I want to overclock my pi but I am not sure about the power stuff.
Here are my power supply specs.
Input: AC100-240v
0.2A Max 50-60Hz
Output:DC5.0V
1000mA
Thx
Wait, how did u get windows server 2003 guest os on it. Please explain it simple because im only 14.miker00lz wrote:I've got my raspi running at 1.0 GHz CPU, 500 MHz SDRAM clock, overvolt is set to 6. I'm using force_turbo as well. It's totally stable, I have QEMU running on it right now. Windows Server 2003 guest OS installed, and it's been running perfectly with a full-time 100% CPU load for 2 days. The CPU isn't even that warm. I might try to see if I can jack it up even more later. It's handling it well so far.
I read many threads related to overclocking and there was power supply described as key for successful overclocking due to ability of deliver enough voltage. A power supply with more than 1.200mA was usually recommended. If I am mistaken, please correct me.klricks wrote:The power supply has not much to do with overclocking. The main fuse F3 will only reliably allow about 750mA into the board. The question is how much overclocking can you do without sustaining corruption to the filesystem on the SD card? I tried OC max and got corruption in a matter of minutes and had to re-image my SD card. I don't OC at all now.
You are quite correct. I have about 10 Pi's lying around. All support arm_freq=1000 (with overvolt). All support core_freq=500. All support sdram_freq=500 (and some sdram_freq=600).Liber wrote:I read many threads related to overclocking and there was power supply described as key for successful overclocking due to ability of deliver enough voltage. A power supply with more than 1.200mA was usually recommended. If I am mistaken, please correct me.klricks wrote:The power supply has not much to do with overclocking. The main fuse F3 will only reliably allow about 750mA into the board. The question is how much overclocking can you do without sustaining corruption to the filesystem on the SD card? I tried OC max and got corruption in a matter of minutes and had to re-image my SD card. I don't OC at all now.
Interesting. Has Windows 2003 finished booting up yet:)I've got my raspi running at 1.0 GHz CPU, 500 MHz SDRAM clock, overvolt is set to 6. I'm using force_turbo as well. It's totally stable, I have QEMU running on it right now. Windows Server 2003 guest OS installed, and it's been running perfectly with a full-time 100% CPU load for 2 days.
You are not wrong. Though the Pi won't draw more than 750ma, a PS rated a 1000ma will often still have too much of a voltage drop when drawing 750ma. PS's are normally rated by their "charging" ability and a voltage drop during "high charging" isn't critical. But it is critical when supplying a Pi. Particularly when OCing. I know you can buy a charger for an HP TP on ebay for under $5, rated for 2A. Why buy anything less?Liber wrote:I read many threads related to overclocking and there was power supply described as key for successful overclocking due to ability of deliver enough voltage. A power supply with more than 1.200mA was usually recommended. If I am mistaken, please correct me.klricks wrote:The power supply has not much to do with overclocking. The main fuse F3 will only reliably allow about 750mA into the board. The question is how much overclocking can you do without sustaining corruption to the filesystem on the SD card? I tried OC max and got corruption in a matter of minutes and had to re-image my SD card. I don't OC at all now.
