pin_define@CAMERA_0_SDA_PIN {
type = "internal";
number = <28>;
pin_define@CAMERA_0_SCL_PIN {
type = "internal";
number = <29>;
enable_dpi_lcd=1
dpi_output_format=458759
hdmi_cvt=800 480 60 6
dpi_group=2
dpi_mode=87
#dpi_mode=4
#dpi_mode=9
#dpi_group=1
#dpi_mode=3
display_default_lcd=1
pin_config {
pin@default {polarity = "active_high"; termination = "pull_down";startup_state = "inactive";function = "input";};
pin@p0 {function = "dpi";termination = "no_pulling";drive_strength_mA = <0x8>;};
pin@p1 {function = "dpi";termination = "no_pulling";};
pin@p2 {function = "dpi";termination = "no_pulling";drive_strength_mA = <0x8>;};
pin@p3 {function = "dpi";termination = "no_pulling";};
pin@p4 {function = "dpi";termination = "no_pulling";};
pin@p5 {function = "dpi";termination = "no_pulling";};
pin@p6 {function = "dpi";termination = "no_pulling";};
pin@p7 {function = "dpi";termination = "no_pulling";};
pin@p8 {function = "dpi";termination = "no_pulling";};
pin@p9 {function = "dpi";termination = "no_pulling";};
pin@p10 {function = "dpi";termination = "no_pulling";};
pin@p11 {function = "dpi";termination = "no_pulling";};
pin@p12 {function = "dpi";termination = "no_pulling";};
pin@p13 {function = "dpi";termination = "no_pulling";};
pin@p14 {function = "dpi";termination = "no_pulling";};
pin@p15 {function = "dpi";termination = "no_pulling";};
pin@p16 {function = "dpi";termination = "no_pulling";};
pin@p17 {function = "dpi";termination = "no_pulling";};
pin@p18 {function = "dpi";termination = "no_pulling";};
pin@p19 {function = "dpi";termination = "no_pulling";};
pin@p20 {function = "dpi";termination = "no_pulling";};
pin@p21 {function = "dpi";termination = "no_pulling";};
pin@p22 {function = "dpi";termination = "no_pulling";};
pin@p23 {function = "dpi";termination = "no_pulling";};
pin@p24 {function = "dpi";termination = "no_pulling";};
pin@p25 {function = "dpi";termination = "no_pulling";};
pin@p26 {function = "dpi";termination = "no_pulling";};
pin@p27 {function = "dpi";termination = "no_pulling";};
pin@p28 {function = "i2c0";termination = "pull_up";};
pin@p29 {function = "i2c0";termination = "pull_up";};
pin@p31 {function = "output";termination = "pull_down";};
pin@p32 {function = "output";termination = "pull_down";};
pin@p35 {function = "input";termination = "no_pulling";polarity = "active_low";};
pin@p38 {function = "output";termination = "no_pulling";};
pin@p40 {function = "pwm";termination = "no_pulling";drive_strength_mA = <0x10>;};
pin@p41 {function = "output";termination = "no_pulling";};
pin@p44 {function = "gp_clk";termination = "pull_down";};
pin@p45 {function = "pwm";termination = "no_pulling";drive_strength_mA = <0x10>;};
pin@p46 {function = "input";termination = "no_pulling";polarity = "active_low";};
pin@p47 {function = "output";termination = "pull_down";};
pin@p48 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
pin@p49 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
pin@p50 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
pin@p51 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
pin@p52 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
pin@p53 {function = "sdcard";termination = "pull_up";drive_strength_mA = <0x8>;};
This may very well matter, I would recommend testing it. I could imagine the display driver needs to support the DPI registers.PR77 wrote: I am still using a SD Card with RISC OS (I only have a 2GB micro SD available) but I would _assume_ that it makes no difference as the DPI is control and configured with the Bootloader.bin / Start.elf and not the Kernal.img.
enable_dpi_lcd=1
dpi_output_format=4456965
#hdmi_cvt=400 240 60 6 0 0 0
#hdmi_cvt=480 272 60 3 0 0 0
hdmi_timings=400 0 1 2 2 240 0 2 4 2 0 0 0 60 0 9600000 6
#hdmi_timings= 480 0 1 41 2 272 0 2 10 2 0 0 0 60 0 9009000 3
dpi_group=2
dpi_mode=87
@Gert, The RGB signals for the LCD are active high and sampled on the falling edge of the D_CLK. I have checked this with a CRO (do you still use this word or oscilloscope is the way to go?) and it appears to be OK. I was thinking of a D_CLK sync issue as the D_CLK seems faster than what the LCD can handle and it may be sampling the pixel data at the wrong point.Gert van Loo wrote:I see green were it should be red
I see blue where it should be green
I see white where it should be black.
All signals need to be inverted?
There maybe the possibility of a LCD colour look-up table but I am not sure if that is usable in this situation.
I have to ask an expert at Pi headquarters.
@ceteras, good suggestion. I will try this. As I don't have X installed it may take a little longer to test this as I need to figure out how to display a picture with it. I'm far from a Linux guru!ceteras wrote:There are different shades of all colours on the boot screen and this makes it more difficult.
An rgb screen test like this image would help a lot more: http://1zelda.com/tv/pics/rgb_test.jpg
@Ross, the LCD is a RAW panel with no I2C interface. It has RGB, H+V Sync, DE and CLK. It is from the SHARP LQ050 family of panels.ross wrote:Can you describe what configuration / data (if any) you are setting up the panel with over I2C? Do you have a URL for the datasheet? (ideally the one with the command set of the panel)
My first guess is that trying to toggle any "display invert set" command might help (a W.A.G. of sending command 20h or 21h to toggle this)
cd /tmpPR77 wrote: @ceteras, good suggestion. I will try this. As I don't have X installed it may take a little longer to test this as I need to figure out how to display a picture with it. I'm far from a Linux guru!
Unlikely. All data for each individual pixel is transferred in parallel (this is why over 24 pins are needed), so screwed colors are not what you would expect from clock issues, much less almost exactly inverted color. My guess is like Gert's, that the display requires opposite polarity on the color lines for some weird reason, but the only datasheet I found seems to contradict that. Is there anything connected between the Pi pins and the display pins?. But if you want to reduce the pixel clock, what you might try is reducing the refresh rate and the blanking interval in your CVT config. I have not tried it myself (no fast scope at hand), but given that DPI is essentially a digital version of analog video, that should work.PR77 wrote: @Gert, The RGB signals for the LCD are active high and sampled on the falling edge of the D_CLK. I have checked this with a CRO (do you still use this word or oscilloscope is the way to go?) and it appears to be OK. I was thinking of a D_CLK sync issue as the D_CLK seems faster than what the LCD can handle and it may be sampling the pixel data at the wrong point.
@Dougie, thanks. This has worked and I was able to download and view the JPG.DougieLawson wrote:cd /tmpPR77 wrote: @ceteras, good suggestion. I will try this. As I don't have X installed it may take a little longer to test this as I need to figure out how to display a picture with it. I'm far from a Linux guru!
wget http://1zelda.com/tv/pics/rgb_test.jpg
You may need to get that with sudo apt-get install fbi but that's easier than getting X running.
@Gert and Ceteras, thanks also. After viewing the JPG it is easy to see that the colours are inverted as suggested. However this is not consistent with the datasheet as far as I am aware. Basically the LCD is;ceteras wrote:If the image is inverted, it would be like this:
- cyan instead of red
- magenta instead of green
- yellow instead of blue
This is nothing connected in-between the DPI of the Pi and the LCD. I have connected the two together via an Adafruit T-Cobbler and good quality pinned jumper cables.Fat D wrote:Unlikely. All data for each individual pixel is transferred in parallel (this is why over 24 pins are needed), so screwed colors are not what you would expect from clock issues, much less almost exactly inverted color. My guess is like Gert's, that the display requires opposite polarity on the color lines for some weird reason, but the only datasheet I found seems to contradict that. Is there anything connected between the Pi pins and the display pins?. But if you want to reduce the pixel clock, what you might try is reducing the refresh rate and the blanking interval in your CVT config. I have not tried it myself (no fast scope at hand), but given that DPI is essentially a digital version of analog video, that should work.
As for the test picture, do what Dougie said - use fbi.
Let us do the math for the pixel clock. Your display is 400x240, the refresh rate you have it set to amounts to 60 Hz. Disregarding blanking intervals for now, that means that in order to get every pixel out for every frame, your pixel clock is no smaller than 400*240*60 Hz = 5.76 MHz. Seems within spec for now. However, CVT introduces an additional 96 pixels of horizontal blanking and 16 lines of vertical blanking. That results in 496*256*60=7.something MHz, right on target. Reduced blanking instead fixed blanking pixel count irrespective of resolution, so it actually increases the blanking interval for such small screens. Anyway, there should be no reason for the Pi to output such high frequencies to begin with at your resolution, so something is off with your setup.
I'd guess "Yes". The GPU is identical, the pins are identical, the ARM7 can run ARM6 code, the kernel for the PI2 is 3.18.5+ built for ARM7 (probably to gain some go faster stripes).BMS Doug wrote:Is the Gert VGA compatible with the pi2?
It's a good guess. I've tested Gert's VGA adapter on Pi2 and it works just fine.DougieLawson wrote:I'd guess "Yes". The GPU is identical, the pins are identical, the ARM7 can run ARM6 code, the kernel for the PI2 is 3.18.5+ built for ARM7 (probably to gain some go faster stripes).
Ok. I installed gpio_list and from memory most of the initial pins were ALT2 (when trying to access the forum at home in the evening it is blocked for me so I'm going from memory). The 31 MHz signal is fairly sinusoidal (my CRO is 100 MHz @ 1Gs/s). I will post some pictures of the D_CLK and the washed-out screen when I probe the D_CLK. After probing the D_CLK the colours are still washed-out but I can clearly see some green, black and red text correctly displayed.Fat D wrote:Do you have gpio_list installed?
https://github.com/rewolff/bw_rpi_tools ... aster/gpio
If so, does it report ALT2 for the first 27 GPIOs when you execute it?
How clear is the 31 MHz trace and what levels does it have? A photo might be nice if you can provide one. Also, the complete config.txt that gives you the whited-out picture. Mind you, I am grasping for straws here.
Ok, so I've check the GPIO modes and the necessary pins are ALT2.Fat D wrote:I am most interested in the first two or four GPIOs, because they are where the magic happens. The rest just colors things.
A sinusoidal output on a Pi GPIO seems strange. Either you have way too much reactance on the bus, something resonant is connected there or there is a high impedance somewhere and you are picking up crosstalk. What are the peak values of the sinusoid?
Makes me wish I had my own scope so I could cross-check before talking so confidently about how things should be.
Also, why does a CRO have a sample rate?
root@raspberry-pi:~# sudo ./gpio_list
0 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2
10 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2
20 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT2 ALT0 ALT0
30 INP OUT OUT INP INP INP INP INP OUT INP
40 ALT0 OUT INP INP ALT0 ALT0 INP OUT ALT3 ALT3
50 ALT3 ALT3 ALT3 ALT3 INP
I'm connecting to the Pi with an Adafruit T-Cobbler inserted into a new breadboard. Then from the breadboard I have 15cm good quality jumpers with proper pins and receptacles. These jumper wires connect to a 0.1mil header on a FPC adapter board. All buzzed out ok.Fat D wrote:That trace looks awful. Again, I wish I knew what my working trace looked like.
I see nothing wrong with config and pin mux. One more idea: What kind and length of cables are there between the Pi and the screen. I am running lots of 10 cm jumper wires to a breadboard to a breakout to a 30 cm FPC extension to the screen's input FPC no problem, but the more you reveal about your setup, the stranger it gets.
Also, that looks like a DSO to me, not a CRO. Which explains the sample rate.
