(CC) $(CFLAGS) -c $(objdir)dep/generated/m68kopnz.c -o $(objdir)cpu/m68k/m68kopnz.o
$(objdir)dep/generated/m68kops.h: $(objdir)cpu/m68k/m68kmake $(srcdir)cpu/m68k/m68k_in.c
$(objdir)/cpu/m68k/m68kmake $(objdir)dep/generated/ $(srcdir)cpu/m68k/m68k_in.c
$(objdir)cpu/m68k/m68kmake: $(srcdir)cpu/m68k/m68kmake.c
@echo Compiling Musashi MC680x0 core \(m68kmake.c\)...
@$(HOSTCC) $(HOSTCFLAGS) $(srcdir)cpu/m68k/m68kmake.c -o $(objdir)cpu/m68k/m68kmake
endif
# Extra rules for generated header file cvt.h, needed by ctv.cpp
ctv.d ctv.o: $(ctv.h)
$(ctv.h): ctv_make.cpp
@echo Generating $(srcdir)dep/generated/$(@F)...
@$(HOSTCXX) $(LDFLAGS) $< -o $(objdir)dep/generated/ctv_make
@$(objdir)dep/generated/ctv_make >$@
# Extra rules for generated header file toa_gp9001_func.h, needed by toa_gp9001.cpp
toa_bcu2.d toa_bcu2.o toa_gp9001.d toa_gp9001.o: $(toa_gp9001_func.h)
$(toa_gp9001_func.h): $(srcdir)dep/scripts/toa_gp9001_func.pl
@$(srcdir)dep/scripts/toa_gp9001_func.pl -o $(toa_gp9001_func.h)
# Extra rules for generated header file neo_sprite_func.h, needed by neo_sprite.cpp
neo_sprite.d neo_sprite.o: $(neo_sprite_func.h)
$(neo_sprite_func.h): $(srcdir)dep/scripts/neo_sprite_func.pl
@$(srcdir)dep/scripts/neo_sprite_func.pl -o $(neo_sprite_func.h)
# Extra rules for generated header file cave_tile_func.h, needed by cave_tile.cpp
cave_tile.d cave_tile.o: $(cave_tile_func.h)
$(cave_tile_func.h): $(srcdir)dep/scripts/cave_tile_func.pl
@perl $(srcdir)dep/scripts/cave_tile_func.pl -o $(cave_tile_func.h)
# Extra rules for generated header file cave_sprite_func.h, needed by cave_sprite.cpp
cave_sprite.d cave_sprite.o: $(cave_sprite_func.h)
$(cave_sprite_func.h): $(srcdir)dep/scripts/cave_sprite_func.pl
@perl $(srcdir)dep/scripts/cave_sprite_func.pl -o $(cave_sprite_func.h)
# Extra rules for generated header file psikyo_tile_func.h / psikyo_sprite_func.h, needed by psikyo_tile.cpp / psikyo_sprite.cpp
psikyo_tile.d psikyo_tile.o psikyosprite.d psikyo_sprite.o: $(psikyo_tile_func.h)
$(psikyo_tile_func.h): $(srcdir)dep/scripts/psikyo_tile_func.pl
@perl $(srcdir)dep/scripts/psikyo_tile_func.pl -o $(psikyo_tile_func.h)
# Extra rules for generated header file pgm_sprite.h, needed by pgm_draw.cpp
pgm_draw.d pgm_draw.o: $(pgm_sprite.h)
$(pgm_sprite.h): pgm_sprite_create.cpp
@$(HOSTCXX) $(LDFLAGS) $< -o $(objdir)dep/generated/pgm_sprite_create
@$(objdir)dep/generated/pgm_sprite_create >$@
ifdef DEPEND
include $(alldep)
endif
endif
# Generic rules for C/C++ files
%.o: %.cpp
@echo Compiling $<...
@$(CXX) $(CXXFLAGS) -c $< -o $(subst $(srcdir),$(objdir),$(<D))/$(@F)
%.o: %.c
@$(CC) $(CFLAGS) -Wno-unused -Wno-conversion -Wno-missing-prototypes -c $< -o $(subst $(srcdir),$(objdir),$(<D))/$(@F)
%.o: %.asm
@echo Assembling $<...
@$(AS) $(ASFLAGS) $< -o $(subst $(srcdir),$(objdir),$(<D))/$(@F)
else
%.o: %.c
@$(CC) $(CFLAGS) -Wno-unused -Wno-conversion -Wno-missing-prototypes -c $< -o $@
%.o: %.asm
@$(AS) $(ASFLAGS) $< -o $@
%.o:
@$(CC) $(CXXFLAGS) -c $< -o $@
endif
# Generate dependencies for C/C++ files
ifdef DEPEND
%.d: %.c
@echo Generating depend file for $<...
@$(CC) -MM -MT "$(subst $(srcdir),$(objdir),$(<D))/$(*F).o $(subst $(srcdir),$(objdir),$(<D))/$(@F)" -x c++ $(CFLAGS) $< >$(subst $(srcdir),$(objdir),$(<D))/$(@F)
%.d: %.cpp
@$(CXX) -MM -MT "$(subst $(srcdir),$(objdir),$(<D))/$(*F).o $(subst $(srcdir),$(objdir),$(<D))/$(@F)" -x c++ $(CXXFLAGS) $< >$(subst $(srcdir),$(objdir),$(<D))/$(@F)
endif
# Phony targets
init:
ifdef DEBUG
@echo Making debug build...
else
@echo Making normal build...
endif
@echo
@mkdir -p $(foreach dir, $(alldir),$(objdir)$(dir))
@mkdir -p $(srcdir)dep/generated
cleandep:
@echo Removing depend files from $(objdir)...
@for dir in $(alldir); do rm -f $(objdir)$$dir/*.d; done
clean:
@echo Removing all files from $(objdir)...
@rm -f -r $(objdir)
@rm -f -r $(ctv.h)
ifdef PERL
@echo Removing all files generated with perl scripts...
@rm -f -r $(driverlist)
endif
@echo Removing executable file...
@rm -f bin/$(NAME)
# Rule to force recompilation of any target that depends on it
FORCE:
It would be fantastic to get support for more games! (CPS3?)barrybarryk wrote:Haven't seen any real changes yet, but if he's working on it it could happen.
I've been working with that version of FBA-SDL posted above over the last few days and just managed to strip out the SDL rendering and replace it with some gl es / dispmanx rendering so it's now fullscreen and hardware accelerated for scaling / filters etc. Still have to add in the Cyclone 68k ASM core (or some other ASM variant, haven't tested each one for compatibility yet) to give the emulation speed a boost, probably the same with the Z80, and then add in proper front end/menu so you can tweak settings while it's running from the controller (like btn/scaler/filter and dip configs per game). The real benefit is it's built on a recent version of FBA with much, much better support.
I'd work on threading it out too but don't really know where to start. It'd probably mean a major rewrite to how FBA works, since to really get any decent benefit from multithreading the emulated sound processors and cpus by FBA really would need to be separated (from what little I understand of it).
I have tried all the different overclocking + ram split methods with Art of fighting 3, I also made a cache file for it but no matter what it still has cracks in the sound so I guess this is not a juice issue but a inaccurate emulation issue with pifba itself. I am on a Pi1 so someone on a Pi2 can feel free to try Art of fighting 3 and see if it behaves the same cause then it's definitely a emulation issue and not a juice issue.welshy wrote:KitchUK
'I have a really weird problem with a couple of Neo Geo games. For example Art of fighting 3 and Metal Slug 3.'
Hard to say, could be FBA itself or due to issues noted below of the original Hardware (or if your outputting Analogue sound as opposed to HDMI). I do know Cave's 'Danmaku' DoDonPachi doesn't seem to display any slowdown at 900Mhz which surprised/impressed me as the original PGM Hardware is much more powerful than SNK's MVS. Perhaps you could try lowering your GPU allocation to 64MEG, see if that helps.
Vanfanel
'The same happens here with Metal Slug 2, but not with Metal Slug X....strange indeed!'
The original MVS Metal Slug 2 suffered horrendous slowdown (to which Arcade Owners and their patrons complained) so was rewritten as Metal Slug X to address the issue by rearranging elements during the levels to prevent bottle necks.
(i think it's supposed to be march 2014 but yeah)March 2013:
DPAD/HAT support fixed.
Added 4 player joystick support.
Screen rotation option for vertical games.
