I have tried to install vlc but it seems to not play the files I want to see.
Used for the files it plays the omxplayer is very good! Nice picture, smooth flow and no freezing. It would be great if it worked on all other formats as well.
Jörgen
PPA are for x86 Linux and you have asked similar questions beforeKrassegrand wrote:I found this! (http://kodi.wiki/view/HOW-TO:Install_Ko ... tributions)
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi
I only used the 2 last lines to install
What do the 2 first lines do?
Jörgen
Maybe Raspberry is not for me!fruitoftheloom wrote:PPA are for x86 Linux and you have asked similar questions before
Is mpeg2 the problem?johndavies wrote:Have you considered buying the codecs which will allow you to run mpeg2?
That guide looks really good.johndavies wrote:You can enter a standalone version of kodi which will run on Raspbian. You will find details at http://www.raspberrypi.org/forums/viewt ... 66&t=99866. This one was posted by gkreidl. Have you considered buying the codecs which will allow you to run mpeg2?
