This is what you are letting people in for:
Python 3.2.2 (default, Sep 4 2011, 09:51:08) [MSC v.1500 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> for i = 1 to 10
SyntaxError: invalid syntax
>>> help
Type help() for interactive help, or help(object) for help about object.
>>> help(for)
>>> help (for)
>>> help()
Welcome to Python 3.2! This is the online help utility.
If this is your first time using Python, you should definitely check out
the tutorial on the Internet at
http://docs.python.org/tutorial/.
Enter the name of any module, keyword, or topic to get help on writing
Python programs and using Python modules. To quit this help utility and
return to the interpreter, just type "quit".
To get a list of available modules, keywords, or topics, type "modules",
"keywords", or "topics". Each module also comes with a one-line summary
of what it does; to list the modules whose summaries contain a given word
such as "spam", type "modules spam".
help> for
The ``for`` statement
The ``for`` statement is used to iterate over the elements of a
sequence (such as a string, tuple or list) or other iterable object:
for_stmt ::= "for" target_list "in" expression_list ":" suite
["else" ":" suite]
The expression list is evaluated once; it should yield an iterable
object. An iterator is created for the result of the
``expression_list``. The suite is then executed once for each item
provided by the iterator, in the order of ascending indices. Each
item in turn is assigned to the target list using the standard rules
for assignments (see *Assignment statements*), and then the suite is
executed. When the items are exhausted (which is immediately when the
sequence is empty or an iterator raises a ``StopIteration``
exception), the suite in the ``else`` clause, if present, is executed,
and the loop terminates.
A ``break`` statement executed in the first suite terminates the loop
without executing the ``else`` clause's suite. A ``continue``
statement executed in the first suite skips the rest of the suite and
continues with the next item, or with the ``else`` clause if there was
no next item.
The suite may assign to the variable(s) in the target list; this does
not affect the next item assigned to it.
Names in the target list are not deleted when the loop is finished,
but if the sequence is empty, it will not have been assigned to at all
by the loop. Hint: the built-in function ``range()`` returns an
iterator of integers suitable to emulate the effect of Pascal's ``for
i := a to b do``; e.g., ``list(range(3))`` returns the list ``[0, 1,
2]``.
Note: There is a subtlety when the sequence is being modified by the loop
(this can only occur for mutable sequences, i.e. lists). An
internal counter is used to keep track of which item is used next,
and this is incremented on each iteration. When this counter has
reached the length of the sequence the loop terminates. This means
that if the suite deletes the current (or a previous) item from the
sequence, the next item will be skipped (since it gets the index of
the current item which has already been treated). Likewise, if the
suite inserts an item in the sequence before the current item, the
current item will be treated again the next time through the loop.
This can lead to nasty bugs that can be avoided by making a
temporary copy using a slice of the whole sequence, e.g.,
for x in a[:]:
if x < 0: a.remove(x)
Related help topics: break, continue, while
help>
You are now leaving help and returning to the Python interpreter.
If you want to ask for help on a particular object directly from the
interpreter, you can type "help(object)". Executing "help('string')"
has the same effect as typing a particular string at the help> prompt.
Is this really going to motivate kids?
Chris
