drhelius
Re: Emulation on the Raspberry Pi&Pi2 (Updated 19/02/2015)
Fri Mar 20, 2015 5:12 pm
Hi all, just wanted to let you know that I updated my Gearboy and Gersystem (Game Boy, Master System and Game Gear) emulators to Raspberry Pi 2.
I'm getting full speed emulation without frame drops for both emus. Feel free to ask me any questions.
https://github.com/drhelius/Gearboy
https://github.com/drhelius/Gearsystem
chrishoppybot
Sun Mar 29, 2015 1:15 am
I'm looking for some help. I have RetroPie up and running, I'm able to SAMBA ROMs across, and that plays fine.
The problem is, I'm wanting to map keys from the keyboard as the controller but am struggling to find a way to do this. Is anyone able to point me in the right direction please?
Kind regards,
Chris
mrpi64
Tue Apr 07, 2015 4:53 pm
Isn't there a cofig file somewhere? That may have some useful info in it.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
d4rks1d3
Mon Apr 13, 2015 1:47 am
Anyone have a copy of the Ignition.to beta for the rpi 2?
mrpi64
Fri May 01, 2015 4:17 pm
What, the game Ignition?
I'm happy to help.
ProDigit
Mon Jun 01, 2015 12:07 am
Hey,
I'm new to this thread.
Haven't read it all,
but I wonder about some of the claims to overclock the RPi to max settings to run some of these emulations.
GB, and GBA (GBC) versions run at 8 and 16bit, I believe.
Snes runs at 32bit.
Without trying it, I have the impression that they should run fine on the stock Pi CPU speed.
If they don't, then there must be some more efficient code somewhere, or some way to optimize the code.
I remember running NES, SNES, and GB/GBC/GBA games fine on a 630Mhz x86 processor (windows XP), at 640x480pix, but needed 700Mhz to run them at 800x600 pix (probably the CPU would have been fine at 630MHZ, but I needed faster Vram).
welshy
Mon Jun 01, 2015 5:12 pm
ProDigit wrote:I remember running NES, SNES, and GB/GBC/GBA games fine on a 630Mhz x86 processor (windows XP), at 640x480pix, but needed 700Mhz to run them at 800x600 pix (probably the CPU would have been fine at 630MHZ, but I needed faster Vram).
With Processor design its not Fz that governs power, just quatifying how fast the Chip is resonating and IPS/FLOPS ratings (Instructions Per Second/Floating Point Operations Per Second) can also be misleading*, as such, making comparisons between different CPU's ARM/X86/Power PC/ Cell etc. is pretty much pointless! lol I recall in the early days of the Pi (before it was officially allowed) many of us 'Early Adopters' were purposely O/C’ing having a discussion with one of the Engineers here he stated that it may cause the Pi to fail one or two days early if the Hardware was run PERMANENTLY for 20 YEARS! Which I guess was one of the reasons it was then 'Officially' allowed. Using the Pi's Menu Settings O/C's is accommodated only when required (unless you specifically specify this option) and I have found no issues with the five iterations of Hardware owned thus far, WITHOUT any additional cooling required. But I digress, the point is some Emulators will run effectively with no overclocking, but as the designers allow it without validating your Warranty why not use it?
* Nobody would argue that the Intellivision and ColecoVision are far more advanced than the Atari VCS/2600, however, in some instances; it could render Graphics that would be IMPOSSIBLE on those Systems due to its architecture!
"The list of things I have heard now contains everything!"
avinashlego
Re: Emulation on the Raspberry Pi&Pi2 (Updated 25/07/2015)
Wed Jul 29, 2015 8:58 pm
This post is a really useful resource for those interested in Raspberry Pi(2) emulation. Thanks for informing the community :-)
I like lego. End of story.
welshy
Thu Jul 30, 2015 5:53 am
avinashlego
Welcome to the Forum! Thank you for your kind words on the Thread, I'm glad you enjoy it and find the information useful for your Raspberry Pi Emulation endeavors!
avinashlego
Mon Aug 10, 2015 4:39 pm
Thanks! Also, take a look at Happi Game Center. It's another emulation image that is designed specially with the Pi2 in mind. It can emulate a number of systems previously not possible(3DO, Saturn, Jaguar, PSP, Virtual Boy). It also has integrated Raspbian and Kodi. The creator plans to add Dreamcast and Sega Naomi(Arcade Board from the early 2000s, ran Crazy Taxi) support soon.
Please take a look, the owner's name is erwan jestin(at least that's the channel name) and tell me what you think.
Thanks so much,
avinashlego
welshy
Mon Aug 10, 2015 4:57 pm
avinashlego
No Probs! Do you have a Link? Will Add to the Thread if applicable...
BarbuDreadMon
Tue Aug 11, 2015 6:45 pm
Happi Game Center is a retropie fork where the developper closed sources, the previous version i tried also had copyright issues (bios files were included). 3DO, Saturn, Jaguar, PSP and Virtual Boy on Happi Game Center are standard libretro cores running slowly on 99% games (i suppose you won't notice the slowdown on a few very static games), you can build those cores on any rpi distro.
avinashlego
Thu Aug 13, 2015 4:55 am
here ya go, welshy! happi-game-center.com
avinashlego
Thu Aug 13, 2015 5:01 am
Sorry BarbuDreadMon, not too much into coding and tech, so could you please simplify the language?
Thanks so much :?
BarbuDreadMon
Wed Aug 19, 2015 7:14 am
avinashlego wrote:Sorry BarbuDreadMon, not too much into coding and tech, so could you please simplify the language?
Thanks so much :?
There is no coding and tech in what i wrote, i just warned happi game center is/was in violation of copyrights and bring nothing new (no 3DO, Saturn, Jaguar, PSP and Virtual Boy emulation at normal speed).
lollo78
Re: Emulation on the Raspberry Pi&Pi2 (Updated 26/08/2015)
Sat Aug 29, 2015 2:00 pm
Hi guys, I love this thread: is the bible for Rpi/pi2 game emulation.
I use Retroarch (libretro core) on Openelec (Raspberry Pi2) with Advanced Launcher.
The new file (binary and core) are extracted from Lakka build using the original file adapted by Mezo (an Openelec forum user).
http://openelec.tv/forum/128-addons/729 ... mitstart=0
Works really fine (apart some crash of the "no more developed" Advanced Launcher :( ).
But Mezo is no more active, and his retroarch.start code need a fix.
I hope that here, we can find help from the largest and iperactive Raspberry community.
The retroarch.start code is:
#!/bin/sh
#      This file is part of OpenELEC - http://www.openelec.tv
#      Copyright (C) 2009-2014 Stephan Raue (stephan@openelec.tv)
#  OpenELEC is free software: you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation, either version 2 of the License, or
#  (at your option) any later version.
#  OpenELEC is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with OpenELEC.  If not, see <http://www.gnu.org/licenses/>.
. /etc/profile
oe_setup_addon emulator.tools.retroarch
RETROARCH_CONFIG_DIR="$ADDON_HOME/config"
RETROARCH_CONFIG_FILE="$RETROARCH_CONFIG_DIR/retroarch.cfg"
RETROARCH_SAVEFILES_DIR="$ADDON_HOME/savefiles"
RETROARCH_SYSTEM_DIR="$ADDON_HOME/system"
chmod a+x $ADDON_DIR/bin/*
if [ ! -f "$RETROARCH_CONFIG_FILE" ]; then
  mkdir -p $RETROARCH_CONFIG_DIR
  if [ -f $ADDON_DIR/config/retroarch.cfg ]; then
    cp $ADDON_DIR/config/retroarch.cfg $RETROARCH_CONFIG_FILE
  fi
fi
if [ ! -f "$RETROARCH_SAVEFILES_DIR" ]; then
  mkdir -p $RETROARCH_SAVEFILES_DIR
fi
if [ ! -f "$RETROARCH_SYSTEM_DIR" ]; then
  mkdir -p $RETROARCH_SYSTEM_DIR
fi
systemctl stop kodi
modprobe snd_bcm2835
$ADDON_DIR/bin/retroarch -c $RETROARCH_CONFIG_FILE -L $ADDON_DIR/lib/libretro/$1_libretro.so "$2"
rmmod snd_bcm2835
systemctl start kodi
The issue: if we activate in Kodi the "shutdown function after a given period of inactivity" (Setting->System->Power saving), the time setted here freezes retroarch at reach the preset time.
If we set 5 minutes, after 5 minutes of playing in Retroarch the video freezes (and so on with any other value of time).
Seems that Openlec doesn't reveal the retroarch activity, so stop all after the setted time.
Please, someone could help us with a code string or a script?
Thanks a lot
welshy
Sun Aug 30, 2015 1:43 pm
lollo78 wrote:Hi guys, I love this thread: is the bible for Rpi/pi2 game emulation.
Thank you and welcome to the Forum!
BarbuDreadMon
Fri Sep 04, 2015 7:42 am
Btw, i fixed ppsspp-libretro Makefile the other day, people should be able to build it on rpi2 by running
make -C libretro platform=rpi2
As mentioned in my last post, don't expect full speed except on a few games, you can try playing with core settings though
lollo78
Tue Sep 08, 2015 10:42 pm
BarbuDreadMon wrote:Btw, i fixed ppsspp-libretro Makefile the other day, people should be able to build it on rpi2 by running
Great! Anyone could share a compiled .so for the rpi2 (for whom like me that don't know how to compile it) to make some test and help the dev to find bugs?
Thx a lot
welshy
Wed Sep 09, 2015 8:17 am
Msg to Moderators
Can whomever edited the 'Updates', i.e. removed them from top and placed at the bottom of the Thread please explain the reason?
Chips
Sat Sep 12, 2015 10:11 pm
For amiga emulation, I think this thread needs some cleaning since it refer to some old uae not more maintained...
Moreover uae4arm is integrated in retropie and not listed in this thread, so people are using wrong thread when asking for questions :)
welshy
Tue Sep 15, 2015 4:08 am
Chips
Agreed, it's not always easy to keep up with the rapid changes of Pi Emulation! Do you have a Thread Link/Web Link for uae4arm?
EDIT: Found it, will Update the Emulation Thread later Today...
EDIT2: WOW! Nice! I have tested the Binary and it seems not to put a foot wrong where as previous Emulators did, even the final 'HAM' Image at the end of the 'Shadow of the Beast' loading screen shows no artifacts/color issues. Best of all the GUI will be familiar to WinUAE users! Will add to the Emulation Thread shortly.
Gronis
Re: Emulation on the Raspberry Pi&Pi2 (Updated 15/09/2015)
Fri Sep 25, 2015 4:58 pm
Maybe you should include Lakka in the list? (Maybe I have missed it?) Lakka is based on OpenELEC and is like recalbox, a dedicated system for emulation. It supports more hardware than the raspberry pi. One important thing is that it is using the RetroArch GUI, and I think they are working together with RetroArch. Maybe check it out, and include it as an alternative in the first post?
http://www.lakka.tv/
welshy
Wed Sep 30, 2015 12:46 am
Gronis
Correct! I don't think its on the SD Card list. I will check it out when time is available and add in the next few days, thanks! I dont catch Everything! lol
Gronis
Thu Oct 01, 2015 5:35 pm
welshy wrote:Gronis
No problem! I know how it is when starting out something, and then you have to maintain it ;) Just take your time :) Lakka is still a very young project, but since they work together with retroarch, I think it might be good to mention it :)
Return to “Gaming”
