That sandwich case looks better than the Bud sandwich, but that is just my personal taste
But this thread is used for lola34140's case, which is very nice and well designed.
Hope to see it soon on shapeways...
Hey Lolo, looks good but way too expensive @ €30.Lolo34140 wrote:Hi everyone,
I am pleased to inform you that my cases are finally available on http://www.shapeways.com/shops/FreakyShape!
I printed my case in White, Strong & Flexible on shapeways. The quality is very good and the Pi fit perfectly inside my case.
Some photos to illustrates my printed case from shapeways :
Hi,poing wrote:Hey Lolo, looks good but way too expensive @ €30.Lolo34140 wrote:Hi everyone,
But could you please reduce the size of your photos before uploading? This particular forum page takes a minute to load where I can't see the last post because all these enormous images of yours keep pushing the last post out of sight. In the image above I only see the side of a hand and if I click on it I'm taken to the front page of your ISP?? So I can't even see most of your images (some others seem smaller) while they make reading this page a hellish experience. Thanks.
The lightguide for my design case V1 (or all my others cases) is a different part of the case. You must order the lightguide + the case. But this is optional.Montala wrote:Looking good!
Just to clarify though, could you please confirm whether or not the power button 'light guide' is included with Version 1 of your Design Case, or does it have to be ordered separately?
Thanks!
There is a little gap between the light-guide and the wall of the case in order to be sure that the light-guide passes correctly through the top of the case. I add 2 clips on the top of the case which maintain the light-guide. However, I add this feature after I having received my printed case. So I didn't test this system. But if it don't works you need to stick the light-guide.Montala wrote:Hi 'Lolo'... thanks for the prompt reply, but I would appreciate it if you could clarify another couple of points for me please, before I actually place my order.
Firstly, how is the light-guide (V1) attached to the case... or is it just a 'push fit'?
I order the ultra frosted detail and this is very good. I never tested the frosted detail. But you can have an idea of the difference between these both materials here : http://www.shapeways.com/materials/frosted_detailMontala wrote:Shapeways show two options for the guide, 'frosted detail' and 'ultra frosted detail' which I assume is 'better' in some way, but is there really any practical difference, or advantage in buying the 'ultra' one?
The board is maintained thanks to the clips on the bottom of the case. The board is wall against wall with the case. Because it will have some differences between Pi production boards maybe it will have a little gap or not. But when the board is inside the case, you can plug and unplug all the cables easly without the board moves.Montala wrote:Am I right in thinking that that you have now checked out this actual case with a production model of the Raspberry Pi board, which presumably just clips into place into the base of the case?
I waited approximately 10 days before to receive my case printed by shapeways. The shipping is relatively quick.Montala wrote:Although it is more expensive, I am very tempted to go for an all black Design case V1, which I think should look very smart indeed, and would make a worthy home for my Pi... when it eventually arrives!
Mind you I will probably have to wait a couple of weeks or so for a case to be delivered to me, here in the UK, anyway.
Thank you again for the above clarification, but your latest statement does give me slight cause for concern.Lolo34140 wrote:I just want to clarify one other point regarding the design case V1. When you insert the board inside this case, contrary to the other cases, you need to bend just a little bit the front wall in order that the board passes inside the case. This is completly normal and wanted.
And this allows the Pi board to be well maintained inside my case.
And this conception allows to have some differences between Pi board because even if the front and the end walls are slightly bending by the boards (in the case of a board slightly bigger), the closure system will not be affected. And this can't be visible.
I think I didn't properly expressed myself in my last post. In principle the board will have approxymatly the same dimensions because in princple they are laser cut.Montala wrote:Thank you again for the above clarification, but your latest statement does give me slight cause for concern.Lolo34140 wrote:I just want to clarify one other point regarding the design case V1. When you insert the board inside this case, contrary to the other cases, you need to bend just a little bit the front wall in order that the board passes inside the case. This is completly normal and wanted.
I can accept that it may be necessary to bend the front wall of the case slightly in order to place the board in position, but I would not be very happy if both the front and end walls were to be pushed out line, due to an 'oversized', or bigger board.
We would hope that all the boards are made to an exact size, but from what you are saying it looks as if this may not in fact always be the case. I can accept that possibly the retaining 'clips' might have to be trimmed down a bit to accommodate a slightly larger board, but once the board was in place, then I would expect both end walls to be perfectly 'straight', as it were, in order to preserve the professional appearance of the case, which I still consider to be one of the most attractive ones currently available.
Perhaps this is something I will not actually know for sure though, until I receive both a case, and a Raspberry Pi to put inside it?
Hi alex,AlexS wrote:Hi,
will you publish the models, so that anybody print the cases with an own 3d printer?
Thanks,
Alex
