- pi@raspberrypi ~ $ sudo rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS
*** Performing self-update
--2013-07-02 19:15:43-- https://github.com/Hexxeh/rpi-update/ra ... rpi-update
Resolving github.com (github.com)... failed: Name or service not known.
wget: unable to resolve host address `github.com'
!!! Failed to download update for rpi-update!
!!! Make sure you have ca-certificates installed and that the time is set correctly
I've run install and upgrade for the ca-certificates and 'apt-get' says that they are fine. The date/time are set fine. I've played with my network settings and have tried it with the WiFi and hard connect.
Any ideas?
Thanks,
Carl
