I am trying to make my own board to host the CM, and I would like to use the LAN9514 as on the RPi Model B+. I have read all threads on the subject on this forum, and I would like to share my schematic (attached).
I would appreciate it if someone has the time to have a look over and point out any problems. In particular, I have the following concerns:
1. LAN9514 is clocked by RPi GPIO 44, do I need an inline resistor between the GPIO44 pin and the XI pin of the Pi?
2. Does this clock line need to be routed with a specific impedance to ground?
3. How does RPi B+ handle the power control to downstream devices. I see a few ICs on the B+ near the LAN9514 and I assume these are the power management switches, however I can not determine which ICs they are exactly and in what configuration. I see there looks to be a SOT23-6 a SOT23-3 and something else, labelled U13, Q4 and D3, so obviously an IC, diode and a transistor, but how are they connected and are they all for port power management?
Thank you!
-Igor
p.s. Can not attach file, but you can see it at the following link:
LAN9514 Schematic
