No. The prime directive of NOOBS is that we never write to the recovery partition!does/can NOOBIE updates/upgrades itself automatically?
[b]Error[/b]
Error downloading or extracting tarball
wget: unable to resolve host adress 'downloads.raspberrypi.org'
tar: short read
Yes. This is exactly what the concept of adding OS flavours is meant to provide.Failing this...is there provision to simply be able to specify a script which automatically executes following an install (then it would be easy to customise any install as desired).
LOL, think you might have made a typo thererdb wrote:For further reference, please see how Raspbian handles the Boot to Raspbian flavour.
that means, every time a new version of NOOBS is available, i have to start from scratch? (format SD card, install and setup all OS)... uuuh that not good.rdb wrote:No. The prime directive of NOOBS is that we never write to the recovery partition!does/can NOOBS updates/upgrades itself automatically?
No, i meant really NOOBS itself, not the installed OS...ednl wrote:I think he meant the OS that NOOBS loads. Answer still no, the OS must do that. Alternatively, a simple update script for Raspbian that runs once week or so is easily made but depends on a network connection. More importantly, most users probably don't want or need automatic updates.rdb wrote:No. The prime directive of NOOBS is that we never write to the recovery partition!does/can NOOBS updates/upgrades itself automatically?
Hence the reason that this is a BETA release so that we only publish a final v1.3 release once it's been proved to be robust and stable.that means, every time a new version of NOOBS is available, i have to start from scratch? (format SD card, install and setup all OS)... uuuh that not good.
ya ya, ok ok ok... i understand it is a BETA.rdb wrote:Hence the reason that this is a BETA release so that we only publish a final v1.3 release once it's been proved to be robust and stable.that means, every time a new version of NOOBS is available, i have to start from scratch? (format SD card, install and setup all OS)... uuuh that not good.
The "prime directive" is what makes NOOBS so reliable... it means that no matter what else happens, NOOBS should always remain bootable, i.e. still able to rewrite a new OS installation if the OS's partition suffers from the dreaded SD card corruption.beta-tester wrote:that means, every time a new version of NOOBS is available, i have to start from scratch? (format SD card, install and setup all OS)... uuuh that not good.rdb wrote:No. The prime directive of NOOBS is that we never write to the recovery partition!
I guess your request kinda ties in with https://github.com/raspberrypi/noobs/issues/56 toomeltwater wrote:@rdb & AndrewS Ah...that sounds perfect. I shall have to do some digging to understand how it functions (and download the full NOOBS instead).
Thanks.
thank you, but what i dont understand is how to download it from that page.rdb wrote:See http://www.raspberrypi.org/archives/4863 for download links. NOOBS supports SDHC.
paraguaypi wrote:thank you, but what i dont understand is how to download it from that page.rdb wrote:See http://www.raspberrypi.org/archives/4863 for download links. NOOBS supports SDHC.
Did you remember to extract the files to the root of the card, and not to a subfolder within the card?ric96 wrote:Not Working![]()
tried the 20mb network only
got the "bloated pixel" screen then, BLANK!!!
no led other than power!!!
Ignore the README for now, the bit you specifically want from the URL that @rdb gave you is the bit where it says "Download Link: ".Oakham wrote:paraguaypi wrote:thank you, but what i dont understand is how to download it from that page.rdb wrote:See http://www.raspberrypi.org/archives/4863 for download links. NOOBS supports SDHC.![]()
http://www.raspberrypi.org/archives/4863 towards the bottom is a section called "How to Download the NOOBS v1.3 Beta"
https://github.com/raspberrypi/noobs/blob/dev/README.md
1. model b rev.2AndrewS wrote:Did you remember to extract the files to the root of the card, and not to a subfolder within the card?ric96 wrote:Not Working![]()
Some more info would probably be helpful, e.g. what model Pi, what you've got plugged into it, what kind of PSU you're using, what kind of TV/monitor you've got it plugged into, etc. etc.
Did you try pressing the 1 2 3 or 4 buttons on the keyboard as instructed to try the different display modes?
The purpose of beta-testing it to try and get detailed feedback
You mean where it says download link you can actually download something, now that is a novel ideaAndrewS wrote:Ignore the README for now, the bit you specifically want from the URL that @rdb gave you is the bit where it says "Download Link: ".
I guess it shows you can never make anything too easy!
Maybe you should patent itOakham wrote:You mean where it says download link you can actually download something, now that is a novel ideaAndrewS wrote:Ignore the README for now, the bit you specifically want from the URL that @rdb gave you is the bit where it says "Download Link: ".
I guess it shows you can never make anything too easy!![]()
