This is correct - the output resolution does not change but the framebuffer will be larger, then scaled to fit. This should allow OP to resolve any issues with setting up wifi (though the screen will be hard to read!).-rst- wrote:Yep, the actual display device most likely does not display any more pixels (physical limitations), but the framebuffer has more pixels and therefore the windows appear smaller (compared to the desktop size) ...the GPU scales the image down to the physical composite resolution.
